[GRASS-SVN] r66641 - grass-addons/grass7/imagery/i.segment.stats
svn_grass at osgeo.org
Wed Oct 28 08:31:29 PDT 2015
Author: mlennert
Date: 2015-10-28 08:31:29 -0700 (Wed, 28 Oct 2015)
New Revision: 66641
grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
misc corrections, notably: use r.clump before r.to.vect to avoid weird polygons, check for inf values in v.to.db results and replace by NULL
Modified: grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
--- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2015-10-28 13:40:29 UTC (rev 66640)
+++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2015-10-28 15:31:29 UTC (rev 66641)
@@ -81,7 +81,10 @@
if grass.find_file(temporary_vect, element='vector')['name']:
grass.run_command('g.remove', flags='f', type_='vector',
- name=temporary_vect)
+ name=temporary_vect, quiet=True)
+ if grass.find_file(temporary_clumped_rast, element='vector')['name']:
+ grass.run_command('g.remove', flags='f', type_='vector',
+ name=temporary_clumped_rast, quiet=True)
if insert_sql:
os.remove(insert_sql)
@@ -104,6 +107,8 @@
insert_sql = None
global temporary_vect
+ global temporary_clumped_rast
+ temporary_clumped_rast = 'segmstat_tmp_clumpedrast_%d' % os.getpid()
temporary_vect = 'segmstat_tmp_vect_%d' % os.getpid()
raster_stat_dict = {'zone': 0, 'min': 4, 'third_quart': 16, 'max': 5, 'sum':
@@ -113,8 +118,15 @@
'mean': 7}
grass.run_command('g.region', raster=segment_map)
- grass.run_command('r.to.vect', input_=segment_map, output=temporary_vect,
- type_='area' , flags='vt')
+ grass.run_command('r.clump',
+ input_=segment_map,
+ output=temporary_clumped_rast,
+ quiet=True)
+ grass.run_command('r.to.vect',
+ input_=temporary_clumped_rast,
+ output=temporary_vect,
+ type_='area',
+ flags='vt')
for area_measure in area_measures:
output_header.append(area_measure)
@@ -129,21 +141,26 @@
if not grass.find_file(raster, element='raster')['name']:
grass.message(_("Cannot find raster %s" % raster))
continue
- grass.run_command('g.region', raster=raster)
rastername=raster.split('@')[0]
- output_header = output_header + [rastername + "_" + x
- for x in raster_statistics]
+ output_header += [rastername + "_" + x for x in raster_statistics]
stat_indices = [raster_stat_dict[x] for x in raster_statistics]
- res=grass.read_command('r.univar', map_=raster, zones=segment_map,
- flags='et').splitlines()[1:]
- print res
+ res=grass.read_command('r.univar',
+ map_=raster,
+ zones=temporary_clumped_rast,
+ flags='et').splitlines()[1:]
for element in res:
values = element.split('|')
- output_dict[values[0]] = output_dict[values[0]]+ [values[x] for x in
- stat_indices]
+ output_dict[values[0]] = output_dict[values[0]]+ [values[x] for x in stat_indices]
+ if csvfile:
+ with open(csvfile, 'wb') as f:
+ f.write(",".join(output_header)+"\n")
+ for key in output_dict:
+ f.write(key+","+",".join(output_dict[key])+"\n")
+ f.close()
if vectormap:
- insert_sql=grass.tempfile()
+ insert_sql = grass.tempfile()
fsql = open(insert_sql, 'w')
fsql.write('BEGIN TRANSACTION;\n')
create_statement = 'CREATE TABLE ' + vectormap + ' (cat int, '
@@ -151,9 +168,10 @@
create_statement += header + ' double precision, '
create_statement += output_header[-1] + ' double precision);\n'
fsql.write(create_statement)
- for key in sorted(output_dict):
- fsql.write("INSERT INTO " + vectormap + " VALUES (" +
- key+","+",".join(output_dict[key])+");\n")
+ sql = "INSERT INTO " + vectormap + " VALUES (" + key+","+",".join(output_dict[key])+");\n"
+ sql = sql.replace('inf', 'NULL')
+ fsql.write(sql)
fsql.write('END TRANSACTION;')
fsql.close()
grass.run_command('g.copy', vector=temporary_vect+','+vectormap)
@@ -161,13 +179,6 @@
grass.run_command('v.db.connect', map_=vectormap, table=vectormap)
- if csvfile:
- with open(csvfile, 'wb') as f:
- f.write(",".join(output_header)+"\n")
- f.write(key+","+",".join(output_dict[key])+"\n")
- f.close()
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
