[GRASS-SVN] r66169 - grass/trunk/raster/r.watershed/front
Fri Sep 11 08:06:18 PDT 2015
Author: neteler
Date: 2015-09-11 08:06:18 -0700 (Fri, 11 Sep 2015)
New Revision: 66169
   grass/trunk/raster/r.watershed/front/main.c
   grass/trunk/raster/r.watershed/front/r.watershed.html
r.watershed manual: mention 'depression' parameter properly
Modified: grass/trunk/raster/r.watershed/front/main.c
--- grass/trunk/raster/r.watershed/front/main.c	2015-09-11 02:25:09 UTC (rev 66168)
+++ grass/trunk/raster/r.watershed/front/main.c	2015-09-11 15:06:18 UTC (rev 66169)
@@ -314,7 +314,9 @@
     new_argv[new_argc++] = NULL;
     G_debug(1, "Mode: %s", flag_seg->answer ? "Segmented" : "All in RAM");
+/*    if (flag_seg->answer)
+       G_message(_("Using memory cache size: %.1f MB"), atof(opt16->answer));
     ret = G_vspawn_ex(new_argv[0], new_argv);
     if (ret != EXIT_SUCCESS)
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html	2015-09-11 02:25:09 UTC (rev 66168)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html	2015-09-11 15:06:18 UTC (rev 66169)
@@ -59,7 +59,8 @@
 the module uses a least-cost algorithm.
 <p>
-Map of actual depressions or sinkholes in the landscape that are large
+Option <b>depression</b> specifies the optional map of actual
+depressions or sinkholes in the landscape that are large
 enough to slow and store surface runoff from a storm event.  All cells
 that are not NULL and not zero indicate depressions. Water will flow
 into but not out of depressions.
