[GRASS-SVN] r66076 - grass/trunk/lib/raster
svn_grass at osgeo.org
Tue Sep 1 06:22:50 PDT 2015
Author: huhabla
Date: 2015-09-01 06:22:50 -0700 (Tue, 01 Sep 2015)
New Revision: 66076
grass/trunk/lib/raster/rast_to_img_string.c
raster library: Added 32bit RGB type
Modified: grass/trunk/lib/raster/rast_to_img_string.c
--- grass/trunk/lib/raster/rast_to_img_string.c 2015-08-31 11:06:17 UTC (rev 66075)
+++ grass/trunk/lib/raster/rast_to_img_string.c 2015-09-01 13:22:50 UTC (rev 66076)
@@ -31,7 +31,7 @@
#define DEF_BLU 255
/* \brief Convert a raster map layer into a string with
- * 32Bit ARGB or 8Bit Gray little endian encoding.
+ * 32Bit ARGB, 24Bit RGB or 8Bit Gray little endian encoding.
* The raster color table is used for coloring the image. Null values are
* marked as transparent. Only little endian encoding is supported.
@@ -41,16 +41,18 @@
* region for raster access.
* \param name The name of the raster map layer to convert
- * \param color_mode The color mode to use (1 -> 32Bit ARGB, 2 or 3 -> 8Bit Gray)
- * Color mode 2 -> grey scale formular: .33R+ .5G+ .17B
- * Color mode 3 -> grey scale formular: .30R+ .59G+ .11B
+ * \param color_mode The color modes to use:
+ * Color mode 1 -> 32Bit ARGB (0xAARRGGBB)
+ * Color mode 2 -> 32Bit RGB (0xffRRGGBB)
+ * Color mode 3 -> grey scale formular: .33R+ .5G+ .17B
+ * Color mode 4 -> grey scale formular: .30R+ .59G+ .11B
* \param result: An unsigned char pointer to store the result.
* It must have size 4*cols*rows in case of
- * ARGB and rows*cols in case of gray scale.
+ * ARGB and RGB,
+ * rows*cols in case of gray scale.
- * \return: 0 in case map not found, 1 on success
+ * \return: 0 in case map not found, -1 in case the color mode is incorrect, 1 on success
int Rast_map_to_img_str(char *name, int color_mode, unsigned char* result)
@@ -71,6 +73,9 @@
int rows = Rast_window_rows();
int cols = Rast_window_cols();
+ if(color_mode > 3 || color_mode < 1)
+ return(-1);
mapset = G_find_raster2(name, "");
if(!mapset)
@@ -99,14 +104,14 @@
i = 0;
- if(color_mode == 1) {/* 32BIT ARGB COLOR IMAGE with transparency */
+ if(color_mode == 1 || color_mode == 2) {/* 32BIT ARGB COLOR IMAGE with transparency */
for (row = 0; row < rows; row++) {
Rast_get_row(map, (void *)voidc, row, rtype);
Rast_lookup_colors((void *)voidc, red, green, blue, set,
cols, &colors, rtype);
alpha = (unsigned char)255;
- if ( Rast_is_null_value( voidc, rtype ) )
+ if ( color_mode == 1 && Rast_is_null_value( voidc, rtype ) )
alpha = (unsigned char)0;
@@ -133,7 +138,7 @@
- if(color_mode == 2) {
+ if(color_mode == 3) {
for (col = 0; col < cols; col++) {
/*.33R+ .5G+ .17B */
result[i++] = ((red[col]) * 11 +
