[GRASS-SVN] r66499 - grass-addons/grass7/imagery/i.spec.sam
svn_grass at osgeo.org
Thu Oct 15 03:09:49 PDT 2015
Author: ychemin
Date: 2015-10-15 03:09:49 -0700 (Thu, 15 Oct 2015)
New Revision: 66499
grass-addons/grass7/imagery/i.spec.sam/global.h
grass-addons/grass7/imagery/i.spec.sam/main.c
grass-addons/grass7/imagery/i.spec.sam/open.c
working more on mat_struct
Modified: grass-addons/grass7/imagery/i.spec.sam/global.h
--- grass-addons/grass7/imagery/i.spec.sam/global.h 2015-10-15 09:19:56 UTC (rev 66498)
+++ grass-addons/grass7/imagery/i.spec.sam/global.h 2015-10-15 10:09:49 UTC (rev 66499)
@@ -13,9 +13,7 @@
#define MAXFILES 255
-//extern MAT *A;
extern mat_struct *A;
-//extern VEC *b, *Avector;
extern vec_struct *b, *Avector;
extern int matrixsize;
extern float curr_angle;
Modified: grass-addons/grass7/imagery/i.spec.sam/main.c
--- grass-addons/grass7/imagery/i.spec.sam/main.c 2015-10-15 09:19:56 UTC (rev 66498)
+++ grass-addons/grass7/imagery/i.spec.sam/main.c 2015-10-15 10:09:49 UTC (rev 66499)
@@ -58,7 +58,6 @@
int band;
int i, j, error=0;
vec_struct *svd_values;
- /*VEC *svd_values;*/
/*char command[80]; rm by Yann temporarily see grayscale palette*/
float anglefield[255][255];
struct
@@ -141,23 +140,21 @@
error=1;
- if (!error)
+ if (!error)
G_message("Spectral matrix is o.k. Proceeding...\n");
-/* check singular values of Matrix A
- * Ref: Boardman, J.W. 1989: Inversion of imaging spectrometry data
- * using singular value decomposition. IGARSS 1989: 12th Canadian
- * symposium on Remote Sensing. Vol.4 pp.2069-2072
+ /* check singular values of Matrix A
+ * Ref: Boardman, J.W. 1989: Inversion of imaging spectrometry data
+ * using singular value decomposition. IGARSS 1989: 12th Canadian
+ * symposium on Remote Sensing. Vol.4 pp.2069-2072
G_message("Singular values of Matrix A:");
- svd_values = svd(A, MNULL, MNULL, VNULL);
+ G_math_svdval( (double *) svd_values->vals, (double **) A->vals, A->cols, A->rows);
v_output(svd_values);
- if (error)
- G_fatal_error("Exiting...\n");
+ if (error)
+ G_fatal_error("Error in singular value decomposition, exiting...\n");
- /* alright, start Spectral angle mapping */
+ /* alright, start Spectral angle mapping */
nrows = Rast_window_rows();
ncols = Rast_window_cols();
@@ -171,16 +168,16 @@
Rast_get_c_row (cellfd[band], cell[band], row);
for (col = 0; col < ncols; col++) /* cols loop, work pixelwise for all bands */
/* get pixel values of each band and store in b vector: */
- b = v_get(A->m); /* dimension of vector = matrix size = Ref.nfiles*/
+ /*b = v_get(A->m); /* dimension of vector = matrix size = Ref.nfiles*/
+ b = v_get(A->cols); /* Yann: Doubt about "cols", TODO CHECK: dimension of vector = matrix size = Ref.nfiles*/
for (band = 0; band < Ref.nfiles; band++)
- b->ve[band] = cell[band][col]; /* read input vector */
+ b->vals[band] = cell[band][col]; /* read input vector */
/* calculate spectral angle for current pixel
* between pixel spectrum and reference spectrum
* and write result in full degree */
for (i = 0; i < Ref.nfiles; i++) /* Ref.nfiles = matrixsize*/
Avector = G_matvect_get_row(A, i); /* go row-wise through matrix*/
@@ -188,22 +185,20 @@
result_cell[i][col] = myround (curr_angle);
G_vector_free(Avector);
G_vector_free(b);
- } /* columns loop */
+ } /* columns loop */
/* write the resulting rows: */
Rast_put_c_row (resultfd[i], result_cell[i]);
} /* rows loop */
G_percent(row, nrows, 2);
/* close files */
Rast_close (resultfd[i]);
Rast_unopen(cellfd[i]);
/* make grey scale color table */
@@ -211,8 +206,7 @@
sprintf(command, "r.colors map=%s color=grey >/dev/null", result_name);
system(command);*/ /*Commented by Yann*/
/* write a color table */
G_matrix_free(A);
make_history(result_name, group, matrixfile);
return(EXIT_SUCCESS);
Modified: grass-addons/grass7/imagery/i.spec.sam/open.c
--- grass-addons/grass7/imagery/i.spec.sam/open.c 2015-10-15 09:19:56 UTC (rev 66498)
+++ grass-addons/grass7/imagery/i.spec.sam/open.c 2015-10-15 10:09:49 UTC (rev 66499)
@@ -25,7 +25,7 @@
if (fp == NULL)
G_fatal_error("ERROR: Matrixfile %s not found.\n",matrixfile);
/* Read data and close file */
- if ((G_matrix_read2(fp, &A) < 0))
+ if ((G_matrix_read2(fp, A) < 0))
G_fatal_error(_("Unable to read matrix file %s."), matrixfile);
fclose(fp);
