[GRASS-SVN] r66425 - in grass/branches/releasebranch_7_0/temporal:	t.rast.export t.rast.import t.rast.list t.vect.export t.vect.import
    svn_grass at osgeo.org
    Tue Oct  6 08:26:07 PDT 2015
Author: neteler
Date: 2015-10-06 08:26:07 -0700 (Tue, 06 Oct 2015)
New Revision: 66425
   grass/branches/releasebranch_7_0/temporal/t.rast.export/t.rast.export.html
   grass/branches/releasebranch_7_0/temporal/t.rast.import/t.rast.import.html
   grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.html
   grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html
   grass/branches/releasebranch_7_0/temporal/t.vect.import/t.vect.import.html
temporal manual: filter example added; some cross-page standardization
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.export/t.rast.export.html
--- grass/branches/releasebranch_7_0/temporal/t.rast.export/t.rast.export.html	2015-10-06 15:24:26 UTC (rev 66424)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.export/t.rast.export.html	2015-10-06 15:26:07 UTC (rev 66425)
@@ -1,7 +1,7 @@
 <h2>DESCRIPTION</h2>
-This module exports a space time raster dataset as a tar archive. The
-archive contains the raster maps either as GeoTIFF files or as GRASS
+<em>t.rast.export</em> exports a space time raster dataset (strds) as a tar
+archive. The archive contains the raster maps either as GeoTIFF files or as GRASS
 binary files exported using <em>r.pack</em>. The map specific color tables
 are exported in case of GeoTIFF files. In addition several metadata files
 are created in the archive that describe the temporal layout.
@@ -15,18 +15,19 @@
 describes the file format. The output of <em>r.info</em> is stored in
 "metadata.txt".
 <p>
-The tar archive can be compressed using the <b>compress</b> option.
-Gzip and bzip2 are available. A <b>where</b> option can be specified,
+The tar archive can be compressed using the <b>compress</b> option. Gzip
+and bzip2 (default) are available. A <b>where</b> option can be specified,
 to export only a subset of the space time dataset. Archives exported
-with <em>t.rast.export</em> can be importet with <em>t.rast.import</em>.
+with <em>t.rast.export</em> can be imported with
+<em><a href="t.vect.import.html">t.rast.import</a></em>.
 <h2>EXAMPLE</h2>
-In this example all the maps of 2012 of tempmean_monthly will be exported
+In this example, all the maps of 2012 of "tempmean_monthly" will be exported:
 <div class="code"><pre>
 t.rast.export input=tempmean_monthly output=tempmean_monthly.tar.bzip2 \
-              where="start_time >= '2012-01-01' and start_time < '2013-01-01'"
+              where="start_time >= '2012-01-01' and start_time < '2013-01-01'"
 tar xvf precipitation_daily.tar
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.import/t.rast.import.html
--- grass/branches/releasebranch_7_0/temporal/t.rast.import/t.rast.import.html	2015-10-06 15:24:26 UTC (rev 66424)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.import/t.rast.import.html	2015-10-06 15:26:07 UTC (rev 66425)
@@ -8,17 +8,20 @@
 Optionally a base map name can be provided to avoid that existing
 raster maps are overwritten by the map names that are used in the STRDS
 archive.
+<p>
+The <b>directory</b> is used as work directory in case of import but
+can also be used as a data directory when using GeoTIFF for the data
+exchange.
 <h2>EXAMPLE</h2>
-Inside the North Carolina space time dataset it is possible to find a package
-called <em>lst_daily.tar.bzip2</em> with daily data from MODIS LST. Try
-to import it running:
+The North Carolina space time dataset contains a data package called
+<em>lst_daily.tar.bzip2</em> with daily data from MODIS LST. Import it
+by running:
 t.rast.import input=lst_daily.tar.bzip2 output=lst_daily \
               basename=lst directory=/tmp
 </pre></div>
 <h2>SEE ALSO</h2>
@@ -37,4 +40,3 @@
 Sören Gebbert, Thünen Institute of Climate-Smart Agriculture
 <p><i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.html
--- grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.html	2015-10-06 15:24:26 UTC (rev 66424)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.list/t.rast.list.html	2015-10-06 15:26:07 UTC (rev 66425)
@@ -66,7 +66,7 @@
 <p>
-t.rast.list tempmean_monthly columns=name,start_time,min,max where="max > 24"
+t.rast.list tempmean_monthly columns=name,start_time,min,max where="max > 24"
 name|start_time|min|max
 2009_06_tempmean|2009-06-01 00:00:00|15.962669|25.819681
 2009_07_tempmean|2009-07-01 00:00:00|15.32852|26.103664
@@ -80,7 +80,7 @@
 <h3>Filtering the result by time range</h3>
 In this example the result is filtered showing only the maps which
-fall into a specified time range
+fall into a specified time range (from .. to):
 <p>
@@ -96,6 +96,16 @@
 2012_08_tempmean|2012-08-01 00:00:00|15.718526|26.151115
 </pre></div>
+<h3>Filtering the result by selecting recurring timestamps</h3>
+In this example the result is filtered showing only the maps which
+fall into a specified recurring time range (here one month per year):
+<div class="code"><pre>
+t.rast.list Tseasonal_fieldata_garda where="strftime('%m', start_time)='06'"
+</pre></div>
 <h3>Using method option</h3>
 Method option is able to show raster in different way. By default <em>cols</em>
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html
--- grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html	2015-10-06 15:24:26 UTC (rev 66424)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.export/t.vect.export.html	2015-10-06 15:26:07 UTC (rev 66425)
@@ -12,23 +12,23 @@
 metadata. The "proj.txt" file stores the projection information as a
 proj4 string of the location the space time vector dataset was
 exported from. The file "readme.txt" describes the file format. The
-output of v.info for each vector map in the space time dataset is
+output of <em>v.info</em> for each vector map in the space time dataset is
 stored in "metadata.txt".
+<p>
+to export only a subset of the space time dataset. Archives exported
+with <em>t.vect.export</em> can be imported with
+<em><a href="t.vect.import.html">t.vect.import</a></em>.
-<p>Gzip or bzip2 (default) compression can be specified with the
-<strong>compress</strong> option. Archives exported with
-<em><a href="t.vect.export.html">t.vect.export</a></em> can be imported
-with <em><a href="t.vect.import.html">t.vect.import</a></em>.
 <h2>EXAMPLE</h2>
-In this example 5 vector maps are created and
+In this example, five vector maps are created and
 registered in a single space time vector dataset named <em>random_locations</em>.
 Each vector map represents random locations
 within the boundary of the state taken at 1 month intervals.
 t.vect.export input=shoreline output=shoreline_nc
 tar xvfj shoreline_nc
@@ -104,17 +104,15 @@
                  time stamps in ISO-Format. Field separator is |
  metadata.txt -- The output of t.info
    readme.txt -- This file
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="t.vect.import.html">t.vect.import</a>,
 <a href="t.create.html">t.create</a>,
 <a href="t.info.html">t.info</a>,
-<a href="v.in.ogr.html">v.in.ogr</a>,
+<a href="v.out.ogr.html">v.out.ogr</a>,
 <a href="v.unpack.html">v.unpack</a>,
 <a href="t.rast.export.html">t.rast.export</a>
 </em>
@@ -124,4 +122,3 @@
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.import/t.vect.import.html
--- grass/branches/releasebranch_7_0/temporal/t.vect.import/t.vect.import.html	2015-10-06 15:24:26 UTC (rev 66424)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.import/t.vect.import.html	2015-10-06 15:26:07 UTC (rev 66425)
@@ -1,16 +1,23 @@
-<em>t.vect.import</em> imports a space time vector dataset archive that was
-created with <a href="t.vect.export.html">t.vect.export</a>.
-Optionally a base map name can be provided to avoid overwriting vector maps
-used in the space-time vector dataset archive.
+<em>t.vect.import</em> imports a space time vector dataset archive that
+was exported with <a href="t.vect.export.html">t.vect.export</a>.
+<h2>NOTES</h2>
+Optionally a base map name can be provided to avoid that existing
+vector maps are overwritten by the map names that are used in the STRDS
+archive.
+<p>
+can also be used as a data directory when using GML for the data
+exchange.
 <h2>EXAMPLE</h2>
-In this example 5 vector maps are created and registered in a single space time
-vector dataset named <em>random_locations</em>. Each vector map represents
-random locations within the boundary of the state taken at 1 month intervals.
+In this example, five vector maps are created and registered in a single space time
+vector dataset named <em>random_locations</em>. Each vector map represents
+random locations within the boundary of the state taken at 1 month intervals.
 The space time dataset is then exported and re-imported.
@@ -18,7 +25,7 @@
 for i in `seq 1 5` ; do
     v.random output=map_$i n=500 input=boundary_state at PERMANENT
-    echo map_$i >> map_list.txt
+    echo map_$i >> map_list.txt
 done
 t.create type=stvds temporaltype=absolute \
@@ -52,7 +59,7 @@
 <a href="t.vect.export.html">t.vect.export</a>,
-<a href="v.out.ogr.html">v.out.ogr</a>,
+<a href="v.in.ogr.html">v.in.ogr</a>,
 <a href="v.pack.html">v.pack</a>,
 <a href="t.rast.import.html">t.rast.import</a>
 </em>
