[GRASS-SVN] r66473 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Oct 12 01:09:50 PDT 2015
Author: lucadelu
Date: 2015-10-12 01:09:50 -0700 (Mon, 12 Oct 2015)
New Revision: 66473
grass/trunk/lib/init/grass.py
init/grass.py: check if owner mapset is valid
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2015-10-12 07:11:01 UTC (rev 66472)
+++ grass/trunk/lib/init/grass.py 2015-10-12 08:09:50 UTC (rev 66473)
@@ -1161,6 +1161,13 @@
if not os.path.exists(mapset_path):
fatal(_("Path '%s' doesn't exist") % mapset_path)
+ if not os.access(mapset_path, os.W_OK):
+ error = "Path '%s' not accessible.\n" % mapset_path
+ stat_info = os.stat(mapset_path)
+ mapset_uid = stat_info.st_uid
+ if mapset_uid != os.getuid():
+ error += "You are not the owner of '%s'" % mapset_path
+ fatal(_(error))
# Check for concurrent use
lockfile = os.path.join(mapset_path, ".gislock")
ret = call([gpath("etc", "lock"), lockfile, "%d" % os.getpid()])
