[GRASS-SVN] r66616 - in grass/branches/releasebranch_6_4: db/drivers/dbf db/drivers/ogr db/drivers/postgres imagery/i.landsat.toar imagery/i.rectify raster/r.flow raster/r.in.gdal raster/r.in.xyz raster/r.profile raster/r.quant raster/r.random.surface raster/r.reclass raster/r.to.vect raster3d/r3.out.v5d vector/v.in.ascii vector/v.in.ogr vector/v.net.allpairs vector/v.net.centrality vector/v.net.components vector/v.net.distance vector/v.net.flow vector/v.net.path vector/v.net.timetable vector/v.overlay vector/v.surf.rst vector/v.vol.rst
Tue Oct 27 06:58:52 PDT 2015
Author: neteler
Date: 2015-10-27 06:58:52 -0700 (Tue, 27 Oct 2015)
New Revision: 66616
   grass/branches/releasebranch_6_4/db/drivers/dbf/column.c
   grass/branches/releasebranch_6_4/db/drivers/ogr/select.c
   grass/branches/releasebranch_6_4/db/drivers/postgres/db.c
   grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c
   grass/branches/releasebranch_6_4/imagery/i.rectify/cp.c
   grass/branches/releasebranch_6_4/imagery/i.rectify/target.c
   grass/branches/releasebranch_6_4/raster/r.flow/mem.h
   grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c
   grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c
   grass/branches/releasebranch_6_4/raster/r.profile/main.c
   grass/branches/releasebranch_6_4/raster/r.quant/read_rules.c
   grass/branches/releasebranch_6_4/raster/r.random.surface/init.c
   grass/branches/releasebranch_6_4/raster/r.reclass/main.c
   grass/branches/releasebranch_6_4/raster/r.to.vect/main.c
   grass/branches/releasebranch_6_4/raster/r.to.vect/util.c
   grass/branches/releasebranch_6_4/raster3d/r3.out.v5d/main.c
   grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c
   grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
   grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c
   grass/branches/releasebranch_6_4/vector/v.net.centrality/main.c
   grass/branches/releasebranch_6_4/vector/v.net.components/main.c
   grass/branches/releasebranch_6_4/vector/v.net.distance/main.c
   grass/branches/releasebranch_6_4/vector/v.net.flow/main.c
   grass/branches/releasebranch_6_4/vector/v.net.path/path.c
   grass/branches/releasebranch_6_4/vector/v.net.timetable/main.c
   grass/branches/releasebranch_6_4/vector/v.overlay/area_area.c
   grass/branches/releasebranch_6_4/vector/v.overlay/line_area.c
   grass/branches/releasebranch_6_4/vector/v.overlay/main.c
   grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
   grass/branches/releasebranch_6_4/vector/v.vol.rst/main.c
   grass/branches/releasebranch_6_4/vector/v.vol.rst/vector.c
fixes for fail to compile with -Werror=format-security (#2773) (partial backport from trunk, r66614)
Modified: grass/branches/releasebranch_6_4/db/drivers/dbf/column.c
--- grass/branches/releasebranch_6_4/db/drivers/dbf/column.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/db/drivers/dbf/column.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -39,7 +39,7 @@
 	sprintf(buf, "DBMI-DBF driver: column name '%s'", name);
 	name[DBF_COL_NAME - 1] = '\0';
 	sprintf(buf + strlen(buf), " truncated to '%s'", name);
-	G_warning(buf);
+	G_warning("%s", buf);
     /* Check if the column exists */
Modified: grass/branches/releasebranch_6_4/db/drivers/ogr/select.c
--- grass/branches/releasebranch_6_4/db/drivers/ogr/select.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/db/drivers/ogr/select.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -39,7 +39,7 @@
     if (c->hLayer == NULL) {
 	append_error("Cannot select: \n");
-	append_error(db_get_string(sel));
+	append_error("%s", db_get_string(sel));
 	append_error("\n");
 	report_error();
 	return DB_FAILED;
Modified: grass/branches/releasebranch_6_4/db/drivers/postgres/db.c
--- grass/branches/releasebranch_6_4/db/drivers/postgres/db.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/db/drivers/postgres/db.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -23,7 +23,7 @@
 	name = connection.databaseName;
     G_debug(3,
-	    "db_driver_open_database() driver=pg database definition = '%s'",
+	    "db_driver_open_database(): driver=pg database definition = '%s'",
 	    name);
     if (parse_conn(name, &pgconn) == DB_FAILED) {
Modified: grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c
--- grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/imagery/i.landsat.toar/landsat_met.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -384,14 +384,14 @@
 	    sprintf(key, "Band%dGainSetting", lsat->band[i].code);
 	    get_mtldata(mtldata, key, value);
 	    if (value[0] == '\0') {
-		G_warning(key);
+                G_warning("%s", key);
 		continue;
 	    lsat->band[i].gain = atof(value);
 	    sprintf(key, "Band%dBiasSetting", lsat->band[i].code);
-		G_warning(key);
 		continue;
 	    lsat->band[i].bias = atof(value);
Modified: grass/branches/releasebranch_6_4/imagery/i.rectify/cp.c
--- grass/branches/releasebranch_6_4/imagery/i.rectify/cp.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/imagery/i.rectify/cp.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -40,7 +40,7 @@
 	return 1;
-    G_fatal_error(msg);
+    G_fatal_error("%s", msg);
     return 0; /* G_fatal_error() calls exit() */
Modified: grass/branches/releasebranch_6_4/imagery/i.rectify/target.c
--- grass/branches/releasebranch_6_4/imagery/i.rectify/target.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/imagery/i.rectify/target.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -34,6 +34,6 @@
   error:
     strcat(buf, _("Please run i.target for group."));
     strcat(buf, group);
-    G_fatal_error(buf);
+    G_fatal_error("%s", buf);
     return 1;			/* never reached */
Modified: grass/branches/releasebranch_6_4/raster/r.flow/mem.h
--- grass/branches/releasebranch_6_4/raster/r.flow/mem.h	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.flow/mem.h	2015-10-27 13:58:52 UTC (rev 66616)
@@ -37,7 +37,7 @@
 		   segment_get_row(l.seg, l.buf[row] - l.col_offset, \
 				          row + l.row_offset) < 1)) ? \
 	(sprintf(string, "r.flow: cannot write segment file for %s", l.name),\
-	 G_fatal_error(string), (DCELL *) NULL) : \
+	 G_fatal_error("%s", string), (DCELL *) NULL) :                  \
 	l.buf[row])
 /*   This was is Astley's version 12...
Modified: grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.in.gdal/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -688,7 +688,7 @@
 		target_mapset, pszDstLoc);
 	strcat(errbuf, permissions == 0 ? _("permission denied")
 	       : _("not found"));
-	G_fatal_error(errbuf);
+	G_fatal_error("%s", errbuf);
     }				/* permission check */
     /* And switch back to original location */
Modified: grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c
--- grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.in.xyz/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -1059,7 +1059,7 @@
     sprintf(buff, _("%lu points found in region."), count_total);
-    G_done_msg(buff);
+    G_done_msg("%s", buff);
     G_debug(1, "Processed %lu lines.", line);
     exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_6_4/raster/r.profile/main.c
--- grass/branches/releasebranch_6_4/raster/r.profile/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.profile/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -181,7 +181,7 @@
 	sprintf(formatbuff, _("[Along Track Dist.(m)] [Elevation]"));
     if (clr)
 	strcat(formatbuff, _(" [RGB Color]"));
-    G_message(formatbuff);
+    G_message("%s", formatbuff);
     /* Get Profile Start Coords */
     if (!parm.profile->answer && !parm.i->answer) {
Modified: grass/branches/releasebranch_6_4/raster/r.quant/read_rules.c
--- grass/branches/releasebranch_6_4/raster/r.quant/read_rules.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.quant/read_rules.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -19,13 +19,13 @@
     for (i = 0; i < noi; i++) {
 	if (G_read_fp_range(name[i], mapset[i], &drange) <= 0) {
 	    sprintf(buff, "Can't read f_range for map %s", name[i]);
-	    G_fatal_error(buff);
+	    G_fatal_error("%s", buff);
 	G_get_fp_range_min_max(&drange, &tmp_dmin, &tmp_dmax);
 	if (G_read_range(name[i], mapset[i], &range) <= 0) {
 	    sprintf(buff, "Can't read range for map %s", name[i]);
 	G_get_range_min_max(&range, &tmp_min, &tmp_max);
 	if (!i || tmp_max > old_max || G_is_c_null_value(&old_max))
Modified: grass/branches/releasebranch_6_4/raster/r.random.surface/init.c
--- grass/branches/releasebranch_6_4/raster/r.random.surface/init.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.random.surface/init.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -207,7 +207,7 @@
 		Seeds[i] = Seeds[i] % SEED_MAX;
 		sprintf(msg2, _(" seed is set to %d"), Seeds[i]);
 		strcat(msg, msg2);
-		G_warning(msg);
+		G_warning("%s", msg);
 	    else if (Seeds[i] < SEED_MIN) {
 		sprintf(msg, _("Seed (%d) smaller than minimum (%d)"),
@@ -216,7 +216,7 @@
 		    Seeds[i] += SEED_MAX - SEED_MIN;
 		strcat(msg, msg2);
-		G_warning(msg);
 	}			/* /for */
     }				/* /else */
Modified: grass/branches/releasebranch_6_4/raster/r.reclass/main.c
--- grass/branches/releasebranch_6_4/raster/r.reclass/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.reclass/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -124,7 +124,7 @@
 	    else {
 		strcat(buf, _(" - invalid reclass rule"));
 	    break;
Modified: grass/branches/releasebranch_6_4/raster/r.to.vect/main.c
--- grass/branches/releasebranch_6_4/raster/r.to.vect/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.to.vect/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -189,7 +189,7 @@
 	db_append_string(&sql, ")");
-	G_debug(3, db_get_string(&sql));
+	G_debug(3, "%s", db_get_string(&sql));
 	if (db_execute_immediate(driver, &sql) != DB_OK)
 	    G_fatal_error(_("Unable to create table: %s"),
@@ -268,7 +268,7 @@
 		sprintf(buf, "insert into %s values ( %d, '%s')", Fi->table,
 			cat, db_get_string(&label));
 		db_set_string(&sql, buf);
 		    G_fatal_error(_("Unable to insert into table: %s"),
Modified: grass/branches/releasebranch_6_4/raster/r.to.vect/util.c
--- grass/branches/releasebranch_6_4/raster/r.to.vect/util.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster/r.to.vect/util.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -150,7 +150,7 @@
 	G_fatal_error(_("Cannot insert new row: %s"), db_get_string(&sql));
Modified: grass/branches/releasebranch_6_4/raster3d/r3.out.v5d/main.c
--- grass/branches/releasebranch_6_4/raster3d/r3.out.v5d/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/raster3d/r3.out.v5d/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -54,7 +54,7 @@
 	    fatalError(_("Unable to close 3D raster map"));
-    G3d_fatalError(errorMsg);
+    G3d_fatalError("%s", errorMsg);
Modified: grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c
--- grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.in.ascii/points.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -399,7 +399,7 @@
 		db_append_string(&sql, buf2);
 	    if (db_execute_immediate(driver, &sql) != DB_OK) {
 		G_fatal_error(_("Unable to insert new record: %s"),
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -595,7 +595,7 @@
 	    strcat(error_msg,
 		   _("Consider generating a new location with 'location' parameter"
 		    " from input data set.\n"));
-	    G_fatal_error(error_msg);
+	    G_fatal_error("%s", error_msg);
 	else {
 	    G_message(_("Projection of input dataset and current location "
@@ -779,7 +779,7 @@
 		G_free(Ogr_fieldname);
 	    driver =
 		db_start_driver_open_database(Fi->driver,
@@ -933,7 +933,7 @@
 		    db_append_string(&sql, buf);
 		db_append_string(&sql, " )");
 		    db_close_database(driver);
Modified: grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c
--- grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.net.allpairs/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -146,7 +146,7 @@
 	    Fi->table);
-    G_debug(2, db_get_string(&sql));
+    G_debug(2, "%s", db_get_string(&sql));
 	db_close_database_shutdown_driver(driver);
@@ -234,7 +234,7 @@
 	    sprintf(buf, "insert into %s values (%d, %d, %f)",
 		    Fi->table, spnode[i].cat, spnode[j].cat, cost);
Modified: grass/branches/releasebranch_6_4/vector/v.net.centrality/main.c
--- grass/branches/releasebranch_6_4/vector/v.net.centrality/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.net.centrality/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -233,7 +233,7 @@
 	    "create table %s(cat integer%s)", Fi->table, db_get_string(&tmp));
Modified: grass/branches/releasebranch_6_4/vector/v.net.components/main.c
--- grass/branches/releasebranch_6_4/vector/v.net.components/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.net.components/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -31,7 +31,7 @@
     sprintf(buf, "insert into %s values (%d, %d)", Fi->table, cat, comp);
     db_set_string(sql, buf);
-    G_debug(3, db_get_string(sql));
+    G_debug(3, "%s", db_get_string(sql));
     if (db_execute_immediate(driver, sql) != DB_OK) {
@@ -140,7 +140,7 @@
     sprintf(buf, "create table %s ( cat integer, comp integer)", Fi->table);
Modified: grass/branches/releasebranch_6_4/vector/v.net.distance/main.c
--- grass/branches/releasebranch_6_4/vector/v.net.distance/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.net.distance/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -201,7 +201,7 @@
 	    Fi->table);
@@ -250,7 +250,7 @@
 		    tcat, cost);
 		G_fatal_error(_("Cannot insert new record: %s"),
Modified: grass/branches/releasebranch_6_4/vector/v.net.flow/main.c
--- grass/branches/releasebranch_6_4/vector/v.net.flow/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.net.flow/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -161,7 +161,7 @@
 	    Fi->table);
@@ -237,7 +237,7 @@
 	    sprintf(buf, "insert into %s values (%d, %f)", Fi->table, cat,
 		    flow[i] / (double)In.cost_multip);
Modified: grass/branches/releasebranch_6_4/vector/v.net.path/path.c
--- grass/branches/releasebranch_6_4/vector/v.net.path/path.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.net.path/path.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -102,7 +102,7 @@
 	    Fi->table);
@@ -302,7 +302,7 @@
 		"insert into %s values ( %d, %d, %d, %d, %d, %f, %f, %f)",
 		Fi->table, cat, id, fcat, tcat, sp, cost, fdist, tdist);
Modified: grass/branches/releasebranch_6_4/vector/v.net.timetable/main.c
--- grass/branches/releasebranch_6_4/vector/v.net.timetable/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.net.timetable/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -96,7 +96,7 @@
     sprintf(buf, "create table %s (%s)", (*Fi)->table, columns);
     if (db_execute_immediate(*driver, &sql) != DB_OK) {
 	db_close_database_shutdown_driver(*driver);
@@ -128,7 +128,7 @@
     sprintf(buf, "insert into %s values (%d, %d, %d, %d, %d, %d)", table, cat,
 	    path, stop_id, index, arrival_time, departure_time);
 	G_fatal_error(_("Cannot insert new record: %s"), db_get_string(&sql));
@@ -150,7 +150,7 @@
 	    table, cat, path, from_id, to_id, route_id, index, from_time,
 	    to_time);
Modified: grass/branches/releasebranch_6_4/vector/v.overlay/area_area.c
--- grass/branches/releasebranch_6_4/vector/v.overlay/area_area.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.overlay/area_area.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -339,7 +339,7 @@
 			db_append_string(&stmt, " )");
-			G_debug(3, db_get_string(&stmt));
+			G_debug(3, "%s", db_get_string(&stmt));
 			if (db_execute_immediate(driver, &stmt) != DB_OK)
 			    G_warning(_("Unable to insert new record: '%s'"),
Modified: grass/branches/releasebranch_6_4/vector/v.overlay/line_area.c
--- grass/branches/releasebranch_6_4/vector/v.overlay/line_area.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.overlay/line_area.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -212,7 +212,7 @@
Modified: grass/branches/releasebranch_6_4/vector/v.overlay/main.c
--- grass/branches/releasebranch_6_4/vector/v.overlay/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.overlay/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -517,7 +517,7 @@
 	if (db_execute_immediate(driver, &stmt) != DB_OK) {
 	    Vect_close(&Out);
Modified: grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.surf.rst/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -601,7 +601,7 @@
 	db_append_string(&sql2, "cat integer");
 	db_append_string(&sql2, ", flt1 double precision");
 	db_append_string(&sql2, ")");
-	G_debug(1, db_get_string(&sql2));
+	G_debug(1, "%s", db_get_string(&sql2));
 	driver2 = db_start_driver_open_database(ff->driver, ff->database);
 	if (driver2 == NULL)
 	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Modified: grass/branches/releasebranch_6_4/vector/v.vol.rst/main.c
--- grass/branches/releasebranch_6_4/vector/v.vol.rst/main.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.vol.rst/main.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -584,7 +584,7 @@
 	db_append_string(&sql, "cat integer");
 	db_append_string(&sql, ", flt1 double precision");
-	G_debug(1, db_get_string(&sql));
+	G_debug(1, "%s", db_get_string(&sql));
 	driver = db_start_driver_open_database(f->driver, f->database);
 	if (driver == NULL)
Modified: grass/branches/releasebranch_6_4/vector/v.vol.rst/vector.c
--- grass/branches/releasebranch_6_4/vector/v.vol.rst/vector.c	2015-10-27 13:21:39 UTC (rev 66615)
+++ grass/branches/releasebranch_6_4/vector/v.vol.rst/vector.c	2015-10-27 13:58:52 UTC (rev 66616)
@@ -72,7 +72,7 @@
     sprintf(buf, ", %f", err);
