[GRASS-SVN] r66553 - in grass/trunk/lib/python/temporal: . testsuite
svn_grass at osgeo.org
Wed Oct 21 03:09:56 PDT 2015
Author: huhabla
Date: 2015-10-21 03:09:56 -0700 (Wed, 21 Oct 2015)
New Revision: 66553
grass/trunk/lib/python/temporal/c_libraries_interface.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py
temporal framework: Fixed several tests that were using wrong t.register calls
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-10-21 10:07:51 UTC (rev 66552)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-10-21 10:09:56 UTC (rev 66553)
@@ -1008,16 +1008,16 @@
True
>>> ciface.read_raster_info("test", tgis.get_current_mapset())
{'rows': 12, 'north': 80.0, 'min': 1, 'datatype': 'CELL', 'max': 1, 'ewres': 10.0, 'cols': 8, 'west': 0.0, 'east': 120.0, 'nsres': 10.0, 'south': 0.0}
- >>> info = ciface.read_raster_full_info("test", tgis.get_current_mapset())
+ >>> info = ciface.read_raster_full_info("test", tgis.get_current_mapset())
>>> info # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
- {u'tbres': 1.0, ... 'keyword': 'generated by r.mapcalc',
+ {u'tbres': 1.0, ... 'keyword': 'generated by r.mapcalc',
u'bottom': 0.0, 'end_time': None, 'title': 'test', u'south': 0.0}
>>> info["start_time"]
datetime.datetime(1995, 3, 12, 10, 34, 40)
>>> info["end_time"]
>>> check = ciface.has_raster_timestamp("test", tgis.get_current_mapset())
>>> print check
True
@@ -1084,7 +1084,7 @@
>>> kvp["start_time"]
>>> kvp["end_time"]
>>> check = ciface.has_vector_timestamp("test", tgis.get_current_mapset(), None)
>>> print check
True
@@ -1111,25 +1111,25 @@
>>> location = ciface.get_location()
>>> gisdbase = ciface.get_gisdbase()
- >>> ciface.fatal_error()
+ >>> ciface.fatal_error() # doctest: +ELLIPSIS, +NORMALIZE_WHITESPACE
- raise FatalError(message)
- FatalError: Fatal error
+ raise FatalError("Exception raised: " + str(e) + " Message: " + message)
+ FatalError: Exception raised: ...
>>> ciface.stop()
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py 2015-10-21 10:07:51 UTC (rev 66552)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py 2015-10-21 10:09:56 UTC (rev 66553)
@@ -56,7 +56,7 @@
tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1,d2,d3",
start="2001-01-03", increment="1 day", interval=True)
tgis.register_maps_in_space_time_dataset(type="raster", name=None, maps="singletmap",
- start="2001-01-03", end="2001-01-04", interval=True)
+ start="2001-01-03", end="2001-01-04")
def tearDown(self):
self.runModule("t.remove", inputs="R", quiet=True)
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py 2015-10-21 10:07:51 UTC (rev 66552)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py 2015-10-21 10:09:56 UTC (rev 66553)
@@ -62,7 +62,7 @@
tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d3",
start="2001-05-01", increment="31 days", interval=True)
def tearDown(self):
pass
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py 2015-10-21 10:07:51 UTC (rev 66552)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py 2015-10-21 10:09:56 UTC (rev 66553)
@@ -63,7 +63,7 @@
tgis.register_maps_in_space_time_dataset(type="raster", name="E", maps="e1,e2,e3",
start="2000-12-31", increment="2 day", interval=True)
def tearDown(self):
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py 2015-10-21 10:07:51 UTC (rev 66552)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py 2015-10-21 10:09:56 UTC (rev 66553)
@@ -55,7 +55,7 @@
def tearDown(self):
self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py 2015-10-21 10:07:51 UTC (rev 66552)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py 2015-10-21 10:09:56 UTC (rev 66553)
@@ -60,7 +60,7 @@
start="2001-05-01", increment="5 days", interval=True)
- start="2001-03-01", end="2001-04-01", interval=True)
+ start="2001-03-01", end="2001-04-01")
def tearDown(self):
return
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py 2015-10-21 10:07:51 UTC (rev 66552)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py 2015-10-21 10:09:56 UTC (rev 66553)
@@ -55,7 +55,7 @@
tgis.register_maps_in_space_time_dataset(type="vector", name="D", maps="d1,d2,d3",
tgis.register_maps_in_space_time_dataset(type="vector", name=None, maps="singletmap",
def tearDown(self):
self.runModule("t.remove", type="stvds", inputs="R", quiet=True)
