[GRASS-SVN] r66105 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Fri Sep 4 17:42:43 PDT 2015
Author: huhabla
Date: 2015-09-04 17:42:43 -0700 (Fri, 04 Sep 2015)
New Revision: 66105
grass/trunk/lib/python/temporal/c_libraries_interface.py
temporal framework: CLibrariesInterface inherits RPCServerBase from pygrass.rpc
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-09-05 00:41:30 UTC (rev 66104)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-09-05 00:42:43 UTC (rev 66105)
@@ -25,6 +25,7 @@
import grass.lib.date as libdate
import grass.lib.raster3d as libraster3d
import grass.lib.temporal as libtgis
+from grass.pygrass.rpc.base import RPCServerBase
@@ -791,7 +792,7 @@
functions[data[0]](lock, conn, data)
lock.release()
-class CLibrariesInterface(object):
+class CLibrariesInterface(RPCServerBase):
"""Fast and exit-safe interface to GRASS C-libraries functions
This class implements a fast and exit-safe interface to the GRASS
@@ -943,44 +944,8 @@
def __init__(self):
- self.client_conn = None
- self.server_conn = None
- self.queue = None
- self.server = None
- self.checkThread = None
- self.threadLock = threading.Lock()
- self.start_server()
- self.start_checker_thread()
- self.stopThread = False
+ RPCServerBase.__init__(self)
- def start_checker_thread(self):
- if self.checkThread is not None and self.checkThread.is_alive():
- self.stop_checker_thread()
- self.checkThread = threading.Thread(target=self.thread_checker)
- self.checkThread.daemon = True
- self.checkThread.start()
- def stop_checker_thread(self):
- self.threadLock.acquire()
- self.stopThread = True
- self.threadLock.release()
- self.checkThread.join(None)
- def thread_checker(self):
- """Check every 200 micro seconds if the server process is alive"""
- while True:
- time.sleep(0.2)
- #sys.stderr.write("Check server process\n")
- self._check_restart_server()
- if self.stopThread == True:
- #sys.stderr.write("Stop thread\n")
- return
def start_server(self):
self.client_conn, self.server_conn = Pipe(True)
self.lock = Lock()
@@ -989,24 +954,6 @@
self.server.daemon = True
self.server.start()
- def check_server(self):
- def _check_restart_server(self):
- """Restart the server if it was terminated
- if self.server.is_alive() is True:
- return
- self.client_conn.close()
- self.server_conn.close()
- logging.warning("Needed to restart the libgis server")
def raster_map_exists(self, name, mapset):
"""Check if a raster map exists in the spatial database
@@ -1361,32 +1308,6 @@
# The pipe should be closed in the checker thread
return self.safe_receive("Fatal error")
- def safe_receive(self, message):
- """Receive the data and throw an FatalError exception in case the server
- process was killed and the pipe was closed by the checker thread"""
- try:
- ret = self.client_conn.recv()
- if isinstance(ret, FatalError):
- raise FatalError()
- return ret
- except (EOFError, IOError, FatalError):
- # The pipe was closed by the checker thread because
- # the server process was killed
- raise FatalError(message)
- def stop(self):
- """Stop the check thread, the libgis server and close the pipe
- This method should be called at exit using the package atexit
- #sys.stderr.write("###### Stop was called\n")
- if self.server is not None and self.server.is_alive():
- self.client_conn.send([0, ])
- self.server.join()
- if self.client_conn is not None:
if __name__ == "__main__":
import doctest
doctest.testmod()
