[GRASS-SVN] r66501 - grass-addons/grass7/raster/r.shaded.pca
svn_grass at osgeo.org
Thu Oct 15 06:51:36 PDT 2015
Author: annakrat
Date: 2015-10-15 06:51:36 -0700 (Thu, 15 Oct 2015)
New Revision: 66501
grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.html
grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.py
r.shaded.pca: fix after renaming r.relief
Modified: grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.html
--- grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.html 2015-10-15 12:08:20 UTC (rev 66500)
+++ grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.html 2015-10-15 13:51:36 UTC (rev 66501)
@@ -3,16 +3,16 @@
<em>r.shaded.pca</em> is a tool for the generation
of RGB composite of the three main components
of PCA created from different hill shades
-(created by <em><a href="r.shaded.relief.html">r.shaded.relief</a></em>).
+(created by <em><a href="r.shaded.relief.html">r.relief</a></em>).
<h3>Input parameters explanation</h3>
Input parameters are the same as for
-<em><a href="r.shaded.relief.html">r.shaded.relief</a></em> module except for
+<em><a href="r.relief.html">r.relief</a></em> module except for
an <i>azimuth</i> parameter which is replaced by <i>nazimuths</i> parameter
(we need to specify number of different azimuths rather than one)
and for an <i>nprocs</i> parameter which adds the possibility to run the
-shades creation (<em><a href="r.shaded.relief.html">r.shaded.relief</a></em>)
+shades creation (<em><a href="r.relief.html">r.relief</a></em>)
in parallel. However, the speed of <em><a href="i.pca.html">i.pca</a></em>
limits the overall speed of this module.
@@ -34,7 +34,7 @@
Moreover, if you would like to add one of the shades to your composition,
you can specify the <i>shades_basename</i> parameter then the module will
output also the hill shade maps as created during
-the process by <em><a href="r.shaded.relief.html">r.shaded.relief</a></em>.
+the process by <em><a href="r.relief.html">r.relief</a></em>.
One of the shades can be used to subtract the intensity channel in HIS
composition or just as an overlay in your visualization tool.
@@ -66,7 +66,7 @@
<h2>SEE ALSO</h2>
<em>
-<a href="r.shaded.relief.html">r.shaded.relief</a>,
+<a href="r.relief.html">r.relief</a>,
</em>
Modified: grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.py
--- grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.py 2015-10-15 12:08:20 UTC (rev 66500)
+++ grass-addons/grass7/raster/r.shaded.pca/r.shaded.pca.py 2015-10-15 13:51:36 UTC (rev 66501)
@@ -128,9 +128,9 @@
params = {}
if units:
params.update({'units': units})
- grass.run_command('r.shaded.relief', input=elevation_input,
+ grass.run_command('r.relief', input=elevation_input,
output=shades_basename + suffix,
- azimuth=azimuth, zmult=z_exaggeration,
+ azimuth=azimuth, zscale=z_exaggeration,
scale=scale, altitude=altitude,
overwrite=core.overwrite(), quiet=True,
**params)
@@ -196,7 +196,7 @@
check_map_names(pca_basename, grass.gisenv()['MAPSET'],
suffixes=range(1, number_of_azimuths))
- grass.info(_("Running r.shade.relief in a loop..."))
+ grass.info(_("Running r.relief in a loop..."))
count = 0
# Parallel processing
proc_list = []
@@ -229,7 +229,7 @@
exitcodes += proc.exitcode
if exitcodes != 0:
- core.fatal(_("Error during r.shade.relief computation"))
+ core.fatal(_("Error during r.relief computation"))
# Empty process list
proc_list = []
