[GRASS-SVN] r66423 - grass/branches/releasebranch_7_0/vector/v.mkgrid
svn_grass at osgeo.org
Tue Oct 6 07:39:26 PDT 2015
Author: martinl
Date: 2015-10-06 07:39:26 -0700 (Tue, 06 Oct 2015)
New Revision: 66423
grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c
grass/branches/releasebranch_7_0/vector/v.mkgrid/write_grid.c
v.mkgrid: finish progress (G_percent) info, be less verbose about progress (merge r66422 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c
--- grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c 2015-10-06 14:30:18 UTC (rev 66422)
+++ grass/branches/releasebranch_7_0/vector/v.mkgrid/main.c 2015-10-06 14:39:26 UTC (rev 66423)
@@ -413,7 +413,7 @@
/* Create a grid of label points at the centres of the grid cells */
- G_verbose_message(_("Creating centroids..."));
+ G_message(_("Creating centroids..."));
/* Write out centroids and attributes */
/* If the output id is lines it skips to add centroids and attributes
@@ -423,6 +423,7 @@
db_begin_transaction(Driver);
attCount = 0;
for (i = 0; i < grid_info.num_rows; ++i) {
+ G_percent(i, grid_info.num_rows, 2);
for (j = 0; j < grid_info.num_cols; ++j) {
double x, y;
@@ -464,6 +465,7 @@
attCount++;
+ G_percent(1, 1, 1);
db_commit_transaction(Driver);
Modified: grass/branches/releasebranch_7_0/vector/v.mkgrid/write_grid.c
--- grass/branches/releasebranch_7_0/vector/v.mkgrid/write_grid.c 2015-10-06 14:30:18 UTC (rev 66422)
+++ grass/branches/releasebranch_7_0/vector/v.mkgrid/write_grid.c 2015-10-06 14:39:26 UTC (rev 66423)
@@ -65,7 +65,7 @@
y_len = height / (1. * nbreaks + 1);
/* write out all the vector lengths (x vectors) of the entire grid */
- G_verbose_message(_("Writing out vector rows..."));
+ G_message(_("Writing out vector rows..."));
y = grid_info->south;
for (i = 0; i < num_v_rows; ++i) {
double startx;
@@ -101,9 +101,10 @@
y += height;
/* write out all the vector widths (y vectors) of the entire grid */
- G_verbose_message(_("Writing out vector columns..."));
+ G_message(_("Writing out vector columns..."));
x = grid_info->west;
for (i = 0; i < num_v_cols; ++i) {
double starty;
@@ -138,7 +139,8 @@
x += width;
/* new with Vlib */
Vect_destroy_line_struct(Points);
