[GRASS-SVN] r66158 - grass/branches/releasebranch_7_0/vector/v.what.rast
Thu Sep 10 03:51:40 PDT 2015
Author: neteler
Date: 2015-09-10 03:51:40 -0700 (Thu, 10 Sep 2015)
New Revision: 66158
   grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html
v.what.rast manual: improved examples
Modified: grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html
--- grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html	2015-09-10 10:51:03 UTC (rev 66157)
+++ grass/branches/releasebranch_7_0/vector/v.what.rast/v.what.rast.html	2015-09-10 10:51:40 UTC (rev 66158)
@@ -43,37 +43,52 @@
 <h2>EXAMPLES</h2>
-A) Reading values from raster map at position of vector points,
-   writing these values into a column of the attribute table
-   connected to the vector map:
-<br>
+<h3>Transferring raster values into existing attribute table of vector points map</h3>
+Reading values from raster map at position of vector points,
+writing these values into a column of the attribute table
+connected to the vector map:
+<p>
 <div class="code"><pre>
-v.what.rast map=pnts raster=elevation column=heights
+# work on copy of original geodetic points map
+g.copy vector=geodetic_pts,mygeodetic_pts
+# set computational region to raster map to be queried
+g.region raster=elev_state_500m -p
+# add new column to existing table
+v.db.addcolumn map=mygeodetic_pts column="height double precision"
+v.what.rast map=mygeodetic_pts raster=elev_state_500m column=height
+# compare official geodetic heights to those of elevation model
+v.db.select map=mygeodetic_pts columns=Z_VALUE,height separator=comma
 </pre></div>
+<h3>Transferring raster values into new vector points map</h3>
+In case of a vector map without attached attribute table, first add
+a new attribute table. This table is then populated with values
+queried from the raster map:
 <p>
-B) In case of a vector map without attached attribute table, first add
-   a new attribute table. This table is then populated with values
-   queried from the raster map:
-<br>
 # create new random vector points map
 v.random pnts n=100
 # add new table, link to map
-v.db.addtable pnts column="heights double precision"
+v.db.addtable map=pnts column="height double precision"
+g.region raster=elevation -p
 # query raster map and upload values to vector table into specified column
-g.region raster=elevation -p
+v.what.rast map=pnts raster=elevation column=height
 # verify new attribute table:
 v.db.select pnts
 # verify statistics of uploaded values:
-v.univar map=pnts column=heights type=point
+v.univar map=pnts column=height type=point
 </pre></div>
