[GRASS-SVN] r66602 - in grass/trunk/raster/r.univar: . testsuite
svn_grass at osgeo.org
Mon Oct 26 04:51:23 PDT 2015
Author: huhabla
Date: 2015-10-26 04:51:23 -0700 (Mon, 26 Oct 2015)
New Revision: 66602
grass/trunk/raster/r.univar/r.univar_main.c
grass/trunk/raster/r.univar/stats.c
grass/trunk/raster/r.univar/testsuite/test_r_univar.py
Fixed zone map region bug, introduced with the -r
flag for map specific regions.
Modified the output of the -g flag in case of zones. Now the shell
style is consistent. Instead of "\nzone num cat\n\n" -> "zone=num;cat"
is printed to stdout.
Modified: grass/trunk/raster/r.univar/r.univar_main.c
--- grass/trunk/raster/r.univar/r.univar_main.c 2015-10-26 04:18:55 UTC (rev 66601)
+++ grass/trunk/raster/r.univar/r.univar_main.c 2015-10-26 11:51:23 UTC (rev 66602)
@@ -178,11 +178,11 @@
if(param.use_rast_region->answer) {
mapset = G_find_raster2(*p, "");
Rast_get_cellhd(*p, mapset, ®ion);
+ /* Set the computational region */
+ Rast_set_window(®ion);
} else {
G_get_window(®ion);
- /* Set the computational region */
- Rast_set_window(®ion);
fd = open_raster(*p);
Modified: grass/trunk/raster/r.univar/stats.c
--- grass/trunk/raster/r.univar/stats.c 2015-10-26 04:18:55 UTC (rev 66601)
+++ grass/trunk/raster/r.univar/stats.c 2015-10-26 11:51:23 UTC (rev 66602)
@@ -134,19 +134,22 @@
sprintf(sum_str, "%.15g", stats[z].sum);
G_trim_decimal(sum_str);
- if (zone_info.n_zones) {
- int z_cat = z + zone_info.min;
- fprintf(stdout, "\nzone %d %s\n\n", z_cat, Rast_get_c_cat(&z_cat, &(zone_info.cats)));
if (!param.shell_style->answer) {
+ if (zone_info.n_zones) {
+ int z_cat = z + zone_info.min;
+ fprintf(stdout, "\nzone %d %s\n\n", z_cat, Rast_get_c_cat(&z_cat, &(zone_info.cats)));
fprintf(stdout, "total null and non-null cells: %lu\n", stats[z].size);
fprintf(stdout, "total null cells: %lu\n\n", stats[z].size - stats[z].n);
fprintf(stdout, "Of the non-null cells:\n----------------------\n");
if (param.shell_style->answer) {
+ fprintf(stdout, "zone=%d;%s\n", z_cat, Rast_get_c_cat(&z_cat, &(zone_info.cats)));
fprintf(stdout, "n=%lu\n", stats[z].n);
fprintf(stdout, "null_cells=%lu\n", stats[z].size - stats[z].n);
fprintf(stdout, "cells=%lu\n", stats->size);
Modified: grass/trunk/raster/r.univar/testsuite/test_r_univar.py
--- grass/trunk/raster/r.univar/testsuite/test_r_univar.py 2015-10-26 04:18:55 UTC (rev 66601)
+++ grass/trunk/raster/r.univar/testsuite/test_r_univar.py 2015-10-26 11:51:23 UTC (rev 66602)
@@ -18,8 +18,10 @@
cls.del_temp_region()
def tearDown(self):
+ pass
self.runModule("g.remove", type="raster", name="map_a")
self.runModule("g.remove", type="raster", name="map_b")
+ self.runModule("g.remove", type="raster", name="zone_map")
def setUp(self):
"""Create input data
@@ -29,6 +31,8 @@
overwrite=True)
self.runModule("r.mapcalc", expression="map_b = 200 + row() + col()",
overwrite=True)
+ self.runModule("r.mapcalc", expression="zone_map = if(row() < 20, 1,2)",
+ overwrite=True)
def test_1(self):
# Output of r.univar
@@ -135,6 +139,40 @@
self.assertModuleKeyValue(module="r.univar", map=["map_a","map_b"], flags="rg",
reference=univar_string, precision=3, sep='=')
+ def test_1_zone(self):
+ multiple maps and zone
+ :return:
+ # Output of r.univar
+ univar_string="""zone=1;
+ n=1710
+ null_cells=0
+ cells=1710
+ min=102
+ max=209
+ range=107
+ mean=155.5
+ mean_of_abs=155.5
+ sum=265905
+ zone=2;
+ n=6390
+ null_cells=0
+ cells=1710
+ min=121
+ max=280
+ range=159
+ mean=200.5
+ mean_of_abs=200.5
+ sum=1281195"""
+ self.runModule("g.region", res=1)
+ self.assertModuleKeyValue(module="r.univar", map=["map_a"],
+ zones="zone_map",flags="g",
+ reference=univar_string, precision=3, sep='=')
class TestAccumulateFails(TestCase):
def test_error_handling(self):
