[GRASS-SVN] r66151 - grass/trunk/raster/r.in.lidar
    svn_grass at osgeo.org
    Tue Sep  8 20:29:32 PDT 2015
Author: wenzeslaus
Date: 2015-09-08 20:29:32 -0700 (Tue, 08 Sep 2015)
New Revision: 66151
   grass/trunk/raster/r.in.lidar/Makefile
   grass/trunk/raster/r.in.lidar/main.c
r.in.lidar: use segment lib to enable different resolution for output
Using Segment library is easier than implementing another segmentation
similar to the existing one (based on rows); the impl. would also require
way of getting the right row/col based on corrdinates.
Leaving there the raster row based approach for cases when resolution
of output is not set. It is faster since it does not create the segments.
This fixes segfault and fatal when the resolution option was lower or
higher than the current one (introduced in r66094).
Deliberately not using the old formatting style.
Modified: grass/trunk/raster/r.in.lidar/Makefile
--- grass/trunk/raster/r.in.lidar/Makefile	2015-09-08 16:35:14 UTC (rev 66150)
+++ grass/trunk/raster/r.in.lidar/Makefile	2015-09-09 03:29:32 UTC (rev 66151)
@@ -2,8 +2,8 @@
 PGM = r.in.lidar
-LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB) $(GPROJLIB) $(LASLIBS)
-DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB) $(GPROJLIB) $(LASLIBS) $(SEGMENTLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP) $(SEGMENTDEP)
 EXTRA_INC = $(PROJINC) $(LASINC)
 EXTRA_CFLAGS = $(GDALCFLAGS)
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c	2015-09-08 16:35:14 UTC (rev 66150)
+++ grass/trunk/raster/r.in.lidar/main.c	2015-09-09 03:29:32 UTC (rev 66151)
@@ -24,6 +24,7 @@
 #include <sys/types.h>
 #include <grass/gis.h>
 #include <grass/raster.h>
+#include <grass/segment.h>
 #include <grass/gprojects.h>
 #include <grass/glocale.h>
 #include <liblas/capi/liblas.h>
@@ -110,10 +111,12 @@
     RASTER_MAP_TYPE rtype, base_raster_data_type;
     struct History history;
     char title[64];
+    SEGMENT base_segment;
     void *n_array, *min_array, *max_array, *sum_array, *sumsq_array,
         *index_array, *base_array;
     void *raster_row, *ptr;
     struct Cell_head region;
+    struct Cell_head input_region;
     int rows, cols;		/* scan box size */
     int row, col;		/* counters */
@@ -648,11 +651,34 @@
     npasses = (int)ceil(1.0 * region.rows / rows);
+    /* using row-based chunks (used for output) when input and output
+     * region matches and using segment library when they don't */
+    int use_segment = 0;
+    if (base_raster_opt->answer && res_opt->answer)
+        use_segment = 1;
     if (base_raster_opt->answer) {
         /* TODO: do we need to test existence first? mapset? */
         base_raster = Rast_open_old(base_raster_opt->answer, "");
         base_raster_data_type = Rast_get_map_type(base_raster);
+    if (base_raster_opt->answer && use_segment) {
+        Rast_get_input_window(&input_region);  /* we have split window */
+        /* TODO: these numbers does not fit with what we promise about percentage */
+        int segment_rows = 64;
+        /* writing goes row by row, so we use long segments as well */
+        int segment_cols = cols;
+        int segments_in_memory = 4;
+        if (Segment_open(&base_segment, G_tempfile(), input_region.rows, input_region.cols,
+                segment_rows, segment_cols,
+                Rast_cell_size(base_raster_data_type), segments_in_memory) != 1)
+            G_fatal_error(_("Cannot create temporary file with segments of a raster map"));
+        for (row = 0; row < input_region.rows; row++) {
+            raster_row = Rast_allocate_input_buf(base_raster_data_type);
+            Rast_get_row(base_raster, raster_row, row, base_raster_data_type);
+            Segment_put_row(&base_segment, raster_row, row);
+        Rast_close(base_raster);  /* we won't need the raster again */
     if (!scan_flag->answer) {
 	/* check if rows * (cols + 1) go into a size_t */
@@ -678,7 +704,7 @@
 	if (bin_index)
 	    index_array =
 		G_calloc((size_t)rows * (cols + 1), Rast_cell_size(CELL_TYPE));
-	if (base_raster_opt->answer)
+	if (base_raster_opt->answer && !use_segment)
 	    base_array = G_calloc((size_t)rows * (cols + 1), Rast_cell_size(base_raster_data_type));
 	/* we don't free the raster, we just use it again */
 	/* TODO: perhaps none of them needs to be freed */
@@ -881,6 +907,41 @@
                 z -= base_z;
+            else if (use_segment) {
+                double base_z;
+                off_t base_row = Rast_northing_to_row(y, &input_region);
+                off_t base_col = Rast_easting_to_col(x, &input_region);
+                /* skip points which are outside the base raster
+                 * (null propagation) */
+                if (base_row < 0 || base_col < 0 ||
+                        base_row >= input_region.rows ||
+                        base_col >= input_region.cols)
+                    continue;
+                if (base_raster_data_type == DCELL_TYPE) {
+                    DCELL value;
+                    Segment_get(&base_segment, &value, base_row, base_col);
+                    if (Rast_is_null_value(&value, base_raster_data_type))
+                        continue;
+                    base_z = value;
+                else if (base_raster_data_type == FCELL_TYPE) {
+                    FCELL value;
+                        continue;
+                    base_z = value;
+                else {
+                    CELL value;
+                        continue;
+                    base_z = value;
+                z -= base_z;
             if (zrange_opt->answer) {
                 if (z < zrange_min || z > zrange_max) {
@@ -1255,6 +1316,8 @@
 	if (base_array)
+        if (use_segment)
+            Segment_close(&base_segment);
     }				/* passes loop */
     G_percent(1, 1, 1);		/* flush */
