[GRASS-SVN] r66181 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Sat Sep 12 11:35:45 PDT 2015
Author: wenzeslaus
Date: 2015-09-12 11:35:45 -0700 (Sat, 12 Sep 2015)
New Revision: 66181
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: add decimation based on counting
Simple decimation using skipping or preserving every n-nt,
ignoring points at the beginning or limiting number of points.
Four new options added to group Decimation.
The rest reordered and put into groups Selection and Speed.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-09-12 18:05:17 UTC (rev 66180)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-09-12 18:35:45 UTC (rev 66181)
@@ -112,6 +112,7 @@
float xmin = 0., ymin = 0., xmax = 0., ymax = 0.;
struct GModule *module;
struct Option *in_opt, *out_opt, *spat_opt, *filter_opt, *class_opt;
+ struct Option *skip_opt, *preserve_opt, *offset_opt, *limit_opt;
struct Option *outloc_opt;
struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
struct Flag *over_flag, *extend_flag, *no_import_flag;
@@ -171,17 +172,10 @@
spat_opt->required = NO;
spat_opt->key_desc = "xmin,ymin,xmax,ymax";
spat_opt->label = _("Import subregion only");
- spat_opt->guisection = _("Subregion");
+ spat_opt->guisection = _("Selection");
spat_opt->description =
_("Format: xmin,ymin,xmax,ymax - usually W,S,E,N");
- outloc_opt = G_define_option();
- outloc_opt->key = "location";
- outloc_opt->type = TYPE_STRING;
- outloc_opt->required = NO;
- outloc_opt->description = _("Name for new location to create");
- outloc_opt->key_desc = "name";
filter_opt = G_define_option();
filter_opt->key = "return_filter";
filter_opt->type = TYPE_STRING;
@@ -189,6 +183,7 @@
filter_opt->label = _("Only import points of selected return type");
filter_opt->description = _("If not specified, all points are imported");
filter_opt->options = "first,last,mid";
+ filter_opt->guisection = _("Selection");
class_opt = G_define_option();
class_opt->key = "class_filter";
@@ -198,33 +193,82 @@
class_opt->label = _("Only import points of selected class(es)");
class_opt->description = _("Input is comma separated integers. "
"If not specified, all points are imported.");
+ class_opt->guisection = _("Selection");
+ skip_opt = G_define_option();
+ skip_opt->key = "skip";
+ skip_opt->type = TYPE_INTEGER;
+ skip_opt->multiple = NO;
+ skip_opt->required = NO;
+ skip_opt->label = _("Do not import every n-th point");
+ skip_opt->description = _("For example, 5 will import 80 percent of points. "
+ "If not specified, all points are imported");
+ skip_opt->guisection = _("Decimation");
+ preserve_opt = G_define_option();
+ preserve_opt->key = "preserve";
+ preserve_opt->type = TYPE_INTEGER;
+ preserve_opt->multiple = NO;
+ preserve_opt->required = NO;
+ preserve_opt->label = _("Import only every n-th point");
+ preserve_opt->description = _("For example, 4 will import 25 percent of points. "
+ preserve_opt->guisection = _("Decimation");
+ offset_opt = G_define_option();
+ offset_opt->key = "offset";
+ offset_opt->type = TYPE_INTEGER;
+ offset_opt->multiple = NO;
+ offset_opt->required = NO;
+ offset_opt->label = _("Skip first n points");
+ offset_opt->description = _("Skips the given number of points at the beginning.");
+ offset_opt->guisection = _("Decimation");
+ limit_opt = G_define_option();
+ limit_opt->key = "limit";
+ limit_opt->type = TYPE_INTEGER;
+ limit_opt->multiple = NO;
+ limit_opt->required = NO;
+ limit_opt->label = _("Import only n points");
+ limit_opt->description = _("Imports only the given number of points");
+ limit_opt->guisection = _("Decimation");
+ outloc_opt = G_define_option();
+ outloc_opt->key = "location";
+ outloc_opt->type = TYPE_STRING;
+ outloc_opt->required = NO;
+ outloc_opt->description = _("Name for new location to create");
+ outloc_opt->key_desc = "name";
print_flag = G_define_flag();
print_flag->key = 'p';
print_flag->description =
_("Print LAS file info and exit");
print_flag->suppress_required = YES;
- notab_flag = G_define_standard_flag(G_FLG_V_TABLE);
- notab_flag->guisection = _("Attributes");
- over_flag = G_define_flag();
- over_flag->key = 'o';
- over_flag->label =
- _("Override projection check (use current location's projection)");
- over_flag->description =
- _("Assume that the dataset has same projection as the current location");
region_flag = G_define_flag();
region_flag->key = 'r';
- region_flag->guisection = _("Subregion");
+ region_flag->guisection = _("Selection");
region_flag->description = _("Limit import to the current region");
extend_flag = G_define_flag();
extend_flag->key = 'e';
extend_flag->description =
- _("Extend region extents based on new dataset");
+ _("Extend region extents based on new dataset");
+ notab_flag = G_define_standard_flag(G_FLG_V_TABLE);
+ notab_flag->guisection = _("Speed");
+ notopo_flag = G_define_standard_flag(G_FLG_V_TOPO);
+ notopo_flag->guisection = _("Speed");
+ over_flag = G_define_flag();
+ over_flag->key = 'o';
+ over_flag->label =
+ _("Override projection check (use current location's projection)");
+ over_flag->description =
+ _("Assume that the dataset has same projection as the current location");
no_import_flag = G_define_flag();
no_import_flag->key = 'i';
no_import_flag->description =
@@ -232,7 +276,7 @@
" Do not import the vector data.");
no_import_flag->suppress_required = YES;
- notopo_flag = G_define_standard_flag(G_FLG_V_TOPO);
+ G_option_exclusive(skip_opt, preserve_opt, NULL);
/* The parser checks if the map already exists in current mapset, this is
* wrong if location options is used, so we switch out the check and do it
@@ -638,7 +682,26 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
+ /* counters used by both but that's ok, the filters are exclusive */
+ int skip_every = 0;
+ int preserve_every = 0;
+ int every_counter = 0;
+ int n_count_filtered = 0;
+ int offset_n = 0;
+ int offset_n_counter = 0;
+ int limit_n = 0;
+ /* we are not counting it elsewhere except for cat */
+ int limit_n_counter = 0;
+ if (skip_opt->answer)
+ skip_every = atoi(skip_opt->answer);
+ if (preserve_opt->answer)
+ preserve_every = atoi(preserve_opt->answer);
+ if (offset_opt->answer)
+ offset_n = atoi(offset_opt->answer);
+ if (limit_opt->answer)
+ limit_n = atoi(limit_opt->answer);
G_important_message(_("Scanning %d points..."), n_features);
while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
double x, y, z;
@@ -704,6 +767,31 @@
continue;
+ if (offset_n) {
+ offset_n_counter++;
+ if (offset_n_counter < offset_n)
+ continue;
+ else
+ offset_n = 0; /* disable offset check */
+ if (skip_every) {
+ every_counter++;
+ if (every_counter == skip_every) {
+ n_count_filtered++;
+ every_counter = 0;
+ continue;
+ else if (preserve_every) {
+ every_counter++;
+ if (every_counter == preserve_every) {
+ else {
+ continue;
Vect_append_point(Points, x, y, z);
Vect_cat_set(Cats, 1, cat);
@@ -788,6 +876,12 @@
+ if (limit_n) {
+ limit_n_counter++;
+ /* this matches the last successfully imported point */
+ if (limit_n_counter == limit_n)
+ break;
cat++;
G_percent(n_features, n_features, 1); /* finish it */
@@ -805,9 +899,13 @@
if (!notopo_flag->answer)
Vect_build(&Map);
Vect_close(&Map);
- G_message(_("%d points imported"),
- n_features - not_valid - n_outside - n_filtered - n_class_filtered);
+ if (limit_n)
+ G_message(_("%d points imported (limit was %d)"), limit_n_counter, limit_n);
+ else
+ G_message(_("%d points imported"),
+ n_features - not_valid - n_outside - n_filtered - n_class_filtered
+ - offset_n_counter - n_count_filtered);
if (not_valid)
G_message(_("%d input points were not valid"), not_valid);
if (n_outside)
@@ -816,6 +914,12 @@
G_message(_("%d input points were filtered out by return number"), n_filtered);
if (n_class_filtered)
G_message(_("%d input points were filtered out by class number"), n_class_filtered);
+ if (offset_n_counter)
+ G_message(_("%d input points were skipped at the begging using offset"), offset_n_counter);
+ if (n_count_filtered)
+ G_message(_("%d input points were skipped by count-based decimation"), n_count_filtered);
+ if (limit_n)
+ G_message(_("The rest of points was ignored"));
/* Extend current window based on dataset. */
