[GRASS-SVN] r66600 - grass-addons/grass7/imagery/i.spec.sam
svn_grass at osgeo.org
Sun Oct 25 10:51:25 PDT 2015
Author: ychemin
Date: 2015-10-25 10:51:25 -0700 (Sun, 25 Oct 2015)
New Revision: 66600
grass-addons/grass7/imagery/i.spec.sam/main.c
replaced v_output()
Modified: grass-addons/grass7/imagery/i.spec.sam/main.c
--- grass-addons/grass7/imagery/i.spec.sam/main.c 2015-10-25 10:02:36 UTC (rev 66599)
+++ grass-addons/grass7/imagery/i.spec.sam/main.c 2015-10-25 17:51:25 UTC (rev 66600)
@@ -59,7 +59,7 @@
int row, col;
int band;
int i, j, error=0;
- vec_struct *svd_values;
+ vec_struct *svd_values; /*la.h defines vec_struct as a typedef mat_struct*/
/*char command[80]; rm by Yann temporarily see grayscale palette*/
float anglefield[255][255];
struct
@@ -152,9 +152,11 @@
G_message("Singular values of Matrix A:");
G_math_svdval( (double *) svd_values->vals, (double **) A->vals, A->cols, A->rows);
- v_output(svd_values);
if (error)
G_fatal_error("Error in singular value decomposition, exiting...\n");
+ /*Experimental: display values (replace v_output() in original version)*/
+ for(i=0;i<svd_values->ldim;i++)
+ G_message("%f", svd_values->vals[i]);
/* alright, start Spectral angle mapping */
nrows = Rast_window_rows();
