[GRASS-SVN] r66223 - grass/branches/releasebranch_7_0/imagery/i.maxlik
svn_grass at osgeo.org
Mon Sep 14 09:36:24 PDT 2015
Author: neteler
Date: 2015-09-14 09:36:24 -0700 (Mon, 14 Sep 2015)
New Revision: 66223
Added:
grass/branches/releasebranch_7_0/imagery/i.maxlik/i_maxlik_rejection.png
grass/branches/releasebranch_7_0/imagery/i.maxlik/i_maxlik_rgb.png
grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html
grass/branches/releasebranch_7_0/imagery/i.maxlik/i_maxlik_classes.png
i.maxlik manual: screenshots added
Property changes on: grass/branches/releasebranch_7_0/imagery/i.maxlik
___________________________________________________________________
Modified: svn:ignore
- OBJ.*
+ OBJ.*
*.tmp.html
Modified: grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html
--- grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html 2015-09-14 16:35:33 UTC (rev 66222)
+++ grass/branches/releasebranch_7_0/imagery/i.maxlik/i.maxlik.html 2015-09-14 16:36:24 UTC (rev 66223)
@@ -78,11 +78,13 @@
<h2>EXAMPLE</h2>
-Completion of the unsupervised classification of
-a LANDSAT subscene (VIZ, NIR, MIR channels) in North Carolina
-(see <em><a href="i.cluster.html">i.cluster</a></em> manual page for the first part):
+Second part of the unsupervised classification of a LANDSAT subscene
+(VIZ, NIR, MIR channels) in North Carolina (see
+<em><a href="i.cluster.html">i.cluster</a></em> manual page for the first
+part of the example):
<div class="code"><pre>
+# using here the signaturefile created by i.cluster
i.maxlik group=lsat7_2002 subgroup=lsat7_2002 \
signaturefile=sig_cluster_lsat2002 \
output=lsat7_2002_cluster_classes reject=lsat7_2002_cluster_reject
@@ -96,8 +98,9 @@
r.report lsat7_2002_cluster_reject units=k,p
# optionally, filter out pixels with high level of rejection
-# here we select 90% which is category 12
-r.mapcalc "lsat7_2002_cluster_classes_filtered = if(lsat7_2002_cluster_reject < 12, lsat7_2002_cluster_classes, null())"
+# here we remove pixels of at least 90% of rejection probability, i.e. categories 12-16
+r.mapcalc "lsat7_2002_cluster_classes_filtered = \
+ if(lsat7_2002_cluster_reject <= 12, lsat7_2002_cluster_classes, null())"
</pre></div>
@@ -106,8 +109,14 @@
<p>
<center>
+<img src="i_maxlik_rgb.png"><br>
+RGB composite of input data
+<p>
<img src="i_maxlik_classes.png"><br>
-Resulting raster with classified pixels
+Output raster map with pixels classified (10 classes)
+<p>
+<img src="i_maxlik_rejection.png"><br>
+Output raster map with rejection probability values (pixel classification confidence levels)
</center>
Modified: grass/branches/releasebranch_7_0/imagery/i.maxlik/i_maxlik_classes.png
(Binary files differ)
Copied: grass/branches/releasebranch_7_0/imagery/i.maxlik/i_maxlik_rejection.png (from rev 66222, grass/trunk/imagery/i.maxlik/i_maxlik_rejection.png)
Copied: grass/branches/releasebranch_7_0/imagery/i.maxlik/i_maxlik_rgb.png (from rev 66222, grass/trunk/imagery/i.maxlik/i_maxlik_rgb.png)
