[GRASS-SVN] r66427 - in grass/branches/releasebranch_7_0: scripts/v.what.vect vector/v.distance
svn_grass at osgeo.org
Wed Oct 7 01:15:43 PDT 2015
Author: neteler
Date: 2015-10-07 01:15:43 -0700 (Wed, 07 Oct 2015)
New Revision: 66427
grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.html
grass/branches/releasebranch_7_0/vector/v.distance/main.c
grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html
v.distance: tell user if input is 3D (esp. relevant for v.what.vect)
Modified: grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.html
--- grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.html 2015-10-07 08:15:15 UTC (rev 66426)
+++ grass/branches/releasebranch_7_0/scripts/v.what.vect/v.what.vect.html 2015-10-07 08:15:43 UTC (rev 66427)
@@ -17,6 +17,8 @@
<p>When transferring attributes from a point map to a polygon map, usually <b>dmax</b>
has to be larger than zero (determined by distance between query points and
polygon centroids).
+<p>In case that one or both input vector maps are 3D, features need to touch also
+in the 3rd dimension (z coordinate) in order to transfer attributes.
<h2>EXAMPLES</h2>
Modified: grass/branches/releasebranch_7_0/vector/v.distance/main.c
--- grass/branches/releasebranch_7_0/vector/v.distance/main.c 2015-10-07 08:15:15 UTC (rev 66426)
+++ grass/branches/releasebranch_7_0/vector/v.distance/main.c 2015-10-07 08:15:43 UTC (rev 66427)
@@ -310,6 +310,9 @@
G_fatal_error(_("Unable to open vector map <%s>"), opt.from->answer);
from_field = Vect_get_field_number(&From, opt.from_field->answer);
+ /* in 3D features may not be found */
+ if (Vect_is_3d(&From))
+ G_warning(_("Input vector map <%s> is 3D"), opt.from->answer);
nfromlines = Vect_get_num_primitives(&From, from_type);
nfromareas = 0;
@@ -327,6 +330,9 @@
Vect_set_open_level(2);
if (Vect_open_old2(&To, opt.to->answer, "", opt.to_field->answer) < 0)
G_fatal_error(_("Unable to open vector map <%s>"), opt.to->answer);
+ if (Vect_is_3d(&To))
+ G_warning(_("Input vector map <%s> is 3D"), opt.to->answer);
ntolines = Vect_get_num_primitives(&To, to_type);
ntoareas = 0;
Modified: grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html
--- grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html 2015-10-07 08:15:15 UTC (rev 66426)
+++ grass/branches/releasebranch_7_0/vector/v.distance/v.distance.html 2015-10-07 08:15:43 UTC (rev 66427)
@@ -50,6 +50,7 @@
If a nearest feature does not have a category, the attribute column is
updated to NULL.
<p>The upload <b>column</b>(s) must already exist. Create one with
<em><a href="v.db.addcolumn.html">v.db.addcolumn</a></em>.
@@ -57,6 +58,10 @@
(<em>dist</em>, <em>from_along</em>, and <em>to_along</em>) not in
degrees but in meters calculated as geodesic distances on a sphere.
+<p>
+If one or both of the input vector maps are 3D, the user is notified
+accordingly.
<h2>EXAMPLES</h2>
<h3>Find nearest lines</h3>
