[GRASS-SVN] r66555 - in grass/trunk/temporal: t.list t.merge/testsuite t.rast.algebra/testsuite t.rast3d.list/testsuite t.vect.algebra/testsuite t.vect.list/testsuite
svn_grass at osgeo.org
Wed Oct 21 04:18:05 PDT 2015
Author: huhabla
Date: 2015-10-21 04:18:05 -0700 (Wed, 21 Oct 2015)
New Revision: 66555
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py
grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh
grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py
grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh
grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh
temporal modules: Fixed several wrong t.register calls in the module tests
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.list/t.list.py 2015-10-21 11:18:05 UTC (rev 66555)
@@ -99,6 +99,8 @@
tgis.init()
sp = tgis.dataset_factory(type, None)
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
first = True
if gscript.verbosity() > 0:
@@ -110,7 +112,7 @@
else:
time = "relative time"
- stds_list = tgis.get_dataset_list(type, ttype, columns, where, order)
+ stds_list = tgis.get_dataset_list(type, ttype, columns, where, order, dbif=dbif)
# Use the correct order of the mapsets, hence first the current mapset, then
# alphabetic ordering
@@ -155,6 +157,8 @@
print output
+ dbif.close()
if __name__ == "__main__":
options, flags = gscript.parser()
main()
Modified: grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh
--- grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.merge/testsuite/test.t.merge.sh 2015-10-21 11:18:05 UTC (rev 66555)
@@ -22,7 +22,7 @@
# in several space time datasets
t.create --o type=strds temporaltype=absolute output=precip_abs1 \
title="Test" descr="This is the 1 test strds" semantictype=sum
-t.register -i --o input=precip_abs1 maps=prec_1,prec_2,prec_3
+t.register --o input=precip_abs1 maps=prec_1,prec_2,prec_3
t.create --o type=strds temporaltype=absolute output=precip_abs2 \
title="Test" descr="This is the 2 test strds" semantictype=sum
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py 2015-10-21 11:18:05 UTC (rev 66555)
@@ -57,7 +57,7 @@
tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1,d2,d3",
start="2001-01-03", increment="1 day", interval=True)
tgis.register_maps_in_space_time_dataset(type="raster", name=None, maps="singletmap",
- start="2001-01-03", end="2001-01-04", interval=True)
+ start="2001-01-03", end="2001-01-04")
def tearDown(self):
self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py 2015-10-21 11:18:05 UTC (rev 66555)
@@ -62,7 +62,7 @@
tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d3",
start="2001-05-01", increment="5 days", interval=True)
- start="2001-03-01", end="2001-04-01", interval=True)
+ start="2001-03-01", end="2001-04-01")
def tearDown(self):
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py 2015-10-21 11:18:05 UTC (rev 66555)
@@ -33,9 +33,9 @@
title="A", descr="A", semantic="field", overwrite=True)
tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1",
- start="2001-02-01", end="2001-04-01", interval=True)
+ start="2001-02-01", end="2001-04-01")
tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a2",
- start="2001-03-01", end="2001-05-01", interval=True)
+ start="2001-03-01", end="2001-05-01")
@classmethod
def tearDownClass(cls):
Modified: grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh
--- grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.rast3d.list/testsuite/test.t.rast3d.list.sh 2015-10-21 11:18:05 UTC (rev 66555)
@@ -81,24 +81,24 @@
t.rast3d.list separator=" | " method=delta input=volume_abs1
t.rast3d.list separator=" | " method=deltagaps input=volume_abs1
-t.register -i type=raster_3d input=volume_abs2 file="${n2}"
+t.register type=raster_3d input=volume_abs2 file="${n2}"
t.rast3d.list separator=" | " method=comma input=volume_abs2
t.rast3d.list input=volume_abs2
t.rast3d.list separator=" | " method=cols input=volume_abs2
t.rast3d.list separator=" | " method=delta input=volume_abs2
t.rast3d.list separator=" | " method=deltagaps input=volume_abs2
-t.register -i type=raster_3d input=volume_abs3 file="${n3}"
+t.register type=raster_3d input=volume_abs3 file="${n3}"
t.rast3d.list separator=" | " method=comma input=volume_abs3
t.rast3d.list separator=" | " method=delta input=volume_abs3
t.rast3d.list separator=" | " method=deltagaps input=volume_abs3
-t.register -i type=raster_3d input=volume_abs4 file="${n4}"
+t.register type=raster_3d input=volume_abs4 file="${n4}"
t.rast3d.list separator=" | " method=comma input=volume_abs4
t.rast3d.list separator=" | " method=delta input=volume_abs4
t.rast3d.list separator=" | " method=deltagaps input=volume_abs4
-t.register -i type=raster_3d input=volume_abs5 file="${n5}"
+t.register type=raster_3d input=volume_abs5 file="${n5}"
t.rast3d.list separator=" | " method=comma input=volume_abs5
t.rast3d.list input=volume_abs5
t.rast3d.list separator=" | " method=cols input=volume_abs5
Modified: grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py
--- grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py 2015-10-21 11:18:05 UTC (rev 66555)
@@ -57,7 +57,7 @@
tgis.register_maps_in_space_time_dataset(type="vector", name="D", maps="d1,d2,d3",
tgis.register_maps_in_space_time_dataset(type="vector", name=None, maps="singletmap",
def tearDown(self):
self.runModule("t.remove", type="stvds", inputs="R", quiet=True)
Modified: grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh
--- grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh 2015-10-21 11:18:05 UTC (rev 66555)
@@ -87,31 +87,31 @@
t.create type=stvds temporaltype=absolute output=soils_abs5 title="A test with input files" descr="A test with input files"
# The first @test
-t.register type=vector input=soils_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=vector input=soils_abs1 file="${n1}" start="2001-01-01" increment="1 months"
t.vect.list separator=" | " method=comma input=soils_abs1
t.vect.list input=soils_abs1
t.vect.list separator=" | " method=cols input=soils_abs1
t.vect.list separator=" | " method=delta input=soils_abs1
t.vect.list separator=" | " method=deltagaps input=soils_abs1
-t.register type=vector -i input=soils_abs2 file="${n2}"
+t.register type=vector input=soils_abs2 file="${n2}"
t.vect.list separator=" | " method=comma input=soils_abs2
t.vect.list input=soils_abs2
t.vect.list separator=" | " method=cols input=soils_abs2
t.vect.list separator=" | " method=delta input=soils_abs2
t.vect.list separator=" | " method=deltagaps input=soils_abs2
-t.register type=vector -i input=soils_abs3 file="${n3}"
+t.register type=vector input=soils_abs3 file="${n3}"
t.vect.list separator=" | " method=comma input=soils_abs3
t.vect.list separator=" | " method=delta input=soils_abs3
t.vect.list separator=" | " method=deltagaps input=soils_abs3
-t.register type=vector -i input=soils_abs4 file="${n4}"
+t.register type=vector input=soils_abs4 file="${n4}"
t.vect.list separator=" | " method=comma input=soils_abs4
t.vect.list separator=" | " method=delta input=soils_abs4
t.vect.list separator=" | " method=deltagaps input=soils_abs4
-t.register type=vector -i input=soils_abs5 file="${n5}"
+t.register type=vector input=soils_abs5 file="${n5}"
t.vect.list separator=" | " method=comma input=soils_abs5
t.vect.list input=soils_abs5
t.vect.list separator=" | " method=cols input=soils_abs5
Modified: grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh
--- grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh 2015-10-21 10:16:50 UTC (rev 66554)
+++ grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh 2015-10-21 11:18:05 UTC (rev 66555)
@@ -73,31 +73,31 @@
t.create type=stvds temporaltype=absolute output=lidar_abs5 title="A test with input files" descr="A test with input files"
# The first @test
-t.register type=vector input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=vector input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
t.vect.list separator=" | " method=comma input=lidar_abs1
t.vect.list input=lidar_abs1
t.vect.list separator=" | " method=cols input=lidar_abs1
t.vect.list separator=" | " method=delta input=lidar_abs1
t.vect.list separator=" | " method=deltagaps input=lidar_abs1
-t.register type=vector -i input=lidar_abs2 file="${n2}"
+t.register type=vector input=lidar_abs2 file="${n2}"
t.vect.list separator=" | " method=comma input=lidar_abs2
t.vect.list input=lidar_abs2
t.vect.list separator=" | " method=cols input=lidar_abs2
t.vect.list separator=" | " method=delta input=lidar_abs2
t.vect.list separator=" | " method=deltagaps input=lidar_abs2
-t.register type=vector -i input=lidar_abs3 file="${n3}"
+t.register type=vector input=lidar_abs3 file="${n3}"
t.vect.list separator=" | " method=comma input=lidar_abs3
t.vect.list separator=" | " method=delta input=lidar_abs3
t.vect.list separator=" | " method=deltagaps input=lidar_abs3
-t.register type=vector -i input=lidar_abs4 file="${n4}"
+t.register type=vector input=lidar_abs4 file="${n4}"
t.vect.list separator=" | " method=comma input=lidar_abs4
t.vect.list separator=" | " method=delta input=lidar_abs4
t.vect.list separator=" | " method=deltagaps input=lidar_abs4
-t.register type=vector -i input=lidar_abs5 file="${n5}"
+t.register type=vector input=lidar_abs5 file="${n5}"
t.vect.list separator=" | " method=comma input=lidar_abs5
t.vect.list input=lidar_abs5
t.vect.list separator=" | " method=cols input=lidar_abs5
