[GRASS-SVN] r66559 - grass/trunk/lib/python/docs
svn_grass at osgeo.org
Wed Oct 21 06:15:14 PDT 2015
Author: neteler
Date: 2015-10-21 06:15:14 -0700 (Wed, 21 Oct 2015)
New Revision: 66559
grass/trunk/lib/python/docs/Makefile
grass/trunk/lib/python/docs/conf.py
sphinx Python lib docs: fix language definition for 'make libpythonlatexpdf'
Modified: grass/trunk/lib/python/docs/Makefile
--- grass/trunk/lib/python/docs/Makefile 2015-10-21 13:00:12 UTC (rev 66558)
+++ grass/trunk/lib/python/docs/Makefile 2015-10-21 13:15:14 UTC (rev 66559)
@@ -91,6 +91,8 @@
@echo
@echo "Build finished. The epub file is in $(BUILDDIR)/epub/"
+# requires:
+# texlive-titlesec texlive-framed texlive-threeparttable texlive-wrapfig texlive-upquote texlive-multirow
libpythonlatex:
@echo "SPHINXBUILD: Using <$(SPHINXBUILD)>"
$(call run_grass,$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex)
Modified: grass/trunk/lib/python/docs/conf.py
--- grass/trunk/lib/python/docs/conf.py 2015-10-21 13:00:12 UTC (rev 66558)
+++ grass/trunk/lib/python/docs/conf.py 2015-10-21 13:15:14 UTC (rev 66559)
@@ -95,7 +95,8 @@
# The language for content autogenerated by Sphinx. Refer to documentation
# for a list of supported languages.
-language = 'python'
+# http://sphinx-doc.org/config.html#options-for-internationalization
+language = 'en'
# There are two options for replacing |today|: either, you set today to some
# non-false value, then it is used:
@@ -234,7 +235,7 @@
# (source start file, target name, title,
# author, documentclass [howto, manual, or own class]).
latex_documents = [
- ('index', 'PythonLib.tex', u'Python Librart Documentation',
+ ('index', 'PythonLib.tex', u'Python Library Documentation',
u'GRASS Development Team', 'manual'),
