[GRASS-SVN] r66664 - grass/trunk/gui/wxpython/xml
Thu Oct 29 09:47:03 PDT 2015
Author: martinl
Date: 2015-10-29 09:47:03 -0700 (Thu, 29 Oct 2015)
New Revision: 66664
   grass/trunk/gui/wxpython/xml/toolboxes.xml
wxGUI: add r.import and v.import to the menu
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml	2015-10-29 16:44:10 UTC (rev 66663)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml	2015-10-29 16:47:03 UTC (rev 66664)
@@ -249,6 +249,9 @@
     <label>Import raster data</label>
     <items>
       <wxgui-item name="CommonFormatsImport"/>
+      <module-item name="r.import">
+        <label>Common formats import with reprojection</label>
+      </module-item>
       <separator/>
       <module-item name="r.in.xyz">
         <label>ASCII x,y,z point import and gridding</label>
@@ -298,6 +301,9 @@
     <label>Import vector data</label>
     <items>
       <wxgui-item name="CommonImportFormats"/>
+      <module-item name="v.import">
+      </module-item>
       <separator/>
       <module-item name="v.in.ascii">
         <label>ASCII points or GRASS ASCII format</label>
