[GRASS-SVN] r66683 - grass-addons/grass7/raster/r.skyview
Fri Oct 30 12:29:49 PDT 2015
Author: wenzeslaus
Date: 2015-10-30 12:29:49 -0700 (Fri, 30 Oct 2015)
New Revision: 66683
   grass-addons/grass7/raster/r.skyview/r.skyview.py
r.skyview: add option to shade input or other maps with the output
This adds functionality which could be done by the user
manually afterwards but this gives a narrower set of choices
and adds convenience. (Similarly to r66628.)
Modified: grass-addons/grass7/raster/r.skyview/r.skyview.py
--- grass-addons/grass7/raster/r.skyview/r.skyview.py	2015-10-30 19:09:12 UTC (rev 66682)
+++ grass-addons/grass7/raster/r.skyview/r.skyview.py	2015-10-30 19:29:49 UTC (rev 66683)
@@ -5,6 +5,7 @@
 # MODULE:       r.skyview
 # AUTHOR(S):    Anna Petrasova (kratochanna gmail.com)
+#               Vaclav Petras <wenzeslaus gmail com> (colorize addition)
 # PURPOSE:      Implementation of Sky-View Factor visualization technique
@@ -40,11 +41,51 @@
 #% required: no
 #%end
 #%option
+#% key: color_source
+#% type: string
+#% label: Source raster for colorization
+#% description: Input and color_input are taken from input and color_input options respectively. The rest is computed using r.slope.aspect
+#% descriptions: input; use the raster from the input option;color_input;use the raster from the color_input option;slope;compute and use slope;aspect;compute and use aspect;dxy;compute and use second order partial derivative dxy
+#% multiple: no
+#% required: no
+#% options: input, color_input, slope, aspect, dxy
+#% answer: input
+#% guisection: Colorize
+#%end
+#%option G_OPT_R_INPUT
+#% key: color_input
+#% required: no
+#% description: Custom raster map to be used for colorization
+#%end
+#%option
+#% key: color_table
+#% type: string
+#% label: Color table for colorization raster (preset color table by default)
+#% description: If empty, the color table of the created raster is used (not used at all for input and color_input)
+#% multiple: no
+#% required: no
+#% options: reds, blues, greens, oranges, sepia, aspectcolr
+#%end
+#%option G_OPT_R_OUTPUT
+#% key: colorized_output
+#% required: no
+#% description: Colorized sky-view factor
+#%end
+#%option
 #%  key: basename
 #%  type: string
 #%  multiple: no
 #%  description: Set the basename for the intermediate maps
 #%end
+#%flag
+#% key: n
+#% label: Invert color table for colorization raster
+#% description: Ignored for input and color_input
+#%end
 import sys
@@ -57,6 +98,7 @@
 from grass.pygrass.messages import get_msgr
+# TODO: also used for r.slope.aspect result
 TMP_NAME = 'tmp_horizon_' + str(os.getpid())
 CLEANUP = True
@@ -75,6 +117,28 @@
     if options['basename']:
         TMP_NAME = options['basename']
         CLEANUP = False
+    colorized_output = options['colorized_output']
+    colorize_color = options['color_table']
+    if colorized_output:
+        color_raster_tmp = TMP_NAME + "_color_raster"
+    else:
+        color_raster_tmp = None
+    color_raster_type = options['color_source']
+    color_input = options['color_input']
+    if color_raster_type == 'color_input' and not color_input:
+        gcore.fatal(_("Provide raster name in color_input option"))
+    if color_raster_type != 'color_input' and color_input:
+        gcore.fatal(_("The option color_input is not needed"
+                      " when not using it as source for color"))
+    # this would be needed only when no value would allowed
+    if not color_raster_type and color_input:
+        color_raster_type = 'color_input'  # enable for convenience
+    if color_raster_type == 'aspect' \
+            and colorize_color \
+            and colorize_color not in ['default', 'aspectcolr']:
+        gcore.warning(_("Using possibly inappropriate color table <{}>"
+                        " for aspect".format(colorize_color)))
     horizon_step = 360. / n_dir
     msgr = get_msgr()
@@ -89,6 +153,8 @@
         else:
             msgr.warning(_("The following maps will be overwritten: {names}"
                            ).format(names=','.join(old_maps)))
+    if not gcore.overwrite() and color_raster_tmp:
+        check_map_name(color_raster_tmp)
     try:
         gcore.run_command('r.horizon', elevation=elev, step=horizon_step,
                           output=TMP_NAME, flags='d')
@@ -106,6 +172,31 @@
         msgr.fatal(_("r.horizon failed to compute horizon elevation "
                      "angle maps. Please report this problem to developers."))
         return 1
+        if color_raster_type == 'slope':
+            gcore.run_command('r.slope.aspect', elevation=elev,
+                              slope=color_raster_tmp)
+        elif color_raster_type == 'aspect':
+                              aspect=color_raster_tmp)
+        elif color_raster_type == 'dxy':
+                              dxy=color_raster_tmp)
+        elif color_raster_type == 'color_input':
+            color_raster_tmp = color_input
+        else:
+            color_raster_tmp = elev
+        # don't modify user's color table for inputs
+        if colorize_color \
+                and color_raster_type not in ['input', 'color_input']:
+            rcolors_flags = ''
+            if flags['n']:
+                rcolors_flags += 'n'
+            gcore.run_command('r.colors', map=color_raster_tmp,
+                              color=colorize_color,
+                              flags=rcolors_flags)
+        gcore.run_command('r.shade', shade=output, color=color_raster_tmp,
+                          output=colorized_output)
     return 0
@@ -114,6 +205,15 @@
                               pattern=TMP_NAME + "*")[gcore.gisenv()['MAPSET']]
+def check_map_name(name):
+    # cell means any raster in this context
+    # mapset needs to retrieved in very call, ok for here
+    if gcore.find_file(name, element='cell',
+                       mapset=gcore.gisenv()['MAPSET'])['file']:
+        gcore.fatal(_("Raster map <%s> already exists. "
+                      "Remove the existing map or allow overwrite.") % name)
 if __name__ == "__main__":
     options, flags = gcore.parser()
     atexit.register(cleanup)
