[GRASS-SVN] r66520 - grass-addons/tools/addons
svn_grass at osgeo.org
Fri Oct 16 13:44:55 PDT 2015
Author: wenzeslaus
Date: 2015-10-16 13:44:55 -0700 (Fri, 16 Oct 2015)
New Revision: 66520
grass-addons/tools/addons/get_page_description.py
remove some HTML tags to not have them in addons index
Be also more strict about heading but ignore their case.
Modified: grass-addons/tools/addons/get_page_description.py
--- grass-addons/tools/addons/get_page_description.py 2015-10-16 20:08:21 UTC (rev 66519)
+++ grass-addons/tools/addons/get_page_description.py 2015-10-16 20:44:55 UTC (rev 66520)
@@ -33,6 +33,37 @@
return text.strip()
+def remove_unwanted_tags(text):
+ r"""Remove HTML selected tags from text
+ This is not an ideal example where the formatting is in fact wrong
+ but let's fix it and use it so it at least looks good.
+ >>> remove_unwanted_tags('module.name<br>\nDescription later')
+ 'module.name\nDescription later'
+ Links to details are not ideal for index page. Links to the same page
+ (the ones with #) would be even broken.
+ >>> remove_unwanted_tags('uses <a href="http://example.com">Famous</a> lib') # doctest: +NORMALIZE_WHITESPACE
+ 'uses Famous lib'
+ However we save some links:
+ >>> remove_unwanted_tags('abc <br> abc <em>abc</em>') # doctest: +NORMALIZE_WHITESPACE
+ 'abc abc <em>abc</em>'
+ # ? is for non-greedy to not go to last tag but end the current first
+ # new lines and paragraphs
+ text = re.sub(r'<br.?>', '', text, flags=re.IGNORECASE)
+ text = re.sub(r'<p.*?>', '', text, flags=re.IGNORECASE)
+ text = re.sub(r'</p>', '', text, flags=re.IGNORECASE)
+ # links and other anchors
+ text = re.sub(r'<a.*?>', '', text, flags=re.IGNORECASE)
+ text = re.sub(r'</a>', '', text, flags=re.IGNORECASE)
+ return text
def get_desc_from_desc_text(text):
r"""Get description defined as first sentence in the given text.
@@ -49,6 +80,7 @@
# this matches the sentence but gives also whole string even if it
# is not the sentence
text = re.split(r"\.(\s|$)", text, 1)[0]
+ text = remove_unwanted_tags(text)
# strip spaces at the beginning and add the tripped dot back
return text.lstrip() + '.'
@@ -60,10 +92,12 @@
in_desc_section = False
desc_section = ''
desc_section_num_lines = 0
- desc_block_start = re.compile(r'NAME')
+ desc_block_start = re.compile(r'<h2.*>NAME.*/h.>', flags=re.IGNORECASE)
# the incomplete manual pages have NAME followed by DESCRIPTION
- desc_block_end = re.compile(r'<h2.*>(KEYWORDS|DESCRIPTION).*/h.>')
- desc_section_start = re.compile(r'<h2.*>DESCRIPTION.*/h.>')
+ desc_block_end = re.compile(r'<h2.*>(KEYWORDS|DESCRIPTION).*/h.>',
+ flags=re.IGNORECASE)
+ desc_section_start = re.compile(r'<h2.*>DESCRIPTION.*/h.>',
desc_line = re.compile(r' - ')
comment_meta_desc_line = re.compile(r'<!-- meta page description:.*-->')
for line in page_file:
