[GRASS-SVN] r66593 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Sat Oct 24 19:52:29 PDT 2015
Author: wenzeslaus
Date: 2015-10-24 19:52:29 -0700 (Sat, 24 Oct 2015)
New Revision: 66593
Added:
grass/trunk/raster/r.in.lidar/rast_segment.c
grass/trunk/raster/r.in.lidar/rast_segment.h
grass/trunk/raster/r.in.lidar/local_proto.h
grass/trunk/raster/r.in.lidar/main.c
grass/trunk/raster/r.in.lidar/support.c
r.in.lidar: separate code for base raster
But leaving the two options (row array and segment) in the main code.
Modified: grass/trunk/raster/r.in.lidar/local_proto.h
--- grass/trunk/raster/r.in.lidar/local_proto.h 2015-10-25 02:29:41 UTC (rev 66592)
+++ grass/trunk/raster/r.in.lidar/local_proto.h 2015-10-25 02:52:29 UTC (rev 66593)
@@ -52,5 +52,8 @@
int update_sum(void *, int, int, int, RASTER_MAP_TYPE, double);
int update_sumsq(void *, int, int, int, RASTER_MAP_TYPE, double);
+/* raster reading */
+int row_array_get_value_row_col(void *array, int arr_row, int arr_col,
+ int cols, RASTER_MAP_TYPE rtype, double *value);
#endif /* __LOCAL_PROTO_H__ */
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2015-10-25 02:29:41 UTC (rev 66592)
+++ grass/trunk/raster/r.in.lidar/main.c 2015-10-25 02:52:29 UTC (rev 66593)
@@ -28,7 +28,9 @@
#include <grass/gprojects.h>
#include <grass/glocale.h>
#include <liblas/capi/liblas.h>
#include "local_proto.h"
+#include "rast_segment.h"
struct node
@@ -671,36 +673,21 @@
use_base_raster_res = 1;
if (base_raster_opt->answer && (res_opt->answer || use_base_raster_res))
use_segment = 1;
- if (base_raster_opt->answer) {
+ if (base_raster_opt->answer && !use_segment) {
+ /* TODO: do we need to test existence first? mapset? */
+ base_raster = Rast_open_old(base_raster_opt->answer, "");
+ base_raster_data_type = Rast_get_map_type(base_raster);
+ base_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(base_raster_data_type));
+ if (base_raster_opt->answer && use_segment) {
if (use_base_raster_res) {
/* TODO: how to get cellhd already stored in the open map? */
Rast_get_cellhd(base_raster_opt->answer, "", &input_region);
/* TODO: make it only as small as the output is or points are */
Rast_set_input_window(&input_region); /* we have split window */
- /* TODO: do we need to test existence first? mapset? */
- base_raster = Rast_open_old(base_raster_opt->answer, "");
- base_raster_data_type = Rast_get_map_type(base_raster);
+ rast_segment_open(&base_segment, base_raster_opt->answer, &base_raster_data_type);
- if (base_raster_opt->answer && use_segment) {
- if (!use_base_raster_res)
- Rast_get_input_window(&input_region); /* we have split window */
- /* TODO: these numbers does not fit with what we promise about percentage */
- int segment_rows = 64;
- /* writing goes row by row, so we use long segments as well */
- int segment_cols = cols;
- int segments_in_memory = 4;
- if (Segment_open(&base_segment, G_tempfile(), input_region.rows, input_region.cols,
- segment_rows, segment_cols,
- Rast_cell_size(base_raster_data_type), segments_in_memory) != 1)
- G_fatal_error(_("Cannot create temporary file with segments of a raster map"));
- for (row = 0; row < input_region.rows; row++) {
- raster_row = Rast_allocate_input_buf(base_raster_data_type);
- Rast_get_row(base_raster, raster_row, row, base_raster_data_type);
- Segment_put_row(&base_segment, raster_row, row);
- Rast_close(base_raster); /* we won't need the raster again */
if (!scan_flag->answer) {
/* check if rows * (cols + 1) go into a size_t */
@@ -726,9 +713,6 @@
if (bin_index)
index_array =
G_calloc((size_t)rows * (cols + 1), Rast_cell_size(CELL_TYPE));
- if (base_raster_opt->answer && !use_segment)
- base_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(base_raster_data_type));
- /* we don't free the raster, we just use it again */
/* TODO: perhaps none of them needs to be freed */
/* and then free it again */
@@ -909,61 +893,22 @@
arr_col = (int)((x - region.west) / region.ew_res);
if (base_array) {
- ptr = base_array;
- ptr =
- G_incr_void_ptr(ptr,
- ((arr_row * cols) +
- arr_col) * Rast_cell_size(base_raster_data_type));
double base_z;
- if (Rast_is_null_value(ptr, base_raster_data_type)) {
+ if (row_array_get_value_row_col(base_array, arr_row, arr_col,
+ cols, base_raster_data_type,
+ &base_z))
+ z -= base_z;
+ else
continue;
- else {
- if (base_raster_data_type == DCELL_TYPE)
- base_z = *(DCELL *) ptr;
- else if (base_raster_data_type == FCELL_TYPE)
- base_z = (double) *(FCELL *) ptr;
- else
- base_z = (double) *(CELL *) ptr;
- z -= base_z;
else if (use_segment) {
double base_z;
- /* Rast gives double, Segment needs off_t */
- off_t base_row = Rast_northing_to_row(y, &input_region);
- off_t base_col = Rast_easting_to_col(x, &input_region);
- /* skip points which are outside the base raster
- * (null propagation) */
- if (base_row < 0 || base_col < 0 ||
- base_row >= input_region.rows ||
- base_col >= input_region.cols)
+ if (rast_segment_get_value_xy(&base_segment, &input_region,
+ base_raster_data_type, x, y,
+ &base_z))
+ z -= base_z;
+ else
continue;
- if (base_raster_data_type == DCELL_TYPE) {
- DCELL value;
- Segment_get(&base_segment, &value, base_row, base_col);
- if (Rast_is_null_value(&value, base_raster_data_type))
- continue;
- base_z = value;
- else if (base_raster_data_type == FCELL_TYPE) {
- FCELL value;
- continue;
- base_z = value;
- else {
- CELL value;
- continue;
- base_z = value;
- z -= base_z;
if (zrange_opt->answer) {
Added: grass/trunk/raster/r.in.lidar/rast_segment.c
--- grass/trunk/raster/r.in.lidar/rast_segment.c (rev 0)
+++ grass/trunk/raster/r.in.lidar/rast_segment.c 2015-10-25 02:52:29 UTC (rev 66593)
@@ -0,0 +1,86 @@
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/raster.h>
+#include <grass/segment.h>
+static void rast_segment_load(SEGMENT * segment, int rowio,
+ RASTER_MAP_TYPE map_type)
+ void *raster_row = Rast_allocate_input_buf(map_type);
+ int row;
+ for (row = 0; row < Rast_input_window_rows(); row++) {
+ /* TODO: free mem */
+ Rast_get_row(rowio, raster_row, row, map_type);
+ Segment_put_row(segment, raster_row, row);
+/* TODO: close function */
+void rast_segment_open(SEGMENT * segment, const char *name,
+ RASTER_MAP_TYPE * map_type)
+ /* TODO: check if not passing the mapset is OK */
+ int rowio = Rast_open_old(name, "");
+ *map_type = Rast_get_map_type(rowio);
+ int segment_rows = 64;
+ /* we use long segments because this is how the values a binned */
+ int segment_cols = Rast_input_window_cols();
+ int segments_in_memory = 4;
+ if (Segment_open(segment, G_tempfile(), Rast_input_window_rows(),
+ Rast_input_window_cols(), segment_rows, segment_cols,
+ Rast_cell_size(*map_type), segments_in_memory) != 1)
+ G_fatal_error(_("Cannot create temporary file with segments of a raster map"));
+ rast_segment_load(segment, rowio, *map_type);
+ Rast_close(rowio); /* we won't need the raster again */
+/* 0 on out of region or NULL, 1 on success */
+int rast_segment_get_value_xy(SEGMENT * base_segment,
+ struct Cell_head *input_region,
+ RASTER_MAP_TYPE rtype, double x, double y,
+ double *value)
+ /* Rast gives double, Segment needs off_t */
+ off_t base_row = Rast_northing_to_row(y, input_region);
+ off_t base_col = Rast_easting_to_col(x, input_region);
+ /* skip points which are outside the base raster
+ * (null propagation) */
+ if (base_row < 0 || base_col < 0 ||
+ base_row >= input_region->rows || base_col >= input_region->cols)
+ return 0;
+ if (rtype == DCELL_TYPE) {
+ DCELL tmp;
+ Segment_get(base_segment, &tmp, base_row, base_col);
+ if (Rast_is_d_null_value(&tmp))
+ return 0;
+ *value = (double)tmp;
+ else if (rtype == FCELL_TYPE) {
+ FCELL tmp;
+ if (Rast_is_f_null_value(&tmp))
+ return 0;
+ else {
+ CELL tmp;
+ if (Rast_is_c_null_value(&tmp))
+ return 0;
+ return 1;
Property changes on: grass/trunk/raster/r.in.lidar/rast_segment.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
Added: grass/trunk/raster/r.in.lidar/rast_segment.h
--- grass/trunk/raster/r.in.lidar/rast_segment.h (rev 0)
+++ grass/trunk/raster/r.in.lidar/rast_segment.h 2015-10-25 02:52:29 UTC (rev 66593)
@@ -0,0 +1,14 @@
+#ifndef GRASS_RAST_SEGMENT_H
+#define GRASS_RAST_SEGMENT_H
+ RASTER_MAP_TYPE * map_type);
+ double *value);
+#endif /* GRASS_RAST_SEGMENT_H */
Property changes on: grass/trunk/raster/r.in.lidar/rast_segment.h
+ text/x-chdr
+ native
Modified: grass/trunk/raster/r.in.lidar/support.c
--- grass/trunk/raster/r.in.lidar/support.c 2015-10-25 02:29:41 UTC (rev 66592)
+++ grass/trunk/raster/r.in.lidar/support.c 2015-10-25 02:52:29 UTC (rev 66593)
@@ -128,3 +128,23 @@
return 0;
+/* 0 on NULL, 1 on success */
+ void *ptr = array;
+ ptr =
+ G_incr_void_ptr(ptr,
+ ((arr_row * cols) +
+ arr_col) * Rast_cell_size(rtype));
+ if (Rast_is_null_value(ptr, rtype))
+ return 0;
+ *value = (double) *(DCELL *) ptr;
+ *value = (double) *(FCELL *) ptr;
+ else
+ *value = (double) *(CELL *) ptr;
+ return 1;
