[GRASS-SVN] r66509 - grass/branches/releasebranch_7_0/gui/wxpython/vnet
svn_grass at osgeo.org
Thu Oct 15 19:19:57 PDT 2015
Author: annakrat
Date: 2015-10-15 19:19:57 -0700 (Thu, 15 Oct 2015)
New Revision: 66509
grass/branches/releasebranch_7_0/gui/wxpython/vnet/dialogs.py
wxGUI/vnet: fix known problem with StaticBoxes on Mac (merge from trunk, r66497)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/vnet/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/vnet/dialogs.py 2015-10-15 16:51:03 UTC (rev 66508)
+++ grass/branches/releasebranch_7_0/gui/wxpython/vnet/dialogs.py 2015-10-16 02:19:57 UTC (rev 66509)
@@ -197,10 +197,16 @@
def _createPointsPage(self):
"""Tab with points list and analysis settings"""
pointsPanel = wx.Panel(parent = self)
+ anSettingsPanel = wx.Panel(parent = pointsPanel)
+ maxDistPanel = wx.Panel(parent = anSettingsPanel)
maxValue = 1e8
listBox = wx.StaticBox(parent = pointsPanel, id = wx.ID_ANY,
label =" %s " % _("Points for analysis:"))
+ listSizer = wx.StaticBoxSizer(listBox, wx.VERTICAL)
+ anSettingsBox = wx.StaticBox(parent = anSettingsPanel, id = wx.ID_ANY,
+ label =" %s " % _("Analysis settings:"))
+ anSettingsSizer = wx.StaticBoxSizer(anSettingsBox, wx.VERTICAL)
self.notebook.AddPage(page = pointsPanel,
text=_('Points'),
@@ -213,12 +219,6 @@
dialog=self,
vnet_mgr=self.vnet_mgr)
- anSettingsPanel = wx.Panel(parent = pointsPanel)
- anSettingsBox = wx.StaticBox(parent = anSettingsPanel, id = wx.ID_ANY,
- label =" %s " % _("Analysis settings:"))
- maxDistPanel = wx.Panel(parent = anSettingsPanel)
maxDistLabel = wx.StaticText(parent = maxDistPanel, id = wx.ID_ANY, label = _("Maximum distance of point to the network:"))
self.anSettings["max_dist"] = wx.SpinCtrl(parent = maxDistPanel, id = wx.ID_ANY, min = 0, max = maxValue)
self.anSettings["max_dist"].Bind(wx.EVT_SPINCTRL, lambda event : self.MaxDist())
@@ -240,12 +240,10 @@
# Layout
AnalysisSizer = wx.BoxSizer(wx.VERTICAL)
- listSizer = wx.StaticBoxSizer(listBox, wx.VERTICAL)
listSizer.Add(item = self.toolbars['pointsList'], proportion = 0)
listSizer.Add(item = self.list, proportion = 1, flag = wx.EXPAND)
- anSettingsSizer = wx.StaticBoxSizer(anSettingsBox, wx.VERTICAL)
maxDistSizer = wx.BoxSizer(wx.HORIZONTAL)
maxDistSizer.Add(item = maxDistLabel, flag = wx.ALIGN_CENTER_VERTICAL, proportion = 1)
@@ -333,6 +331,10 @@
#self.useTurns = wx.CheckBox(parent = dataPanel, id=wx.ID_ANY,
# label = _('Use turns'))
+ box = wx.StaticBox(dataPanel, -1, "Vector map and layers for analysis")
+ bsizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ box2 = wx.StaticBox(dataPanel, -1, "Costs")
+ bsizer2 = wx.StaticBoxSizer(box2, wx.VERTICAL)
selPanels = {}
for dataSel in dataSelects:
@@ -375,8 +377,6 @@
# Layout
mainSizer = wx.BoxSizer(wx.VERTICAL)
- box = wx.StaticBox(dataPanel, -1, "Vector map and layers for analysis")
- bsizer = wx.StaticBoxSizer(box, wx.VERTICAL)
mainSizer.Add(item = bsizer, proportion = 0,
flag = wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border = 5)
@@ -398,15 +398,13 @@
bsizer.Add(item = selPanels[sel], proportion = 0,
flag = wx.EXPAND)
- box = wx.StaticBox(dataPanel, -1, "Costs")
- mainSizer.Add(item = bsizer, proportion = 0,
+ mainSizer.Add(item = bsizer2, proportion = 0,
for sel in ['arc_column', 'arc_backward_column', 'node_column']:
selPanels[sel].SetSizer(self._doSelLayout(title = label[sel], sel = self.inputData[sel]))
- bsizer.Add(item = selPanels[sel], proportion = 0,
+ bsizer2.Add(item = selPanels[sel], proportion = 0,
flag = wx.EXPAND)
@@ -1124,6 +1122,17 @@
self.parent = parent
self.settings = {}
+ # create all staticboxes before creating widgets, needed for Mac
+ otherBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label =" %s " % _("Other settings"))
+ otherBoxSizer = wx.StaticBoxSizer(otherBox, wx.VERTICAL)
+ ptsStyleBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label =" %s " % _("Point style:"))
+ ptsStyleBoxSizer = wx.StaticBoxSizer(ptsStyleBox, wx.VERTICAL)
+ styleBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label =" %s " % _("Analysis result style:"))
+ styleBoxSizer = wx.StaticBoxSizer(styleBox, wx.VERTICAL)
rules = RunCommand('v.colors',
read = True,
flags = 'l')
@@ -1199,9 +1208,6 @@
sizer = wx.BoxSizer(wx.VERTICAL)
- styleBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label =" %s " % _("Analysis result style:"))
- styleBoxSizer = wx.StaticBoxSizer(styleBox, wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
@@ -1229,10 +1235,6 @@
styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
# Point style layout
- ptsStyleBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label =" %s " % _("Point style:"))
- ptsStyleBoxSizer = wx.StaticBoxSizer(ptsStyleBox, wx.VERTICAL)
row = 0
@@ -1251,10 +1253,6 @@
ptsStyleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
# Other settings layout
- otherBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label =" %s " % _("Other settings"))
- otherBoxSizer = wx.StaticBoxSizer(otherBox, wx.VERTICAL)
row = 0
@@ -1331,6 +1329,8 @@
"""Create turntable dialog."""
wx.Dialog.__init__(self, parent, id, title = _(title), style = style)
+ box = wx.StaticBox(self, -1, "Vector map and layers for analysis")
label = {}
dataSelects = [
['input', "Choose vector map for analysis:", Select],
@@ -1367,8 +1367,6 @@
# Layout
- box = wx.StaticBox(self, -1, "Vector map and layers for analysis")
@@ -1471,6 +1469,10 @@
self.panel = wx.Panel(parent = self)
+ box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
+ label = "Vector map")
+ self.boxSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
# text fields and it's captions
self.vectSel = Select(parent = self.panel, type = 'vector',
@@ -1490,19 +1492,15 @@
- box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
- label = "Vector map")
- boxSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
- boxSizer.Add(item = self.vectSellabel,
+ self.boxSizer.Add(item = self.vectSellabel,
proportion = 0)
- boxSizer.Add(item = self.vectSel, proportion = 1,
+ self.boxSizer.Add(item = self.vectSel, proportion = 1,
flag = wx.EXPAND | wx.ALL, border = 5)
- sizer.Add(item = boxSizer, proportion = 1,
+ sizer.Add(item = self.boxSizer, proportion = 1,
btnSizer = wx.StdDialogButtonSizer()
