[GRASS-SVN] r66429 - grass/trunk/gui/wxpython/vnet
svn_grass at osgeo.org
Wed Oct 7 13:19:19 PDT 2015
Author: turek
Date: 2015-10-07 13:19:19 -0700 (Wed, 07 Oct 2015)
New Revision: 66429
grass/trunk/gui/wxpython/vnet/vnet_data.py
wx.vnet points list fixes
Modified: grass/trunk/gui/wxpython/vnet/vnet_data.py
--- grass/trunk/gui/wxpython/vnet/vnet_data.py 2015-10-07 08:27:16 UTC (rev 66428)
+++ grass/trunk/gui/wxpython/vnet/vnet_data.py 2015-10-07 20:19:19 UTC (rev 66429)
@@ -308,6 +308,10 @@
idx = self.cols["name"].index(col)
self.data[pt_id][idx] = v
+ # if type is changed checked columns must be recalculated by _usePoint
+ if data.has_key('type') and not data.has_key('use'):
+ data["use"] = self.GetPointData(pt_id)['use']
if data.has_key('use'):
if self._usePoint(pt_id, data["use"]) == -1:
data["use"] = False
@@ -374,6 +378,9 @@
if "analysis" in kwargs["changed_params"].keys():
self._updateTypeCol()
+ if self.an_params.GetParam("analysis")[0] == "v.net.path":
+ self._vnetPathUpdateUsePoints(None)
def _updateTypeCol(self):
"""Rename category values when module is changed. Expample: Start point -> Sink point"""
colValues = [""]
@@ -415,21 +422,28 @@
if len(cats) <= 1:
return 0
- type_idx = self.cols["name"].index("type")
use_idx = self.cols["name"].index("use")
checkedVal = self.data[pt_id][1]
+ # point without given type cannot be selected
if checkedVal == 0:
self.data[pt_id][use_idx] = False
self.pointsChanged.emit(method = "SetPointData", kwargs = {"pt_id" : pt_id, "data" : {"use" : False}})
return -1
if analysis == "v.net.path" and use:
+ self._vnetPathUpdateUsePoints(pt_id)
+ def _vnetPathUpdateUsePoints(self, checked_pt_id):
alreadyChecked = []
- if pt_id:
- checkedKey = pt_id
- alreadyChecked.append(self.data[pt_id][type_idx])
+ type_idx = self.cols["name"].index("type")
+ use_idx = self.cols["name"].index("use")
+ if checked_pt_id is not None:
+ checkedKey = checked_pt_id
+ alreadyChecked.append(self.data[checked_pt_id][type_idx])
else:
checkedKey = -1
@@ -633,9 +647,10 @@
columnchoices = dbInfo.GetTableDesc(table)
except (KeyError, ValueError):
table = None
# check costs columns
for col in ["arc_column", "arc_backward_column", "node_column"]:
if col == "node_column":
try:
table = dbInfo.GetTable(int(params["node_layer"]))
@@ -647,7 +662,7 @@
invParams.append(col)
continue
- if columnchoices[params[col]]['type'] not in ['integer', 'double precision']:
+ if columnchoices[params[col]]['type'] not in ['integer', 'double precision']:
continue
@@ -998,6 +1013,7 @@
RunCommand(layerStyleVnetColors[0],
**layerStyleVnetColors[1])
self.renderLayer = self.mapWin.Map.AddLayer(ltype = "vector", command = cmd,
name = self.fullName, active = True,
opacity = 1.0, render = False,
