[GRASS-SVN] r66458 - grass/trunk/lib/python/temporal
Fri Oct 9 15:09:49 PDT 2015
Author: huhabla
Date: 2015-10-09 15:09:49 -0700 (Fri, 09 Oct 2015)
New Revision: 66458
   grass/trunk/lib/python/temporal/space_time_datasets.py
temporal framework: Added relative time stamp doc-tests
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2015-10-09 21:47:54 UTC (rev 66457)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2015-10-09 22:09:49 UTC (rev 66458)
@@ -73,6 +73,16 @@
              | Minimum value:.............. 1.0
              | Maximum value:.............. 1.0
+            >>> grass.run_command("r.timestamp", map="strds_map_test_case",
+            ...                   date="2 years", quiet=True)
+            0
+            >>> rmap.read_timestamp_from_grass()
+            True
+            >>> rmap.get_temporal_extent_as_tuple()
+            (2, None)
+            >>> rmap.get_relative_time_unit()
+            'years'
             >>> newmap = rmap.get_new_instance("new at PERMANENT")
             >>> isinstance(newmap, RasterDataset)
             True
@@ -392,6 +402,16 @@
              | Number of depths:........... 10
              | Top-Bottom resolution:...... 10.0
+            >>> grass.run_command("r3.timestamp", map="str3ds_map_test_case",
+            0
+            >>> r3map.read_timestamp_from_grass()
+            True
+            >>> r3map.get_temporal_extent_as_tuple()
+            (2, None)
+            >>> r3map.get_relative_time_unit()
+            'years'
             >>> newmap = r3map.get_new_instance("new at PERMANENT")
             >>> isinstance(newmap, Raster3DDataset)
             True
@@ -722,6 +742,17 @@
              | Number of islands .......... 0
              | Number of holes ............ 0
              | Number of volumes .......... 0
+            >>> grass.run_command("v.timestamp", map="stvds_map_test_case",
+            0
+            >>> vmap.read_timestamp_from_grass()
+            True
+            >>> vmap.get_temporal_extent_as_tuple()
+            (2, None)
+            >>> vmap.get_relative_time_unit()
+            'years'
             >>> newmap = vmap.get_new_instance("new at PERMANENT")
             >>> isinstance(newmap, VectorDataset)
             True
