[GRASS-SVN] r66112 - in grass/trunk: lib/python/gunittest lib/symbol locale/po scripts/d.polar scripts/r.pack scripts/r.unpack scripts/v.krige scripts/v.pack scripts/v.unpack vector/v.build
Sat Sep 5 08:57:08 PDT 2015
Author: neteler
Date: 2015-09-05 08:57:08 -0700 (Sat, 05 Sep 2015)
New Revision: 66112
   grass/trunk/lib/python/gunittest/reporters.py
   grass/trunk/lib/symbol/README
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fi.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ro.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/locale/po/grasswxpy_cs.po
   grass/trunk/locale/po/grasswxpy_de.po
   grass/trunk/locale/po/grasswxpy_el.po
   grass/trunk/locale/po/grasswxpy_es.po
   grass/trunk/locale/po/grasswxpy_fi.po
   grass/trunk/locale/po/grasswxpy_fr.po
   grass/trunk/locale/po/grasswxpy_id.po
   grass/trunk/locale/po/grasswxpy_it.po
   grass/trunk/locale/po/grasswxpy_ja.po
   grass/trunk/locale/po/grasswxpy_ko.po
   grass/trunk/locale/po/grasswxpy_lv.po
   grass/trunk/locale/po/grasswxpy_ml.po
   grass/trunk/locale/po/grasswxpy_pl.po
   grass/trunk/locale/po/grasswxpy_pt.po
   grass/trunk/locale/po/grasswxpy_pt_br.po
   grass/trunk/locale/po/grasswxpy_ro.po
   grass/trunk/locale/po/grasswxpy_ru.po
   grass/trunk/locale/po/grasswxpy_th.po
   grass/trunk/locale/po/grasswxpy_tr.po
   grass/trunk/locale/po/grasswxpy_vi.po
   grass/trunk/locale/po/grasswxpy_zh.po
   grass/trunk/scripts/d.polar/d.polar.html
   grass/trunk/scripts/r.pack/r.pack.html
   grass/trunk/scripts/r.unpack/r.unpack.html
   grass/trunk/scripts/v.krige/v.krige.html
   grass/trunk/scripts/v.pack/v.pack.html
   grass/trunk/scripts/v.unpack/v.unpack.html
   grass/trunk/vector/v.build/main.c
various typo fixes, found by the Debian lintian QA tool (trac #2725)
Modified: grass/trunk/lib/python/gunittest/reporters.py
--- grass/trunk/lib/python/gunittest/reporters.py	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/lib/python/gunittest/reporters.py	2015-09-05 15:57:08 UTC (rev 66112)
@@ -690,7 +690,7 @@
                 status=returncode_to_success_html_par(returncode),
-        # TODO: include optionaly hyper link to test suite
+        # TODO: include optionally hyper link to test suite
         # TODO: file_path is reconstucted in a naive way
         # file_path should be stored in the module/test file object and just used here
         summary_section = (
Modified: grass/trunk/lib/symbol/README
--- grass/trunk/lib/symbol/README	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/lib/symbol/README	2015-09-05 15:57:08 UTC (rev 66112)
@@ -64,7 +64,7 @@
 ARC X Y R A1 A2 [C]
  Arc specified by center (X Y), radius (R), start/end angle in degrees (A1/A2)
- and optionaly direction (C for clockwise, default counter clockwise)
+ and optionally direction (C for clockwise, default counter clockwise)
  Note degrees are polar theta not navigational, i.e. 0 is east and
  values increase counter-clockwise from there. Reducing the angle
  from a full circle does not make it draw like a pacman but rather
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_ar.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6863,7 +6863,7 @@
 msgstr "اسم الخريطة الراسترية المدخلة"
 #: ../vector/v.build/main.c:40
-msgid "Optionaly also checks for topological errors."
+msgid "Optionally also checks for topological errors."
 msgstr ""
 #: ../vector/v.build/main.c:44
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_cs.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6880,7 +6880,7 @@
 msgstr "Vytvoří topologii vektorové vrstvy."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_de.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6775,7 +6775,7 @@
 msgstr "Erzeugt Topologie für GRASS Vektorkarten."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_el.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6613,7 +6613,7 @@
 msgstr "Αδυναμία ανάγνωσης διανυσματικού χάρτη"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_es.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6870,7 +6870,7 @@
 msgstr "Crea topología para mapa vectorial."
 msgstr "Opcionalmente revisa también errores topologícos."
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_fi.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6341,7 +6341,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_fr.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -7139,7 +7139,7 @@
 msgstr "Créer des icones pour le fichier vecteur GRASS et les attributs liés"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_it.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6769,7 +6769,7 @@
 msgstr "Crea etichette per vettoriali GRASS e attributi associati"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_ja.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6789,7 +6789,7 @@
 msgstr "ベクトルマップのカテゴリーを編集,構築します"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_ko.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6630,7 +6630,7 @@
 msgstr "출력할 격자지도"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_lv.po	2015-09-05 15:57:08 UTC (rev 66112)
 msgstr "Vektorkartes nosaukums"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_pl.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6805,7 +6805,7 @@
 msgstr "Tworzy topologię dla wektorowej mapy GRASS."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_pt.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6958,7 +6958,7 @@
 "relacionados."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6951,7 +6951,7 @@
 "relacionados."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_ro.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6394,7 +6394,7 @@
 msgstr ""
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_ru.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6853,7 +6853,7 @@
 msgstr "Создать топологию для векторного слоя GRASS."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_sl.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6892,7 +6892,7 @@
 msgstr "Ime vhodnega rastrskega sloja"
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_th.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -1041,7 +1041,7 @@
 "Either 'from_table' (optionally with 'where') can be used or 'select' "
 "option, but not 'from_table' and 'select' at the same time."
 msgstr ""
-"คัดลอกตาราง. โดยใช้คำสั่ง 'from_table' (optionaly with 'where') หรือ 'select' "
+"คัดลอกตาราง. โดยใช้คำสั่ง 'from_table' (optionally with 'where') หรือ 'select' "
 "option, แต่ไม่ใช่  'from_table' และ 'select' พร้อมกัน"
 #: ../db/db.copy/main.c:46
 msgstr "สร้าง topology สำหรับ แผนที่เชิงเส้น GRASS."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_tr.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6767,7 +6767,7 @@
 msgstr "GRASS vektör dosyası için topoloji oluşturur."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_vi.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6857,7 +6857,7 @@
 msgstr "Tạo tôpô cho bản đồ vector của GRASS."
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grassmods_zh.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -6856,7 +6856,7 @@
 msgstr "为 GRASS 矢量文件和附加属性创建标签。"
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_cs.po
--- grass/trunk/locale/po/grasswxpy_cs.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_cs.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12207,7 +12207,7 @@
 #: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1461
 msgid ""
-"Creates topology for vector map. Optionaly also checks for topological "
+"Creates topology for vector map. Optionally also checks for topological "
 "errors."
 msgstr ""
 "Vytvoří topologii vektorové vrstvy. Volitelně také zkontroluje topologické "
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_de.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12065,7 +12065,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_el.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11401,7 +11401,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_es.po
--- grass/trunk/locale/po/grasswxpy_es.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_es.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12262,7 +12262,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_fi.po
--- grass/trunk/locale/po/grasswxpy_fi.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_fi.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11067,7 +11067,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_fr.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11909,7 +11909,7 @@
 msgid ""
 "errors."
 msgstr ""
 "Créer la topologie pour la carte vecteur. En option, vérifie les erreurs de "
Modified: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_id.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12403,7 +12403,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_it.po
--- grass/trunk/locale/po/grasswxpy_it.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_it.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11574,7 +11574,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ja.po
--- grass/trunk/locale/po/grasswxpy_ja.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_ja.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11996,7 +11996,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ko.po
--- grass/trunk/locale/po/grasswxpy_ko.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_ko.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11047,7 +11047,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_lv.po
--- grass/trunk/locale/po/grasswxpy_lv.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_lv.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11326,7 +11326,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ml.po
--- grass/trunk/locale/po/grasswxpy_ml.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_ml.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11768,7 +11768,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_pl.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11784,7 +11784,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pt.po
--- grass/trunk/locale/po/grasswxpy_pt.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_pt.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12586,7 +12586,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_pt_br.po
--- grass/trunk/locale/po/grasswxpy_pt_br.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_pt_br.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12873,7 +12873,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ro.po
--- grass/trunk/locale/po/grasswxpy_ro.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_ro.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12118,7 +12118,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_ru.po
--- grass/trunk/locale/po/grasswxpy_ru.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_ru.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12343,7 +12343,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_th.po
--- grass/trunk/locale/po/grasswxpy_th.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_th.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11854,7 +11854,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_tr.po
--- grass/trunk/locale/po/grasswxpy_tr.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_tr.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12283,7 +12283,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_vi.po
--- grass/trunk/locale/po/grasswxpy_vi.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_vi.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -12406,7 +12406,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_zh.po
--- grass/trunk/locale/po/grasswxpy_zh.po	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/locale/po/grasswxpy_zh.po	2015-09-05 15:57:08 UTC (rev 66112)
@@ -11919,7 +11919,7 @@
 msgid ""
 "errors."
 msgstr ""
Modified: grass/trunk/scripts/d.polar/d.polar.html
--- grass/trunk/scripts/d.polar/d.polar.html	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/scripts/d.polar/d.polar.html	2015-09-05 15:57:08 UTC (rev 66112)
@@ -20,7 +20,7 @@
 <h2>NOTES</h2>
 If the <b>output</b> parameter is used, the diagram is generated
-as EPS file. If the <b>-x</b> flag is used <em>xgraph</em> is lauched.
+as EPS file. If the <b>-x</b> flag is used <em>xgraph</em> is launched.
 Otherwise <em>d.polar</em> will use <em>d.graph</em> to draw the plot
 in the current display frame.
 <p>If <em>d.polar</em> is used on an aspect map generated by
Modified: grass/trunk/scripts/r.pack/r.pack.html
--- grass/trunk/scripts/r.pack/r.pack.html	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/scripts/r.pack/r.pack.html	2015-09-05 15:57:08 UTC (rev 66112)
@@ -9,7 +9,7 @@
 <h2>NOTES</h2>
 Name of the pack file is determined by default from <b>input</b>
-parameter. Optionaly the name can be given by <b>output</b> parameter.
+parameter. Optionally the name can be given by <b>output</b> parameter.
 Currently only 2D raster maps are supported.
Modified: grass/trunk/scripts/r.unpack/r.unpack.html
--- grass/trunk/scripts/r.unpack/r.unpack.html	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/scripts/r.unpack/r.unpack.html	2015-09-05 15:57:08 UTC (rev 66112)
@@ -5,7 +5,7 @@
 <h2>NOTES</h2>
 Name of the raster map is determined by default from pack file
-internals. Optionaly the name can be given by <b>output</b> parameter.
+internals. Optionally the name can be given by <b>output</b> parameter.
Modified: grass/trunk/scripts/v.krige/v.krige.html
--- grass/trunk/scripts/v.krige/v.krige.html	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/scripts/v.krige/v.krige.html	2015-09-05 15:57:08 UTC (rev 66112)
@@ -163,12 +163,12 @@
 <h2>SEE ALSO</h2>
 R package <a href="http://cran.r-project.org/web/packages/gstat/index.html">gstat</a>,
-mantained by Edzer J. Pebesma and others
+maintained by Edzer J. Pebesma and others
 <br>
 R
 package <a href="http://cran.r-project.org/web/packages/spgrass6/index.html">spgrass6</a>,
-mantained by Roger Bivand
+maintained by Roger Bivand
 <br>
 The <a href="http://grasswiki.osgeo.org/wiki/R_statistics">Short
Modified: grass/trunk/scripts/v.pack/v.pack.html
--- grass/trunk/scripts/v.pack/v.pack.html	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/scripts/v.pack/v.pack.html	2015-09-05 15:57:08 UTC (rev 66112)
@@ -10,7 +10,7 @@
 <h2>NOTES</h2>
 <h2>EXAMPLE</h2>
Modified: grass/trunk/scripts/v.unpack/v.unpack.html
--- grass/trunk/scripts/v.unpack/v.unpack.html	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/scripts/v.unpack/v.unpack.html	2015-09-05 15:57:08 UTC (rev 66112)
@@ -5,7 +5,7 @@
 <h2>NOTES</h2>
 Name of the vector map is determined by default from pack file
 <h2>EXAMPLE</h2>
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c	2015-09-05 15:56:17 UTC (rev 66111)
+++ grass/trunk/vector/v.build/main.c	2015-09-05 15:57:08 UTC (rev 66112)
@@ -37,7 +37,7 @@
     G_add_keyword(_("topology"));
     G_add_keyword(_("geometry"));
     module->label = _("Creates topology for vector map.");
-    module->description = _("Optionaly also checks for topological errors.");
+    module->description = _("Optionally also checks for topological errors.");
     map_opt = G_define_standard_option(G_OPT_V_MAP);
     map_opt->label = NULL;
