[GRASS-SVN] r66089 - grass-addons/grass7/raster/r.viewshed.cva
svn_grass at osgeo.org
Thu Sep 3 12:46:40 PDT 2015
Author: neteler
Date: 2015-09-03 12:46:40 -0700 (Thu, 03 Sep 2015)
New Revision: 66089
grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html
grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
r.viewshed.cva addon: fix name_column parameter name; update examples
Modified: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html 2015-09-03 19:29:53 UTC (rev 66088)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.html 2015-09-03 19:46:40 UTC (rev 66089)
@@ -6,14 +6,14 @@
a python wrapper script that iterative loops through each input
point, calculating a viewshed map, and then creates an output map
that is coded by the number of input locations that can "see" each
-cell. <em>r.viewshed.cva</em> uses the GRASS module <em>r.viewshed</em>
+cell. <em>r.viewshed.cva</em> uses the GRASS GIS module <em>r.viewshed</em>
for the viewshed analysis. <em>r.viewshed</em> is very fast,
thus allowing for a cumulative viewshed analysis to run in a
reasonable amount of time. The final cumulative viewshed map is
computed using the "count" method of <em>r.series</em>, rather than
with mapcalc, as it better handles the null values in the individual
constituent viewshed maps (and allows for interim viewshed maps to
-be coded in any way)
+be coded in any way).
<p>
<h3>Options and flags:</h3>
@@ -24,16 +24,17 @@
you to keep the interim viewshed maps made for each input point.
Optionally, option <b>name_col</b> can be used with <b>-k</b> to specify
the suffix of the kept viewshed maps by a particular column in the
-input vector sites' database. If no value is specified for <b>name_col</b>,
+input vector points' database. If no value is specified for <b>name_col</b>,
then the cat value will be used.
<p>
All other flags and options are inherited from
-<em>r.viewshed<em> (see the <a href="r.viewshed.html">r.viewshed</a> help page for more
-information on these).
+<em>r.viewshed<em> (see the <a href="r.viewshed.html">r.viewshed</a>
+help page for more information on these).
<p>
<h2>NOTES</h2>
+<!-- todo: mention r.geomorphon addon for summit extraction -->
The input vector points map can be manually digitized (with <em>
v.digit</em>) over topographic or cultural features, or can be
created as a series of random points (with <em>r.random</em> or <em>
@@ -46,25 +47,26 @@
<p>
<h2>EXAMPLES</h2>
-Undertake a cumulative viewshed analysis from a digitized vector points map of prominent peaks in a region:<br>
+Undertake a cumulative viewshed analysis from a digitized vector points
+map of prominent peaks in a region:<br>
<div class="code"><pre>
-g.region rast=elevation_10m_dem at PERMANENT -p
-[use v.digit to digitize points]
-r.viewshed.cva.py elev=elevation10m_demPERMANENT output=peaks_CVA_map \
- vect=prominent_peaks_points at PERMANENT x_column=x y_column=y \
- name_column=cat obs_elev=0.0 tgt_elev=1.75 max_dist=-1 mem=1500
+g.region raster=elevation_10m_dem -p
+# [use v.digit to digitize points or eg the r.geomorphon addon for summits]
+r.viewshed.cva input=elevation10m_dem output=peaks_CVA_map \
+ vector=prominent_peaks_points name_column=cat \
+ observer_elevation=1.75 target_elevation=0
</pre></div>
<br>Undertake a cumulative viewshed analysis from a 10% sample of landscape locations in a region:<br>
-r.random input=elevation10m_demPERMANENT n=10% vector_output=rand_points_10p
- vect=rand_points_10p at PERMANENT x_column=x y_column=y \
+r.random input=elevation10m_dem n=10% vector_output=rand_points_10p
+ vector=rand_points_10p name_column=cat \
</pre></div>
Modified: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py 2015-09-03 19:29:53 UTC (rev 66088)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py 2015-09-03 19:46:40 UTC (rev 66089)
@@ -26,7 +26,7 @@
#%option G_OPT_V_INPUT
#% key: vector
-#% description: Name of input vector points map containg the set of sites for this analysis.
+#% description: Name of input vector points map containg the set of points for this analysis.
#%end
#%option G_OPT_R_OUTPUT
@@ -76,8 +76,8 @@
#%end
#%option G_OPT_DB_COLUMN
-#% key: name_col
-#% description: Database column for site names (with flag -k)
+#% key: name_column
+#% description: Database column for point names (with flag -k)
#% required : no
#%end
