[GRASS-SVN] r66094 - in grass/trunk/raster/r.in.lidar: . test
Thu Sep 3 19:40:46 PDT 2015
Author: wenzeslaus
Date: 2015-09-03 19:40:46 -0700 (Thu, 03 Sep 2015)
New Revision: 66094
Added:
   grass/trunk/raster/r.in.lidar/test/
   grass/trunk/raster/r.in.lidar/test/sample_test.sh
   grass/trunk/raster/r.in.lidar/main.c
   grass/trunk/raster/r.in.lidar/r.in.lidar.html
r.in.lidar: add base raster to get height above ground
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c	2015-09-03 22:06:20 UTC (rev 66093)
+++ grass/trunk/raster/r.in.lidar/main.c	2015-09-04 02:40:46 UTC (rev 66094)
@@ -99,7 +99,7 @@
 int main(int argc, char *argv[])
-    int out_fd;
+    int out_fd, base_raster;
     char *infile, *outmap;
     int percent;
     int method = -1;
@@ -107,11 +107,11 @@
     double zrange_min, zrange_max, d_tmp;
     unsigned long estimated_lines;
-    RASTER_MAP_TYPE rtype;
+    RASTER_MAP_TYPE rtype, base_raster_data_type;
     struct History history;
     char title[64];
     void *n_array, *min_array, *max_array, *sum_array, *sumsq_array,
-	*index_array;
+        *index_array, *base_array;
     void *raster_row, *ptr;
     struct Cell_head region;
     int rows, cols;		/* scan box size */
@@ -146,7 +146,7 @@
     struct GModule *module;
     struct Option *input_opt, *output_opt, *percent_opt, *type_opt, *filter_opt, *class_opt;
-    struct Option *method_opt, *zrange_opt, *zscale_opt;
+    struct Option *method_opt, *base_raster_opt, *zrange_opt, *zscale_opt;
     struct Option *trim_opt, *pth_opt, *res_opt;
     struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag, *intens_flag;
@@ -197,6 +197,12 @@
     type_opt->answer = "FCELL";
     type_opt->description = _("Storage type for resultant raster map");
+    base_raster_opt = G_define_standard_option(G_OPT_R_INPUT);
+    base_raster_opt->key = "base_raster";
+    base_raster_opt->required = NO;
+    base_raster_opt->label = _("Subtract raster values from the z coordinates");
+    base_raster_opt->description = _("The scale for z is applied beforehand, the filter afterwards");
     zrange_opt = G_define_option();
     zrange_opt->key = "zrange";
     zrange_opt->type = TYPE_DOUBLE;
@@ -507,6 +513,7 @@
     sum_array = NULL;
     sumsq_array = NULL;
     index_array = NULL;
+    base_array = NULL;
     if (strcmp(method_opt->answer, "n") == 0) {
 	method = METHOD_N;
@@ -641,6 +648,12 @@
     npasses = (int)ceil(1.0 * region.rows / rows);
+    if (base_raster_opt->answer) {
+        /* TODO: do we need to test existence first? mapset? */
+        base_raster = Rast_open_old(base_raster_opt->answer, "");
+        base_raster_data_type = Rast_get_map_type(base_raster);
     if (!scan_flag->answer) {
 	/* check if rows * (cols + 1) go into a size_t */
 	if (sizeof(size_t) < 8) {
@@ -665,6 +678,10 @@
 	if (bin_index)
 	    index_array =
 		G_calloc((size_t)rows * (cols + 1), Rast_cell_size(CELL_TYPE));
+	    base_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(base_raster_data_type));
+	/* we don't free the raster, we just use it again */
+	/* TODO: perhaps none of them needs to be freed */
 	/* and then free it again */
 	if (bin_n)
@@ -719,6 +736,13 @@
 	    pass_south = region.south; /* exact copy to avoid fp errors */
+        if (base_array) {
+            G_debug(2, "filling base raster array");
+            for (row = 0; row < rows; row++) {
+                Rast_get_row(base_raster, base_array + (row * cols * Rast_cell_size(base_raster_data_type)), row, base_raster_data_type);
 	G_debug(2, "pass=%d/%d  pass_n=%f  pass_s=%f  rows=%d",
 		pass, npasses, pass_north, pass_south, rows);
@@ -832,19 +856,41 @@
 	    z = z * zscale;
-	    if (zrange_opt->answer) {
-		if (z < zrange_min || z > zrange_max) {
-		    continue;
+            /* find the bin in the current array box */
+            arr_row = (int)((pass_north - y) / region.ns_res);
+            arr_col = (int)((x - region.west) / region.ew_res);
+            if (base_array) {
+                ptr = base_array;
+                ptr =
+                    G_incr_void_ptr(ptr,
+                                    ((arr_row * cols) +
+                                     arr_col) * Rast_cell_size(base_raster_data_type));
+                double base_z;
+                if (Rast_is_null_value(ptr, base_raster_data_type)) {
+                    continue;
+                else {
+                    if (base_raster_data_type == DCELL_TYPE)
+                        base_z = *(DCELL *) ptr;
+                    else if (base_raster_data_type == FCELL_TYPE)
+                        base_z = (double) *(FCELL *) ptr;
+                    else
+                        base_z = (double) *(CELL *) ptr;
+                z -= base_z;
+            if (zrange_opt->answer) {
+                if (z < zrange_min || z > zrange_max) {
+                    continue;
 	    count++;
 	    /*          G_debug(5, "x: %f, y: %f, z: %f", x, y, z); */
-	    /* find the bin in the current array box */
-	    arr_row = (int)((pass_north - y) / region.ns_res);
-	    arr_col = (int)((x - region.west) / region.ew_res);
 	    if (bin_n)
 		update_n(n_array, cols, arr_row, arr_col);
 	    if (bin_min)
@@ -1207,7 +1253,8 @@
 	    max_nodes = 0;
 	    nodes = NULL;
+	if (base_array)
+	    Rast_close(base_raster);
     }				/* passes loop */
     G_percent(1, 1, 1);		/* flush */
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html	2015-09-03 22:06:20 UTC (rev 66093)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html	2015-09-04 02:40:46 UTC (rev 66094)
@@ -200,7 +200,7 @@
 <em>r.neighbors</em> to smooth the stddev map before further use.]
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
 Import of a LAS file into an existing location/mapset (metric):
@@ -211,8 +211,9 @@
 r.univar lidar_dem_mean
 </pre></div>
+<h3>Serpent Mound dataset</h3>
 <p>
-Serpent Mound dataset:
 This example is analogous to the example used in the GRASS wiki page for
 <a href="http://grasswiki.osgeo.org/wiki/LIDAR#Import_LAS_as_raster_DEM">importing LAS as raster DEM</a>.
 <p>The sample LAS data are in the file "Serpent Mound Model LAS Data.las",
@@ -240,6 +241,21 @@
            output=Serpent_Mound_Model_LAS_Data method=mean
 </pre></div>
+<h3>Height above ground</h3>
+<p>
+Compute mean height above ground of the points for each raster cell
+(ground elevation is given by the raster map <tt>elevation</tt>):
+<div class="code"><pre>
+g.region raster=elevation
+r.in.lidar input=points.las output=height_above_ground base_raster=elevation
+</pre></div>
+In this type of computation, it might be advantageous to change the resolution
+to match the precision of the points rather then derive it from the base raster.
 <h2>NOTES</h2>
 The typical file extensions for the LAS format are .las and .laz (compressed).
 The compressed LAS (.laz) format can be imported only if libLAS has been compiled
Added: grass/trunk/raster/r.in.lidar/test/sample_test.sh
--- grass/trunk/raster/r.in.lidar/test/sample_test.sh	                        (rev 0)
+++ grass/trunk/raster/r.in.lidar/test/sample_test.sh	2015-09-04 02:40:46 UTC (rev 66094)
@@ -0,0 +1,11 @@
+# GNU GPL
+# Vaclav Petras
+# this is an idea for a test
+export GRASS_OVERWRITE=1
+r.in.lidar in=points.las out=test_pure
+r.in.lidar in=points.las out=test_hag base=elevation
+r.mapcalc "test_difference = (elevation + test_hag) - test_pure"
+r.univar test_difference
+g.region -p -a raster=test_difference at manual res=0.1 zoom=test_difference at manual
Property changes on: grass/trunk/raster/r.in.lidar/test/sample_test.sh
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + text/x-sh
Added: svn:eol-style
   + native
