[GRASS-SVN] r66138 - grass/trunk/lib/rst/interp_float
Sun Sep 6 21:47:34 PDT 2015
Author: wenzeslaus
Date: 2015-09-06 21:47:34 -0700 (Sun, 06 Sep 2015)
New Revision: 66138
   grass/trunk/lib/rst/interp_float/DESCRIPTION.INTERP
   grass/trunk/lib/rst/interp_float/func2d.c
   grass/trunk/lib/rst/interp_float/init2d.c
   grass/trunk/lib/rst/interp_float/input2d.c
   grass/trunk/lib/rst/interp_float/interp2d.c
   grass/trunk/lib/rst/interp_float/interpf.h
   grass/trunk/lib/rst/interp_float/matrix.c
   grass/trunk/lib/rst/interp_float/output2d.c
   grass/trunk/lib/rst/interp_float/point2d.c
   grass/trunk/lib/rst/interp_float/secpar2d.c
   grass/trunk/lib/rst/interp_float/segmen2d.c
   grass/trunk/lib/rst/interp_float/vinput2d.c
   grass/trunk/lib/rst/interp_float/write2d.c
dox: Doxygen documentation for lib rst interp float
Using existing documentation in source code or text files.
Inline Doxygen docs seems as appropriate for paramters since already used without Doxygen
but it requries slight divergence of what grass_indent would like to see.
Modified: grass/trunk/lib/rst/interp_float/DESCRIPTION.INTERP
--- grass/trunk/lib/rst/interp_float/DESCRIPTION.INTERP	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/DESCRIPTION.INTERP	2015-09-07 04:47:34 UTC (rev 66138)
@@ -10,110 +10,12 @@
 divided into several libraries to provide better
 functionality.
+V. Petras (2015): Removed all functions which are documented elsewhere
+in source code (Doxygen style) or clearly deleted. This file can be
+deleted after resolving IL_input_data_2d function.
+The TODO for changes 1997 still applies.
-DATA STRUCTURES:
-struct interp_params
-   double zmult;       /* multiplier for z-values */
-   FILE *fdinp;         /* input stream */
-   int kmin;           /* min number of points per segment for interpolation */
-   int kmax;           /* max number of points per segment */
-   char *maskmap;       /* name of mask */
-   int nsizr,nsizc;     /* number of rows and columns */
-   double *az,*adx,*ady,*adxx,*adyy,*adxy;  /* array for interpolated values */
-   double fi;                               /* tension */
-   int    KMAX2;                            /* max num. of points for interp.*/
-   int    scik1,scik2,scik3;                /* multipliers for interp. values*/
-   double        rsm;          /* smoothing, for rsm<0 use variable smooth from sites */
-   char   *elev,*slope,*aspect,*pcurv,*tcurv,*mcurv; /* output files */
-   double dmin;                             /* min distance between points */
-   double x_orig, y_orig;                   /* origin */
-   int    deriv;                            /* 1 if compute partial derivs */
-   FILE   *Tmp_fd_z,*Tmp_fd_dx,*Tmp_fd_dy,  /* temp files for writing interp.*/
-          *Tmp_fd_xx,*Tmp_fd_yy,*Tmp_fd_xy; /* values */
-   FILE   *fddevi;     /* pointer to deviations file */
-   int    (*grid_calc) ();                  /*calculates grid for given segm*/
-   int    (*matrix_create) ();              /*creates matrix for a given segm*/
-   int    (*check_points) ();               /*checks interp. func. at points */
-   int    (*secpar) ();                     /* calculates aspect,slope,curv. */
-   double (*interp) ();                     /* radial basis function */
-   int    (*interpder) ();                  /* derivatives of radial basis function */
-   int    (*wr_temp) ();                    /* writes temp files */
-   int c,                                   /* cross validation */
-   char *wheresql                           /* SQL WHERE */
-FUNCTIONS:
-void
-IL_init_params_2d(params,inp,zm,k1,k2,msk,rows,cols,ar1,ar2,ar3,ar4,ar5,ar6,
-                 tension,k3,sc1,sc2,sc3,sm,f1,f2,f3,f4,f5,f6,dm,x_or,y_or,
-                 der,t1,t2,t3,t4,t5,t6,dev)
-   struct interp_params *params;
-   FILE *inp;         /* input stream */
-   double zm;       /* multiplier for z-values */
-   int k1;           /* min number of points per segment for interpolation */
-   int k2;           /* max number of points per segment */
-   char *msk;       /* name of mask */
-   int rows,cols;     /* number of rows and columns */
-   double *ar1,*ar2,*ar3,*ar4,*ar5,*ar6;  /* arrays for interpolated values */
-   double tension;                              /* tension */
-   int    k3;                            /* max num. of points for interp.*/
-   int    sc1,sc2,sc3;                /* multipliers for interp. values*/
-   double        sm;               /* smoothing, if sm<0 take it from sites file input */
-   char   *f1,*f2,*f3,*f4,*f5,*f6;          /*output files */
-   double dm;                             /* min distance between points */
-   double x_or, y_or;                   /* origin */
-   int    der;                            /* 1 if compute partial derivs */
-   FILE   *t1,*t2,*t3,*t4,*t5,*t6;  /* temp files for writing interp. values */
-   FILE   *dev;     /* pointer to deviations file */
-Initializes parameters called by the library
-void
-IL_init_func_2d(params,grid_f,matr_f,point_f,secp_f,interp_f,
-                                                   interpder_f,temp_f)
-   int    (*grid_f) ();             /*calculates grid for given segm*/
-   int    (*matr_f) ();             /*creates matrix for a given segm*/
-   int    (*point_f) ();            /*checks interp. func. at points */
-   int    (*secp_f) ();             /* calculates aspect,slope,curv. */
-   double (*interp_f) ();           /* radial basis function*/
-   int    (*interpder_f) ();        /* derivatives of radial basis fucntion */
-   int    (*temp_f) ();             /* writes temp files */
-Initializes functions called by the library
-double
-IL_crst (r,fi)
-   double r;  /* distance squared*/
-Radial basis function - regularized spline with tension (d=2)
 int
-IL_crstg (r, fi, gd1, gd2)
-    double         *gd1;
-    double         *gd2;
-Derivatives of radial basis function - regularized spline with tension(d=2)
-int
 IL_input_data_2d(params,info,xmin,xmax,ymin,ymax,zmin,zmax,MAXPOINTS,n_points)
    struct tree_info *info;  /* quadtree info */
@@ -124,195 +26,3 @@
 Inserts input data inside the region into a quad tree.
 Also translates data.
 Returns number of segments in the quad tree.
-int IL_vector_input_data_2d(params,Map,dmax,cats,iselev,info,xmin,
-                     xmax,ymin,ymax,zmin,zmax,n_points)
-   struct Map_info *Map;    /* input vector file */
-   double dmax;             /* max distance between points */
-   struct Categories *cats; /* Cats file */
-   int    iselev;           /* do zeroes represent elevation? */
-   struct tree_info *info;  /* quadtree info */
-   double *xmin,*xmax,*ymin,*ymax,*zmin,*zmax;
-   int *n_points;      /* number of points used for interpolation */
-Inserts input data inside the region into a quad tree.
-Also translates data.
-Returns number of segments in the quad tree.
-struct BM *
-IL_create_bitmask(params)
-Creates a bitmap mask from maskmap raster file and/or current MASK if
-present and returns a pointer to the bitmask. If no mask is in force returns
-NULL.
-int
-IL_grid_calc_2d(params,data,bitmask,zmin,zmax,zminac,zmaxac,gmin,gmax,
-                              c1min,c1max,c2min,c2max,ertot,b,offset1)
-    struct quaddata *data;                   /* given segment */
-    struct BM *bitmask;                      /* bitmask */
-    double zmin,zmax;                        /* min and max input z-values */
-    double *zminac,*zmaxac,                  /* min and max interp. z-values */
-           *gmin,*gmax,                      /* min and max inperp. slope val.*/
-           *c1min,*c1max,*c2min,*c2max;      /* min and max interp. curv. val.*/
-    double *ertot;                           /* rms deviation of the interpolated surface */
-    double *b;                               /* solutions of linear equations */
-    int    offset1;                          /* offset for temp file writing */
-Calculates grid for the given segment represented by data (contains n_rows,
-n_cols, ew_res,ns_res, and all points inside + overlap) using solutions of
-system of lin. equations and interpolating functions interp() and interpder().
-Also calls secpar() to compute slope, aspect and curvatures if required.
-int
-IL_matrix_create(params,points,n_points,matrix,indx)
-    struct triple *points;           /* points for interpolation */
-    int           n_points;          /* number of points */
-    double       **matrix;           /* matrix */
-    int           *indx;
-Creates system of linear equations represented by matrix using given points
-and interpolating function interp()
-int
-IL_check_at_points_2d (params,n_points,points,b,ertot,zmin)
-    double        *b;          /* solution of linear equations */
-    double        zmin;        /* min z-value */
-Checks if interpolating function interp() evaluates correct z-values at given
-points. If smoothing is used calculate the maximum and rms deviation caused by smoothing.
-int
-IL_secpar_loop_2d(params,ngstc,nszc,k,bitmask,gmin,gmax,c1min,c1max,c2min,
-                                                         c2max,cond1,cond2)
-    int    ngstc;       /* starting column */
-    int    nszc;        /* ending column */
-    int    k;           /* current row */
-    double *gmin,*gmax,*c1min,*c1max,*c2min,*c2max; /* min,max interp. values */
-    int    cond1,cond2; /*determine if particular values need to be computed*/
-Computes slope, aspect and curvatures (depending on cond1, cond2) for derivative
-arrays adx,...,adxy between columns ngstc and nszc.
-int
-IL_write_temp_2d(params,ngstc,nszc,offset2)
-    int    ngstc,nszc,offset2;  /* begin. and end. column, offset */
-Writes az,adx,...,adxy into appropriate place (depending on ngstc, nszc and
-offset) in corresponding temp file */
-int
-IL_interp_segments_2d (params,info,tree,bitmask,zmin,zmax,zminac,zmaxac,
-               gmin,gmax,c1min,c1max,c2min,c2max,ertot,totsegm,offset1,dnorm)
-    struct tree_info *info;    /* info for the quad tree */
-    struct multtree *tree;    /* current leaf of the quad tree */
-    double *ertot;                           /* rms deviation of the interpolated surface*/
-    int    totsegm;                          /* total number of segments */
-    double dnorm;                            /* normalization factor */
-Recursively processes each segment in a tree by
-  a) finding points from neighbouring segments so that the total number of
-     points is between KMIN and KMAX2 by calling tree function MT_get_region().
-  b) creating and solving the system of linear equations using these points
-     and interp() by calling matrix_create() and G_ludcmp().
-  c) checking the interpolated values at given points by calling
-     check_points().
-  d) computing grid for this segment using points and interp() by calling
-     grid_calc().
-int
-IL_interp_segments_new_2d (params,info,tree,bitmask,
-         zmin,zmax,zminac,zmaxac,gmin,gmax,c1min,c1max,
-         c2min,c2max,ertot,totsegm,offset1,dnorm)
-The difference between this function and IL_interp_segments_2d() is making
-sure that additional points are taken from all directions, i.e. it finds
-equal number of points from neigbouring segments in each of 8 neigbourhoods.
-  c) checking the interpolated function values at points by calling
-     check_points().
-     grid_calc().
-int
-IL_output_2d (params,cellhd,zmin,zmax,zminac,zmaxac,c1min,c1max,c2min,c2max,
-                                               gmin,gmax,ertot,dnorm)
-    struct Cell_head *cellhd;   /* current region */
-    double zmin,zmax,           /* min,max input z-values */
-           zminac,zmaxac,c1min,c1max,  /* min,max interpolated values */
-           c2min,c2max,gmin,gmax;
-Creates output files as well as history files  and color tables for them.
Modified: grass/trunk/lib/rst/interp_float/func2d.c
--- grass/trunk/lib/rst/interp_float/func2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/func2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,36 +1,53 @@
+ * \file func2d.c
+ * \author
+ * Lubos Mitas (original program and various modifications)
- * Original program and various modifications:
- * Lubos Mitas
- * GRASS4.1 version of the program and GRASS4.2 modifications:
+ * \author
  * H. Mitasova,
- * I. Kosinovsky, D. Gerdes
- * D. McCauley
+ * I. Kosinovsky, D. Gerdes,
+ * D. McCauley
+ * (GRASS4.1 version of the program and GRASS4.2 modifications)
- * Copyright 1993, 1995:
+ * \author
  * L. Mitas ,
  * H. Mitasova ,
  * I. Kosinovsky,
  * D.Gerdes
- * D. McCauley
+ * D. McCauley (1993, 1995)
- * modified by McCauley in August 1995
- * modified by Mitasova in August 1995, Nov. 1996
+ * \author modified by McCauley in August 1995
+ * \author modified by Mitasova in August 1995, Nov. 1996
+ * \copyright
+ * (C) 1993-1999 by Lubos Mitas and the GRASS Development Team
+ * \copyright
+ * This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
 #include <stdio.h>
 #include <math.h>
 #include <grass/gis.h>
 #include <grass/interpf.h>
-double IL_crst(double r, double fi)
- * Radial basis function - completely regularized spline with
- * tension (d=2)
+/* parameter description from DESCRIPTION.INTERP */
+ * Radial basis function
+ * Radial basis function - completely regularized spline with tension (d=2)
+double IL_crst(double r,  /**< distance squared */
+               double fi  /**< tension */
     double rfsta2 = fi * fi * r / 4.;
@@ -81,15 +98,16 @@
-int IL_crstg(double r, double fi, double *gd1,	/* G1(r) */
-	     double *gd2	/* G2(r) */
  * Function for calculating derivatives (d=2)
+ * Derivatives of radial basis function - regularized spline with tension(d=2)
+int IL_crstg(double r,  /**< distance squared */
+             double fi,  /**< tension */
+             double *gd1,  /**< G1(r) */
+             double *gd2  /**< G2(r) */
     double r2 = r;
Modified: grass/trunk/lib/rst/interp_float/init2d.c
--- grass/trunk/lib/rst/interp_float/init2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/init2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,13 +1,23 @@
- * Written by H. Mitasova, I. Kosinovsky, D. Gerdes Fall 1993
- * Copyright 1993, H. Mitasova ,
- * I. Kosinovsky, and D.Gerdes
+ * \file init2d.c
- * modified by Brown in June 1999 - added elatt & smatt
+ * \brief Initialization of interpolation library data structures
+ * \author H. Mitasova, I. Kosinovsky, D. Gerdes Fall 1993 (original authors)
+ * \author modified by Brown in June 1999 - added elatt & smatt
+ * \copyright
+ * (C) 1993-1999 by Helena Mitasova and the GRASS Development Team
+ * \copyright
+ * for details.
 #include <stdio.h>
@@ -16,41 +26,38 @@
-void IL_init_params_2d(
-    /* initialize parameters */
-    struct interp_params *params,
-    FILE * inp,			/* input stream */
-    int elatt,			/* which fp att in sites file? 1 = first */
-    int smatt,			/* which fp att in sites file to use for
-				 * smoothing? (if zero use sm) 1 = first */
-    double zm,			/* multiplier for z-values */
-    int k1,			/* min number of points per segment for
-				 * interpolation */
-    int k2,			/* max number of points per segment */
-    char *msk,			/* name of mask */
-    int rows, int cols, 	/* number of rows and columns */
-    DCELL * ar1, DCELL * ar2,
-    DCELL * ar3, DCELL * ar4,
-    DCELL * ar5, DCELL * ar6,	/* arrays for interpolated values */
-    double tension,		/* tension */
-    int k3,			/* max num. of points for interp. */
-    int sc1, int sc2, int sc3,	/* multipliers for interp. values */
-    double sm,			/* smoothing */
-    char *f1, char *f2,
-    char *f3, char *f4,
-    char *f5, char *f6,		/* output files */
-    double dm,			/* min distance between points */
-    double x_or, double y_or,	/* origin */
-    int der,			/* 1 if compute partial derivs */
-    double tet,			/* anisotropy angle, 0=East,counter-clockwise */
-    double scl,			/* anisotropy scaling factor */
-    FILE * t1, FILE * t2,
-    FILE * t3, FILE * t4,
-    FILE * t5, FILE * t6,	/* temp files for writing interp. values */
-    FILE * dev,			/* pointer to deviations file */
-    struct TimeStamp *ts,
-    const char *wheresql	/* SQL WHERE */
+/*! Initializes parameters used by the library */
+void IL_init_params_2d(struct interp_params *params,
+                       FILE * inp,  /*!< input stream */
+                       int elatt,  /*!< which fp att in sites file? 1 = first */
+                       int smatt,  /*!< which fp att in sites file to use for
+                                         * smoothing? (if zero use sm) 1 = first */
+                       double zm,  /*!< multiplier for z-values */
+                       int k1,  /*!< min number of points per segment for interpolation */
+                       int k2,  /*!< max number of points per segment */
+                       char *msk,  /*!< name of mask */
+                       int rows, int cols,  /*!< number of rows and columns */
+                       DCELL * ar1, DCELL * ar2, DCELL * ar3, DCELL * ar4, DCELL * ar5,
+                       DCELL * ar6,  /*!< arrays for interpolated values (ar1-ar6) */
+                       double tension,  /*!< tension */
+                       int k3,  /*!< max number of points for interpolation */
+                       int sc1, int sc2, int sc3,  /*!< multipliers for interpolation values */
+                       double sm,  /*!< smoothing */
+                       char *f1, char *f2, char *f3, char *f4, char *f5,
+                       char *f6,  /*!< output files (f1-f6) */
+                       double dm,  /*!< min distance between points */
+                       double x_or,  /*!< x of origin */
+                       double y_or,  /*!< y of origin */
+                       int der,  /*!< 1 if compute partial derivatives */
+                       double tet,  /*!< anisotropy angle (0 is East, counter-clockwise) */
+                       double scl,  /*!< anisotropy scaling factor */
+                       FILE * t1, FILE * t2, FILE * t3, FILE * t4, FILE * t5,
+                       FILE * t6,  /*!< temp files for writing interp. values (t1-t6) */
+                       FILE * dev,  /*!< pointer to deviations file */
+                       struct TimeStamp *ts,
+                       int c,  /*!< cross validation */
+                       const char *wheresql     /*!< SQL WHERE statement */
     params->fdinp = inp;
@@ -98,16 +105,16 @@
     params->wheresql = wheresql;
+/*! Initializes functions used by the library  */
 void IL_init_func_2d(struct interp_params *params,
-		     grid_calc_fn *grid_f,	/* calculates grid for given segm */
-		     matrix_create_fn *matr_f,	/* creates matrix for a given segm */
-		     check_points_fn *point_f,	/* checks interp. func. at points */
-		     secpar_fn *secp_f,		/* calculates aspect,slope,curv. */
-		     interp_fn *interp_f,	/* radial  basis function */
-		     interpder_fn *interpder_f,	/* derivatives of radial basis func. */
-		     wr_temp_fn *temp_f		/* writes temp files */
+                     grid_calc_fn * grid_f,  /*!< calculates grid for given segment */
+                     matrix_create_fn * matr_f,  /*!< creates matrix for a given segment */
+                     check_points_fn * point_f,  /*!< checks interpolation function at points */
+                     secpar_fn * secp_f,  /*!< calculates aspect, slope, curvature */
+                     interp_fn * interp_f,  /*!< radial basis function */
+                     interpder_fn * interpder_f,  /*!< derivatives of radial basis function */
+                     wr_temp_fn * temp_f        /*!< writes temp files */
-/* initialize functions */
     params->grid_calc = grid_f;
     params->matrix_create = matr_f;
@@ -118,5 +125,3 @@
     params->wr_temp = temp_f;
Modified: grass/trunk/lib/rst/interp_float/input2d.c
--- grass/trunk/lib/rst/interp_float/input2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/input2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,16 +1,20 @@
- * University of Illinois
- * US Army Construction Engineering Research Lab
- * Copyright 1993, H. Mitasova (University of Illinois),
- * I. Kosinovsky, (USA-CERL), and D.Gerdes (USA-CERL)
+ * \file input2d.c
- * modified by Mitasova in November 1996 to include variable smoothing
+ * \copyright
+ * \copyright
+ * for details.
@@ -25,9 +29,15 @@
 #include <grass/glocale.h>
+ * Creates a bitmap mask from given raster map
+ * Creates a bitmap mask from maskmap raster file and/or current MASK if
+ * present and returns a pointer to the bitmask. If no mask is in force
+ * returns NULL.
 struct BM *IL_create_bitmask(struct interp_params *params)
-/** Creates a bitmap mask from given raster map **/
     int i, j, cfmask = -1, irev, MASKfd;
     const char *mapsetm;
Modified: grass/trunk/lib/rst/interp_float/interp2d.c
--- grass/trunk/lib/rst/interp_float/interp2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/interp2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,25 +1,38 @@
+ * \file interp2d.c
- * Lubos Mitas
+ * \author
+ * \author
  * H. Mitasova,
- * D. McCauley
+ * D. McCauley
- * L. Mitas ,
+ * \author
+ * L. Mitas,
  * H. Mitasova,
  * I. Kosinovsky,
- * D.Gerdes
+ * D.Gerdes,
  * D. McCauley
+ * (1993, 1995)
- * bug fixes(mask) and modif. for variable smoothing Mitasova Jan 1997
+ * \author
+ * bug fixes(mask) and modification for variable smoothing
+ * Mitasova (Jan 1997)
+ * \copyright
+ * \copyright
+ * for details.
@@ -38,24 +51,29 @@
 #define CEULER .57721566
-int IL_grid_calc_2d(struct interp_params *params, struct quaddata *data,	/* given segment */
-		    struct BM *bitmask,	/* bitmask */
-		    double zmin, double zmax,	/* min and max input z-values */
-		    double *zminac, double *zmaxac,	/* min and max interp. z-values */
-		    double *gmin, double *gmax,	/* min and max inperp. slope val. */
-		    double *c1min, double *c1max, double *c2min, double *c2max,	/* min and max interp. curv. val. */
-		    double *ertot,	/* total interplating func. error */
-		    double *b,	/* solutions of linear equations */
-		    off_t offset1,	/* offset for temp file writing */
-		    double dnorm)
+ * Calculates grid values for a given segment
  * Calculates grid for the given segment represented by data (contains
  * n_rows, n_cols, ew_res,ns_res, and all points inside + overlap) using
- * solutions of system of lin. equations and interpolating functions
+ * solutions of system of linear equations and interpolating functions
  * interp() and interpder(). Also calls secpar() to compute slope, aspect
  * and curvatures if required.
+ * *ertot* can be also called *RMS deviation of the interpolated surface*
+int IL_grid_calc_2d(struct interp_params *params,
+                    struct quaddata *data,  /*!< given segment */
+                    struct BM *bitmask,  /*!< bitmask */
+                    double zmin, double zmax,  /*!< min and max input z-values */
+                    double *zminac, double *zmaxac,  /*!< min and max interp. z-values */
+                    double *gmin, double *gmax,  /*!< min and max interp. slope val. */
+                    double *c1min, double *c1max,  /*!< min and max interp. curv. val. */
+                    double *c2min, double *c2max,  /*!< min and max interp. curv. val. */
+                    double *ertot,  /*!< total interpolating func. error */
+                    double *b,  /*!< solutions of linear equations */
+                    off_t offset1,  /*!< offset for temp file writing */
+                    double dnorm)
Modified: grass/trunk/lib/rst/interp_float/interpf.h
--- grass/trunk/lib/rst/interp_float/interpf.h	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/interpf.h	2015-09-07 04:47:34 UTC (rev 66138)
@@ -67,41 +67,41 @@
-    int elatt;			/* which floating point attr to use? first = 1, second = 2, etc */
-    int smatt;			/* which floating point attr to use for smoothing? first = 1, second = 2, etc */
-    int nsizr, nsizc;		/* number of rows and columns */
+    double zmult;		/**< multiplier for z-values */
+    FILE *fdinp;		/**< input stream */
+    int elatt;			/**< which floating point attr to use? first = 1, second = 2, etc */
+    int smatt;			/**< which floating point attr to use for smoothing? first = 1, second = 2, etc */
+    int kmin;			/**< min number of points per segment for interpolation */
+    int kmax;			/**< max number of points per segment */
+    char *maskmap;		/**< name of mask */
+    int nsizr, nsizc;		/**< number of rows and columns */
     DCELL *az, *adx, *ady,
-	*adxx, *adyy, *adxy;	/* array for interpolated values */
-    int KMAX2;			/* max num. of points for interp. */
-    int scik1, scik2, scik3;	/* multipliers for interp. values */
-    double rsm;			/* smoothing */
+	*adxx, *adyy, *adxy;	/**< array for interpolated values */
+    double fi;			/**< tension */
+    int KMAX2;			/**< max num. of points for interp. */
+    int scik1, scik2, scik3;	/**< multipliers for interp. values */
+    double rsm;			/**< smoothing */
     char *elev, *slope, *aspect,
-	*pcurv, *tcurv, *mcurv;	/* output files */
-    int deriv, cv;		/* 1 if compute partial derivs */
-    double theta;		/* anisotropy angle, 0=East,counter-clockwise */
-    double scalex;		/* anisotropy scaling factor */
-    struct TimeStamp *ts;	/* timestamp for raster files */
+	*pcurv, *tcurv, *mcurv;	/**< output files */
+    double dmin;		/**< min distance between points */
+    double x_orig, y_orig;	/**< origin */
+    int deriv, cv;		/**< 1 if compute partial derivs */
+    double theta;		/**< anisotropy angle, 0=East,counter-clockwise */
+    double scalex;		/**< anisotropy scaling factor */
+    struct TimeStamp *ts;	/**< timestamp for raster files */
     FILE *Tmp_fd_z, *Tmp_fd_dx,
 	*Tmp_fd_dy, *Tmp_fd_xx,
-	*Tmp_fd_yy, *Tmp_fd_xy;	/* temp files for writing interp. values */
+	*Tmp_fd_yy, *Tmp_fd_xy;	/**< temp files for writing interp. values */
+    FILE *fddevi;		/**< pointer to deviations file */
-    grid_calc_fn *grid_calc;	/*calculates grid for given segm */
-    matrix_create_fn *matrix_create;	/*creates matrix for a given segm */
-    check_points_fn *check_points;	/*checks interp. func. at points */
-    secpar_fn *secpar;		/* calculates aspect,slope,curv. */
-    interp_fn *interp;		/* radial  based interp. function */
-    interpder_fn *interpder;	/* interp. func. for derivatives */
-    wr_temp_fn *wr_temp;	/* writes temp files */
-    const char *wheresql;	/* SQL statement to select input points */
+    grid_calc_fn *grid_calc;	/**< calculates grid for given segm */
+    matrix_create_fn *matrix_create;	/**< creates matrix for a given segm */
+    check_points_fn *check_points;	/**< checks interp. func. at points */
+    secpar_fn *secpar;		/**< calculates aspect,slope,curv. */
+    interp_fn *interp;		/**< radial  based interp. function */
+    interpder_fn *interpder;	/**< interp. func. for derivatives */
+    wr_temp_fn *wr_temp;	/**< writes temp files */
+    const char *wheresql;	/**< SQL statement to select input points */
 /* distance.c */
Modified: grass/trunk/lib/rst/interp_float/matrix.c
--- grass/trunk/lib/rst/interp_float/matrix.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/matrix.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,23 +1,33 @@
- * Lubos Mitas
+ * \author
+ * \author
  * H. Mitasova,
- * D. McCauley
+ * D. McCauley
- * L. Mitas ,
- * H. Mitasova ,
+ * \author
+ * L. Mitas,
+ * H. Mitasova,
  * I. Kosinovsky,
- * D.Gerdes
- * D. McCauley
+ * D.Gerdes,
+ * D. McCauley
+ * (1993, 1995)
+ * \copyright
+ * (C) 1993-1996 by Lubos Mitas and the GRASS Development Team
+ * \copyright
+ * This program is free software under the  GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS for details.
 #include <stdio.h>
 #include <math.h>
 #include <unistd.h>
@@ -25,6 +35,7 @@
 #include <grass/gmath.h>
  * \brief Creates system of linear equations from interpolated points
@@ -32,9 +43,10 @@
  * points and interpolating function interp()
  * \param params struct interp_params *
- * \param points struct triple * :  points for interpolation
- * \param n_points int :  number of points
- * \param matrix double **
+ * \param points points for interpolation as struct triple
+ * \param n_points number of points
+ * \param[out] matrix the matrix
+ * \param indx
  * \return -1 on failure, 1 on success
@@ -43,10 +55,6 @@
 		     int n_points,	/* number of points */
 		     double **matrix,	/* matrix */
 		     int *indx)
-   Creates system of linear equations represented by matrix using given points
-   and interpolating function interp()
     double xx, yy;
     double rfsta2, r;
Modified: grass/trunk/lib/rst/interp_float/output2d.c
--- grass/trunk/lib/rst/interp_float/output2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/output2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,18 +1,22 @@
- * Written by H. Mitasova, I. Kosinovsky, D. Gerdes Summer 1992
- * Copyright 1992, H. Mitasova
+ * \file output2d.c
- * modified by Mitasova in August 1999 (fix for elev color)
- * modified by Brown in September 1999 (fix for Timestamps)
- * Modified by Mitasova in Nov. 1999 (write given tension into hist)
- * Last modification: 2006-12-13
+ * \author H. Mitasova, I. Kosinovsky, D. Gerdesm, Summer 1992 (original authors)
+ * \author modified by Mitasova in August 1999 (fix for elev color)
+ * \author modified by Brown in September 1999 (fix for Timestamps)
+ * \author modified by Mitasova in Nov. 1999 (write given tension into hist)
+ * \copyright
+ * (C) 1992-2006 by Helena Mitasova and the GRASS Development Team
+ * \copyright
 #include <stdio.h>
 #include <math.h>
@@ -46,17 +50,24 @@
     Rast_free_history(&hist);
-int IL_output_2d(struct interp_params *params, struct Cell_head *cellhd,	/* current region */
-		 double zmin, double zmax,	/* min,max input z-values */
-		 double zminac, double zmaxac, double c1min, double c1max,	/* min,max interpolated values */
-		 double c2min, double c2max, double gmin, double gmax, double ertot,	/* total interplating func. error */
-		 char *input,	/* input file name */
-		 double dnorm, int dtens, int vect, int n_points)
- * Creates output files as well as history files  and color tables for
- * them.
+ * Creates output files as well as history files and color tables for them.
+ * *ertot* can be also called *RMS deviation of the interpolated surface*.
+int IL_output_2d(struct interp_params *params,
+                 struct Cell_head *cellhd,  /*!< current region */
+                 double zmin, double zmax,  /*!< min,max input z-values */
+                 double zminac, double zmaxac,
+                 double c1min, double c1max,  /*!< min,max interpolated values */
+                 double c2min, double c2max,
+                 double gmin, double gmax,
+                 double ertot,  /*!< total interpolating func. error */
+                 char *input,  /*!< input file name */
+                 double dnorm,  /*!< normalization factor */
+                 int dtens, int vect, int n_points
     FCELL *cell1;
     int cf1 = -1, cf2 = -1, cf3 = -1, cf4 = -1, cf5 = -1, cf6 = -1;
Modified: grass/trunk/lib/rst/interp_float/point2d.c
--- grass/trunk/lib/rst/interp_float/point2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/point2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,24 +1,26 @@
+ * \file point2d.c
- * Lubos Mitas
+ * \author
- * H. Mitasova
- * D. McCauley
- * L. Mitas ,
- * H. Mitasova ,
- * I. Kosinovsky, ,
- * D.Gerdes
+ * \author
+ * H. Mitasova,
+ * I. Kosinovsky,
+ * D. Gerdes,
  * D. McCauley
+ * \copyright
+ * (C) 1993-2006 by Helena Mitasova and the GRASS Development Team
+ * \copyright
@@ -37,17 +39,25 @@
 #undef hz
 #endif
-int IL_check_at_points_2d(struct interp_params *params, struct quaddata *data,	/* current region */
-			  double *b,	/* solution of linear equations */
-			  double *ertot,	/* total error */
-			  double zmin,	/* min z-value */
-			  double dnorm, struct triple skip_point)
  * Checks if interpolating function interp() evaluates correct z-values at
  * given points. If smoothing is used calculate the maximum error caused
  * by smoothing.
+ * *ertot* is a RMS deviation of the interpolated surface.
+ * \todo
+ * Alternative description:
+ * ...calculate the maximum and RMS deviation caused by smoothing.
+int IL_check_at_points_2d(struct interp_params *params,
+                          struct quaddata *data,  /*!< current region */
+                          double *b,  /*!< solution of linear equations */
+                          double *ertot,  /*!< total error */
+                          double zmin,  /*!< min z-value */
+                          double dnorm,
+                          struct triple skip_point
     int n_points = data->n_points;	/* number of points */
     struct triple *points = data->points;	/* points for interpolation */
Modified: grass/trunk/lib/rst/interp_float/secpar2d.c
--- grass/trunk/lib/rst/interp_float/secpar2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/secpar2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,17 +1,27 @@
- * Written by H. Mitasova, L. Mitas, I. Kosinovsky, D. Gerdes Fall 1994
- * Copyright 1994, H. Mitasova (University of Illinois),
- * L. Mitas (University of Illinois),
+ * \file secpar2d.c
+ * \author H. Mitasova, L. Mitas, I. Kosinovsky, D. Gerdes Fall 1994 (original authors)
+ * \author H. Mitasova (University of Illinois)
+ * \author L. Mitas (University of Illinois)
+ * \author I. Kosinovsky, (USA-CERL)
+ * \author D.Gerdes (USA-CERL)
+ * \copyright
+ * (C) 1994-1995 by Helena Mitasova and the GRASS Development Team
+ * \copyright
+ * for details.
 #include <stdio.h>
 #include <math.h>
 #include <unistd.h>
@@ -19,19 +29,24 @@
 #include <grass/bitmap.h>
-int IL_secpar_loop_2d(struct interp_params *params, int ngstc,	/* starting column */
-		      int nszc,	/* ending column */
-		      int k,	/* current row */
-		      struct BM *bitmask, double *gmin, double *gmax, double *c1min, double *c1max, double *c2min, double *c2max,	/* min,max interp.
-																	 * values */
-		      int cond1, int cond2	/* determine if particular values need to
-						 * be computed */
+ * Compute slope aspect and curvatures
  * Computes slope, aspect and curvatures (depending on cond1, cond2) for
  * derivative arrays adx,...,adxy between columns ngstc and nszc.
+int IL_secpar_loop_2d(struct interp_params *params,
+                      int ngstc,  /*!< starting column */
+                      int nszc,  /*!< ending column */
+                      int k,  /*!< current row */
+                      double *c2min, double *c2max,  /*!< min,max interp. values */
+                      int cond1,
+                      int cond2  /*!< determine if particular values need to be computed */
     double dnorm1, ro,		/* rad to deg conv */
       dx2 = 0, dy2 = 0, grad2 = 0,	/* gradient squared */
Modified: grass/trunk/lib/rst/interp_float/segmen2d.c
--- grass/trunk/lib/rst/interp_float/segmen2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/segmen2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,8 +1,20 @@
- **  Written by H. Mitasova, I. Kosinovsky, D. Gerdes Fall 1993
- **  Copyright  H. Mitasova, I. Kosinovsky, D.Gerdes
+ * \file segmen2d.c
+ * \copyright
+ * (C) 1993 by Helena Mitasova and the GRASS Development Team
+ * \copyright
+ * for details.
 #include <stdio.h>
 #include <stdlib.h>
 #include <math.h>
@@ -14,34 +26,39 @@
 static double smallest_segment(struct multtree *, int);
+ * Interpolate recursively a tree of segments
  *  Recursively processes each segment in a tree by:
- *  a) finding points from neighbouring segments so that the total number of
- *  points is between KMIN and KMAX2 by calling tree function MT_get_region().
- *  b) creating and solving the system of linear equations using these points
- *  and interp() by calling matrix_create() and G_ludcmp().
- *  c) checking the interpolating function values at points by calling
- *  check_points().
- *  d) computing grid for this segment using points and interp() by calling
- *  grid_calc().
+ *  - finding points from neighbouring segments so that the total number of
+ *    points is between KMIN and KMAX2 by calling tree function MT_get_region().
+ *  - creating and solving the system of linear equations using these points
+ *    and interp() by calling matrix_create() and G_ludcmp().
+ *  - checking the interpolating function values at points by calling
+ *    check_points().
+ *  - computing grid for this segment using points and interp() by calling
+ *    grid_calc().
+ * \todo
+ * Isn't this in fact the updated version of the function (IL_interp_segments_new_2d)?
+ * The function IL_interp_segments_new_2d has the following, better behavior:
+ * The difference between this function and IL_interp_segments_2d() is making
+ * sure that additional points are taken from all directions, i.e. it finds
+ * equal number of points from neighboring segments in each of 8 neighborhoods.
-int IL_interp_segments_2d(struct interp_params *params, struct tree_info *info,	/* info for the quad tree */
-			  struct multtree *tree,	/* current leaf of the quad tree */
-			  int totsegm,		/* total number of segments */
-			  double dnorm)
+int IL_interp_segments_2d(struct interp_params *params,
+                          struct tree_info *info,  /*!< info for the quad tree */
+                          struct multtree *tree,  /*!< current leaf of the quad tree */
+                          double *gmin, double *gmax,  /*!< min and max inperp. slope val. */
+                          double *ertot,  /*!< total interplating func. error */
+                          int totsegm,  /*!< total number of segments */
+                          double dnorm)
     double xmn, xmx, ymn, ymx, distx, disty, distxp, distyp, temp1, temp2;
     int i, npt, nptprev, MAXENC;
Modified: grass/trunk/lib/rst/interp_float/vinput2d.c
--- grass/trunk/lib/rst/interp_float/vinput2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/vinput2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,15 +1,28 @@
+ * \file vinput2d.c
+ * \author
+ * US Army Construction Engineering Research Lab
+ * \author
+ * Mitasova (University of Illinois),
+ * I. Kosinovsky, (USA-CERL), and D.Gerdes (USA-CERL)
- * modofied by Mitasova in Nov 1999 (dmax fix)
+ * \author modofied by Mitasova in Nov 1999 (dmax fix)
+ * \copyright
+ * \copyright
+ * for details.
 #include <stdio.h>
@@ -24,21 +37,29 @@
-int IL_vector_input_data_2d(struct interp_params *params, struct Map_info *Map,	/* input vector map */
-			    /* as z values may be used: 1) z coordinates in 3D file -> field = 0
-			     *                          2) categories -> field > 0, zcol = NULL
-			     *                          3) attributes -> field > 0, zcol != NULL */
-			    int field,	/* category field number */
-			    char *zcol,	/* name of the column containing z values */
-			    char *scol,	/* name of the column containing smooth values */
-			    struct tree_info *info,	/* quadtree info */
-			    double *xmin, double *xmax, double *ymin, double *ymax, double *zmin, double *zmax, int *n_points,	/* number of points used for interpolation */
-			    double *dmax)
+ * Insert into a quad tree
  * Inserts input data inside the region into a quad tree. Also translates
  * data. Returns number of segments in the quad tree.
+ * As z values may be used (in *Map*):
+ * - z coordinates in 3D file -> field = 0
+ * - categories -> field > 0, zcol = NULL
+ * - attributes -> field > 0, zcol != NULL
+int IL_vector_input_data_2d(struct interp_params *params, /*!< interpolation parameters */
+                            struct Map_info *Map,  /*!< input vector map */
+                            int field,  /*!< category field number */
+                            char *zcol,  /*!< name of the column containing z values */
+                            char *scol,  /*!< name of the column containing smooth values */
+                            struct tree_info *info,  /*!< quadtree info */
+                            double *xmin, double *xmax,
+                            double *ymin, double *ymax,
+                            double *zmin, double *zmax,
+                            int *n_points,  /*!< number of points used for interpolation */
+                            double *dmax  /*!< max distance between points */
     double dmax2;		/* max distance between points squared */
     double c1, c2, c3, c4;
Modified: grass/trunk/lib/rst/interp_float/write2d.c
--- grass/trunk/lib/rst/interp_float/write2d.c	2015-09-07 04:23:32 UTC (rev 66137)
+++ grass/trunk/lib/rst/interp_float/write2d.c	2015-09-07 04:47:34 UTC (rev 66138)
@@ -1,16 +1,23 @@
+ * \copyright
+ * (C) 1993-1995 by Helena Mitasova and the GRASS Development Team
+ * \copyright
 #include <grass/config.h>
 #include <stdio.h>
 #include <math.h>
@@ -20,11 +27,17 @@
+/* parameter descriptions takes from a strange comment */
  * Writes az,adx,...,adxy into appropriate place (depending on ngstc, nszc
  * and offset) in corresponding temp file
-int IL_write_temp_2d(struct interp_params *params, int ngstc, int nszc, off_t offset2)	/* begin. and end. column, offset */
+int IL_write_temp_2d(struct interp_params *params,
+                     int ngstc,  /*!< begin. column */
+                     int nszc,  /*!<  end. column */
+                     off_t offset2  /*!< offset */
     int j;
     static FCELL *array_cell = NULL;
