[GRASS-SVN] r66401 - grass/trunk/raster/r.reclass
svn_grass at osgeo.org
Fri Oct 2 11:27:30 PDT 2015
Author: hcho
Date: 2015-10-02 11:27:30 -0700 (Fri, 02 Oct 2015)
New Revision: 66401
grass/trunk/raster/r.reclass/r.reclass.html
r.reclass: Remove duplicate words from the manual
Modified: grass/trunk/raster/r.reclass/r.reclass.html
--- grass/trunk/raster/r.reclass/r.reclass.html 2015-10-02 17:38:25 UTC (rev 66400)
+++ grass/trunk/raster/r.reclass/r.reclass.html 2015-10-02 18:27:30 UTC (rev 66401)
@@ -36,7 +36,7 @@
<p>Also note that although the user can generate a <em>r.reclass</em> map
which is based on another <em>r.reclass</em> map,
-the new <em>r.reclass</em> map map will be stored in GRASS as a reclass
+the new <em>r.reclass</em> map will be stored in GRASS as a reclass
of the <em>original</em> raster map on which the first reclassed map was
based. Therefore, while GRASS allows the user to provide <em>r.reclass</em>
map layer information which is based on an already reclassified map
