[GRASS-SVN] r66530 - grass/trunk/temporal/t.register
svn_grass at osgeo.org
Mon Oct 19 13:09:10 PDT 2015
Author: neteler
Date: 2015-10-19 13:09:10 -0700 (Mon, 19 Oct 2015)
New Revision: 66530
grass/trunk/temporal/t.register/t.register.html
t.register manual: HTML cosmetics for r66524 (following https://trac.osgeo.org/grass/wiki/Submitting/Docs#HTMLPages)
Modified: grass/trunk/temporal/t.register/t.register.html
--- grass/trunk/temporal/t.register/t.register.html 2015-10-19 19:48:52 UTC (rev 66529)
+++ grass/trunk/temporal/t.register/t.register.html 2015-10-19 20:09:10 UTC (rev 66530)
@@ -25,22 +25,17 @@
list of maps at once. Maps can be registered in several space time
datasets using the same timestamp.
<p>
- The <i>increment</i> option and the <i>-i</i> flag (to create time intervals)
- work only in conjunction with the <i>start</i> option.
- If an input file with time stamps is used, then the <i>increment</i> option
- and the <i>-i</i> flag are not supported.
-</p>
+The <em>increment</em> option and the <b>-i</b> flag (to create time intervals)
+work only in conjunction with the <b>start</b> option.
+If an input file with time stamps is used, then the <em>increment</em> option
+and the <b>-i</b> flag are not supported.
<p>
Start time and end time with absolute time must be provided using the
format <b>yyyy-mm-dd HH:MM:SS +HHMM</b>. It is supported to specify
only the date <b>yyyy-mm-dd</b>. In case of relative time the temporal
unit (years, months, days, hours, minutes or seconds) must be provided.
The relative start time, end time and the increment are integers.
-<p>
-</p>
<h2>NOTES</h2>
The timestamps of registered maps will be stored in the temporal
@@ -56,7 +51,8 @@
The input file consists of a list of map names, optionally along with time stamps.
Each map name is to be stored in a row in this file.
<p>
-There are several options to register maps, <i>increment</i> option and the <i>-i</i> flag are supported:
+There are several options to register maps, <em>increment</em> option and
+the <b>-i</b> flag are supported:
<p>
Specification of map names:
<div class="code"><pre>
@@ -68,8 +64,8 @@
</pre></div>
<p>
-Specification of map names and the absolute start time (date) of the time instances,
-not support for <i>increment</i> option and the <i>-i</i> flag:
+Specification of map names and the absolute start time (date) of the time
+instances, not support for <em>increment</em> option and the <b>-i</b> flag:
terra_lst_day20020113|2002-01-13
terra_lst_day20020114|2002-01-14
@@ -80,7 +76,7 @@
<p>
Specification of map names and the absolute time stamp (datetime),
+not support for <em>increment</em> option and the <b>-i</b> flag:
terra_lst_day20020113|2002-01-13 10:30
terra_lst_day20020114|2002-01-14 10:30
@@ -91,7 +87,7 @@
<p>
Specification of the map name and the absolute time interval with start,
and end time:
prec_1|2001-01-01|2001-04-01
