[GRASS-SVN] r66121 - grass-addons/grass7/raster/r.mcda.promethee
svn_grass at osgeo.org
Sun Sep 6 02:29:29 PDT 2015
Author: gianluca
Date: 2015-09-06 02:29:29 -0700 (Sun, 06 Sep 2015)
New Revision: 66121
grass-addons/grass7/raster/r.mcda.promethee/local_proto.h
grass-addons/grass7/raster/r.mcda.promethee/main.c
grass-addons/grass7/raster/r.mcda.promethee/promethee.c
first almost usable version 0.1
Modified: grass-addons/grass7/raster/r.mcda.promethee/local_proto.h
--- grass-addons/grass7/raster/r.mcda.promethee/local_proto.h 2015-09-06 02:44:34 UTC (rev 66120)
+++ grass-addons/grass7/raster/r.mcda.promethee/local_proto.h 2015-09-06 09:29:29 UTC (rev 66121)
@@ -20,5 +20,5 @@
void build_flow_matrix(int nrows, int ncols, int ncriteria,
double *weight_vect, double ***decision_vol,
- double ***positive_flow_vol, double ***negative_flow_vol);
+ double **positive_flow_vol, double **negative_flow_vol);
Modified: grass-addons/grass7/raster/r.mcda.promethee/main.c
--- grass-addons/grass7/raster/r.mcda.promethee/main.c 2015-09-06 02:44:34 UTC (rev 66120)
+++ grass-addons/grass7/raster/r.mcda.promethee/main.c 2015-09-06 09:29:29 UTC (rev 66121)
@@ -3,9 +3,8 @@
* MODULE: r.mcda.promethee
* AUTHORS: Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
- * PURPOSE: Make a multicriteria decision analysis based on PROMETHEE algorithm,
- * with concordance and discordance indexes maps
+ * PURPOSE: Make a multicriteria decision analysis based on PROMETHEE algorithm.
* COPYRIGHT: (C) GRASS Development Team (2015)
* This program is free software under the GNU General Public
@@ -38,7 +37,7 @@
int row1, col1;
int outfd_positive_flow, outfd_negative_flow, outfd_netflow; /* output file descriptor */
/*RASTER_MAP_TYPE data_type; type of the map (CELL/DCELL/...) */
- double *weight_vect, ***decision_vol, ***positive_flow_vol, ***negative_flow_vol;/* vector and matrix */
+ double *weight_vect, ***decision_vol, **positive_flow_vol, **negative_flow_vol;/* vector and matrix */
struct History history; /* holds meta-data (title, comments,..) */
@@ -164,19 +163,20 @@
/*memory allocation for-three dimensional matrix*/
decision_vol=G_malloc(nrows * sizeof(double*));
- positive_flow_vol=G_malloc(nrows * sizeof(double*));
- negative_flow_vol=G_malloc(nrows * sizeof(double*));
+ positive_flow_vol=G_calloc(nrows, sizeof(double*)); /*Allocates aligned block of memory and initializes the allocated memory to zero.*/
+ negative_flow_vol=G_calloc(nrows, sizeof(double*));
for (i=0; i<nrows; ++i)
decision_vol[i]=G_malloc(ncols * sizeof(double*));
- positive_flow_vol[i]=G_malloc(nrows * sizeof(double*));
- negative_flow_vol[i]=G_malloc(nrows * sizeof(double*));
+ positive_flow_vol[i]=G_calloc(ncols, sizeof(double*));/*Allocates aligned block of memory and initializes the allocated memory to zero.*/
+ negative_flow_vol[i]=G_calloc(ncols, sizeof(double*));
for (j=0; j<ncols; ++j)
decision_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double)); /****NOTE: it's storage ****/
- positive_flow_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double));
- negative_flow_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double));
+ //positive_flow_vol[i][j]=G_malloc((ncriteria) * sizeof(double));
+ //negative_flow_vol[i][j]=G_malloc((ncriteria) * sizeof(double));
@@ -186,16 +186,18 @@
outrast_netflow = Rast_allocate_buf(DCELL_TYPE);
/* controlling, if we can write the raster */
- outrast_positive_flow = Rast_open_new(result_positive_flow, DCELL_TYPE);
- outrast_negative_flow = Rast_open_new(result_negative_flow, DCELL_TYPE);
- outrast_netflow = Rast_open_new(result_netflow, DCELL_TYPE);
+ outfd_positive_flow = Rast_open_new(result_positive_flow, DCELL_TYPE);
+ outfd_negative_flow = Rast_open_new(result_negative_flow, DCELL_TYPE);
+ outfd_netflow = Rast_open_new(result_netflow, DCELL_TYPE);
/*build a three dimensional matrix for storage all critera maps*/
+ G_message("Load data");
for (i=0;i<ncriteria;i++)
for (row1 = 0; row1 < nrows;row1++)
+ G_percent(row1, nrows, 2);
Rast_get_row(attributes[i].infd, attributes[i].inrast, row1,DCELL_TYPE);/* Reads appropriate information into the buffer buf associated with the requested row*/
/*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row);*/
for (col1 = 0; col1 < ncols; col1++)
@@ -206,17 +208,18 @@
- G_message("step started");
+ G_message("run algorithm");
build_flow_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol,positive_flow_vol, negative_flow_vol); /*scan all DCELL, make a pairwise comparatione, buil positive flow matrix*/
- G_message("step ended");
+ G_message("buil mcda maps");
for (row1 = 0; row1 < nrows; row1++)
- ((DCELL *) outrast_positive_flow)[col1] = (DCELL)positive_flow_vol[row1][col1][ncriteria];/*write positive flow map*/
- ((DCELL *) outrast_negative_flow)[col1] = (DCELL)negative_flow_vol[row1][col1][ncriteria];/*write negative flow map*/
+ ((DCELL *) outrast_positive_flow)[col1] = (DCELL)positive_flow_vol[row1][col1];/*write positive flow map*/
+ ((DCELL *) outrast_negative_flow)[col1] = (DCELL)negative_flow_vol[row1][col1];/*write negative flow map*/
Rast_put_row(outfd_positive_flow, outrast_positive_flow, DCELL_TYPE);
Rast_put_row(outfd_negative_flow, outrast_negative_flow, DCELL_TYPE);
Modified: grass-addons/grass7/raster/r.mcda.promethee/promethee.c
--- grass-addons/grass7/raster/r.mcda.promethee/promethee.c 2015-09-06 02:44:34 UTC (rev 66120)
+++ grass-addons/grass7/raster/r.mcda.promethee/promethee.c 2015-09-06 09:29:29 UTC (rev 66121)
@@ -9,7 +9,7 @@
@@ -50,7 +50,7 @@
int row1, col1, row2, col2;
int i;
@@ -66,37 +66,45 @@
for (row2 = 0; row2 < nrows; row2++)
+ //G_percent(row2, (nrows), 2);
for (col2 = 0; col2 < ncols; col2++)
threshold = (decision_vol[row1][col1][i] - decision_vol[row2][col2][i]);
+ //G_message("thersold:%f;r1:%d;c1:%d // r2:%d;c2:%d ",threshold,row1,col1,row2,col2);
if (threshold>0)
- positive_flow_vol[row1][col1][i]=threshold*weight_vect[i];
- negative_flow_vol[row1][col1][i]=0;
+ //positive_flow_vol[row1][col1][i]=threshold*weight_vect[i];
+ //negative_flow_vol[row1][col1][i]=0;
+ positive_flow_vol[row1][col1]=positive_flow_vol[row1][col1]+(threshold*weight_vect[i]);
+ negative_flow_vol[row1][col1]=negative_flow_vol[row1][col1];
else
- positive_flow_vol[row1][col1][i]=0;
- negative_flow_vol[row1][col1][i]=threshold*weight_vect[i];
+ negative_flow_vol[row1][col1]=negative_flow_vol[row1][col1]+(threshold*weight_vect[i]);
+ positive_flow_vol[row1][col1]=positive_flow_vol[row1][col1];
+ //positive_flow_vol[row1][col1][i]=0;
+ //negative_flow_vol[row1][col1][i]=threshold*weight_vect[i];
+ G_message("check");
/*storage preference value in decision_vol */
- for (row1 = 0; row1 < nrows; row1++)
+/* for (row1 = 0; row1 < nrows; row1++)
for ( i=0; i<ncriteria;i++)
- /*fill matrix with performance for each DCELL */
+ //fill matrix with performance for each DCELL
positive_flow_vol[row1][col1][ncriteria] = positive_flow_vol[row1][col1][ncriteria]+positive_flow_vol[row1][col1][i];
negative_flow_vol[row1][col1][ncriteria] = negative_flow_vol[row1][col1][ncriteria]+negative_flow_vol[row1][col1][i];
