[GRASS-SVN] r66596 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Sat Oct 24 20:55:49 PDT 2015
Author: wenzeslaus
Date: 2015-10-24 20:55:49 -0700 (Sat, 24 Oct 2015)
New Revision: 66596
Added:
grass/trunk/raster/r.in.lidar/filters.c
grass/trunk/raster/r.in.lidar/filters.h
grass/trunk/raster/r.in.lidar/local_proto.h
grass/trunk/raster/r.in.lidar/main.c
r.in.lidar: separate class and return filters
Added: grass/trunk/raster/r.in.lidar/filters.c
--- grass/trunk/raster/r.in.lidar/filters.c (rev 0)
+++ grass/trunk/raster/r.in.lidar/filters.c 2015-10-25 03:55:49 UTC (rev 66596)
@@ -0,0 +1,70 @@
+ * r.in.lidar filtering functions
+ * Copyright 2011-2015 by Markus Metz, and The GRASS Development Team
+ * Authors:
+ * Markus Metz (r.in.lidar)
+ * Vaclav Petras (move code to a separate files)
+ * This program is free software licensed under the GPL (>=v2).
+ * Read the COPYING file that comes with GRASS for details.
+#include "local_proto.h"
+#include "filters.h"
+#include <stdlib.h>
+#include <grass/gis.h>
+int return_filter_is_out(struct ReturnFilter *return_filter, int return_n,
+ int n_returns)
+ if (return_filter->filter == LAS_ALL)
+ return FALSE;
+ int skipme = 1;
+ switch (return_filter->filter) {
+ case LAS_FIRST:
+ if (return_n == 1)
+ skipme = 0;
+ break;
+ case LAS_MID:
+ if (return_n > 1 && return_n < n_returns)
+ skipme = 0;
+ break;
+ case LAS_LAST:
+ if (n_returns > 1 && return_n == n_returns)
+ skipme = 0;
+ break;
+ if (skipme)
+ return TRUE;
+ return FALSE;
+void class_filter_create_from_strings(struct ClassFilter *class_filter,
+ char **classes)
+ class_filter->str_classes = classes;
+int class_filter_is_out(struct ClassFilter *class_filter, int class_n)
+ if (!class_filter->str_classes)
+ return FALSE;
+ int i = 0;
+ int skipme = TRUE;
+ while (class_filter->str_classes[i]) {
+ if (class_n == atoi(class_filter->str_classes[i])) {
+ skipme = FALSE;
+ break;
+ i++;
+ if (skipme)
+ return TRUE;
+ return FALSE;
Property changes on: grass/trunk/raster/r.in.lidar/filters.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
Added: grass/trunk/raster/r.in.lidar/filters.h
--- grass/trunk/raster/r.in.lidar/filters.h (rev 0)
+++ grass/trunk/raster/r.in.lidar/filters.h 2015-10-25 03:55:49 UTC (rev 66596)
@@ -0,0 +1,35 @@
+ * Authors:
+#ifndef __FILTERS_H__
+#define __FILTERS_H__
+struct ReturnFilter
+ int filter;
+struct ClassFilter
+ /** NULL terminated list of class numbers represented as string */
+ char **str_classes;
+ int n_returns);
+ char **classes);
+int class_filter_is_out(struct ClassFilter *class_filter, int class_n);
+#endif /* __FILTERS_H__ */
Property changes on: grass/trunk/raster/r.in.lidar/filters.h
+ text/x-chdr
+ native
Modified: grass/trunk/raster/r.in.lidar/local_proto.h
--- grass/trunk/raster/r.in.lidar/local_proto.h 2015-10-25 03:42:35 UTC (rev 66595)
+++ grass/trunk/raster/r.in.lidar/local_proto.h 2015-10-25 03:55:49 UTC (rev 66596)
@@ -41,6 +41,12 @@
#define METHOD_SKEWNESS 12
#define METHOD_TRIMMEAN 13
+#define LAS_ALL 0
+#define LAS_FIRST 1
+#define LAS_LAST 2
+#define LAS_MID 3
/* info.c */
void print_lasinfo(LASHeaderH, LASSRSH);
int scan_bounds(LASReaderH, int, int, double, struct Cell_head *);
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2015-10-25 03:42:35 UTC (rev 66595)
+++ grass/trunk/raster/r.in.lidar/main.c 2015-10-25 03:55:49 UTC (rev 66596)
@@ -33,11 +33,8 @@
#include "rast_segment.h"
#include "point_binning.h"
-#define LAS_ALL 0
-#define LAS_FIRST 1
-#define LAS_LAST 2
-#define LAS_MID 3
int main(int argc, char *argv[])
@@ -67,7 +64,6 @@
double pass_north, pass_south;
int arr_row, arr_col;
unsigned long count, count_total;
- int skipme, i;
int point_class;
double zscale = 1.0;
@@ -298,6 +294,10 @@
else
G_fatal_error(_("Unknown filter option <%s>"), filter_opt->answer);
+ struct ReturnFilter return_filter_struct;
+ return_filter_struct.filter = return_filter;
+ struct ClassFilter class_filter;
+ class_filter_create_from_strings(&class_filter, class_opt->answers);
/* Fetch input map projection in GRASS form. */
projstr = LASSRS_GetWKT_CompoundOK(LAS_srs);
@@ -498,47 +498,16 @@
else
z = LASPoint_GetZ(LAS_point);
- if (return_filter != LAS_ALL) {
- int return_no = LASPoint_GetReturnNumber(LAS_point);
- int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
- skipme = 1;
+ int return_n = LASPoint_GetReturnNumber(LAS_point);
+ int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
+ if (return_filter_is_out(&return_filter_struct, return_n, n_returns)) {
+ n_filtered++;
+ continue;
+ point_class = (int) LASPoint_GetClassification(LAS_point);
+ if (class_filter_is_out(&class_filter, point_class))
+ continue;
- switch (return_filter) {
- case LAS_FIRST:
- if (return_no == 1)
- skipme = 0;
- break;
- case LAS_MID:
- if (return_no > 1 && return_no < n_returns)
- skipme = 0;
- break;
- case LAS_LAST:
- if (n_returns > 1 && return_no == n_returns)
- skipme = 0;
- break;
- if (skipme) {
- n_filtered++;
- continue;
- if (class_opt->answer) {
- point_class = (int) LASPoint_GetClassification(LAS_point);
- i = 0;
- skipme = TRUE;
- while (class_opt->answers[i]) {
- if (point_class == atoi(class_opt->answers[i])) {
- skipme = FALSE;
- break;
- i++;
- if (skipme) {
- continue;
if (y <= pass_south || y > pass_north) {
continue;
