[GRASS-SVN] r66551 - in grass/trunk/raster/r.univar: . testsuite
svn_grass at osgeo.org
Wed Oct 21 02:50:59 PDT 2015
Author: huhabla
Date: 2015-10-21 02:50:59 -0700 (Wed, 21 Oct 2015)
New Revision: 66551
Added:
grass/trunk/raster/r.univar/testsuite/
grass/trunk/raster/r.univar/testsuite/test_r_univar.py
grass/trunk/raster/r.univar/globals.h
grass/trunk/raster/r.univar/r.univar_main.c
Added raster region flag "-r" to use the native region
and resolution of a raster map, independent from the
current region settings. Added tests.
Modified: grass/trunk/raster/r.univar/globals.h
--- grass/trunk/raster/r.univar/globals.h 2015-10-20 22:14:56 UTC (rev 66550)
+++ grass/trunk/raster/r.univar/globals.h 2015-10-21 09:50:59 UTC (rev 66551)
@@ -56,7 +56,7 @@
typedef struct
struct Option *inputfile, *zonefile, *percentile, *output_file, *separator;
- struct Flag *shell_style, *extended, *table;
+ struct Flag *shell_style, *extended, *table, *use_rast_region;
} param_type;
extern param_type param;
Modified: grass/trunk/raster/r.univar/r.univar_main.c
--- grass/trunk/raster/r.univar/r.univar_main.c 2015-10-20 22:14:56 UTC (rev 66550)
+++ grass/trunk/raster/r.univar/r.univar_main.c 2015-10-21 09:50:59 UTC (rev 66551)
@@ -71,6 +71,10 @@
param.table->description = _("Table output format instead of standard output format");
param.table->guisection = _("Formatting");
+ param.use_rast_region = G_define_flag();
+ param.use_rast_region->key = 'r';
+ param.use_rast_region->description = _("Use the native resolution and extent of the raster map, instead of the current region");
return;
@@ -115,14 +119,16 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (param.zonefile->answer && param.use_rast_region->answer) {
+ G_fatal_error(_("zones option and region flag -r are mutually exclusive"));
name = param.output_file->answer;
if (name != NULL && strcmp(name, "-") != 0) {
if (NULL == freopen(name, "w", stdout)) {
G_fatal_error(_("Unable to open file <%s> for writing"), name);
- G_get_window(®ion);
/* table field separator */
zone_info.sep = G_option_to_separator(param.separator);
@@ -166,6 +172,18 @@
: 0);
for (p = param.inputfile->answers; *p; p++) {
+ /* Check if the native extent and resolution
+ of the input map should be used */
+ if(param.use_rast_region->answer) {
+ mapset = G_find_raster2(*p, "");
+ Rast_get_cellhd(*p, mapset, ®ion);
+ } else {
+ G_get_window(®ion);
+ /* Set the computational region */
+ Rast_set_window(®ion);
fd = open_raster(*p);
if (map_type != -1) {
@@ -255,7 +273,7 @@
const size_t value_sz = Rast_cell_size(map_type);
unsigned int row;
void *raster_row;
- CELL *zoneraster_row;
+ CELL *zoneraster_row = NULL;
int n_zones = zone_info.n_zones;
raster_row = Rast_allocate_buf(map_type);
@@ -264,7 +282,7 @@
for (row = 0; row < rows; row++) {
void *ptr;
- CELL *zptr;
+ CELL *zptr = NULL;
unsigned int col;
Rast_get_row(fd, raster_row, row, map_type);
Added: grass/trunk/raster/r.univar/testsuite/test_r_univar.py
--- grass/trunk/raster/r.univar/testsuite/test_r_univar.py (rev 0)
+++ grass/trunk/raster/r.univar/testsuite/test_r_univar.py 2015-10-21 09:50:59 UTC (rev 66551)
@@ -0,0 +1,142 @@
+"""Test of r.univar
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+class TestRasterUnivar(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Use temporary region settings"""
+ cls.use_temp_region()
+ @classmethod
+ def tearDownClass(cls):
+ """!Remove the temporary region
+ cls.del_temp_region()
+ def tearDown(self):
+ self.runModule("g.remove", type="raster", name="map_a")
+ self.runModule("g.remove", type="raster", name="map_b")
+ def setUp(self):
+ """Create input data
+ self.runModule("g.region", res=1, n=90, s=0, w=0, e=90)
+ self.runModule("r.mapcalc", expression="map_a = 100 + row() + col()",
+ overwrite=True)
+ self.runModule("r.mapcalc", expression="map_b = 200 + row() + col()",
+ overwrite=True)
+ def test_1(self):
+ # Output of r.univar
+ univar_string="""n=8100
+ null_cells=0
+ cells=8100
+ min=102
+ max=280
+ range=178
+ mean=191
+ mean_of_abs=191
+ sum=1547100"""
+ self.assertRasterFitsUnivar(raster="map_a", reference=univar_string,
+ precision=3)
+ def test_2(self):
+ null_cells=0
+ cells=81
+ min=112
+ max=272
+ range=160
+ mean=192
+ mean_of_abs=192
+ sum=15552"""
+ self.runModule("g.region", res=10)
+ precision=3)
+ def test_3(self):
+ Check the -r flag
+ :return:
+ null_cells=0
+ cells=8100
+ min=102
+ max=280
+ range=178
+ mean=191
+ mean_of_abs=191
+ sum=1547100"""
+ self.assertModuleKeyValue(module="r.univar", map="map_a", flags="rg",
+ reference=univar_string, precision=3, sep='=')
+ def test_multiple_1(self):
+ univar_string="""n=16200
+ null_cells=0
+ cells=16200
+ min=102
+ max=380
+ range=278
+ mean=241
+ mean_of_abs=241
+ sum=3904200"""
+ self.assertModuleKeyValue(module="r.univar", map=["map_a","map_b"], flags="rg",
+ def test_multiple_2(self):
+ null_cells=0
+ cells=162
+ min=112
+ max=372
+ range=260
+ mean=241
+ mean_of_abs=241
+ sum=39204"""
+ self.assertModuleKeyValue(module="r.univar", map=["map_a","map_b"], flags="g",
+ def test_multiple_3(self):
+ Check the -r flag
+ :return:
+ null_cells=0
+ cells=16200
+ min=102
+ max=380
+ range=278
+ mean=241
+ mean_of_abs=241
+ sum=3904200"""
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
