[GRASS-SVN] r66255 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Thu Sep 17 18:43:24 PDT 2015
Author: annakrat
Date: 2015-09-17 18:43:24 -0700 (Thu, 17 Sep 2015)
New Revision: 66255
grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: use unsigned long long for counting point counts, fixes #2472 (co-author wenzeslaus)
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2015-09-17 20:32:23 UTC (rev 66254)
+++ grass/trunk/vector/v.in.lidar/main.c 2015-09-18 01:43:24 UTC (rev 66255)
@@ -143,12 +143,18 @@
int return_filter;
int skipme;
int point_class;
- unsigned int not_valid;
struct line_pnts *Points;
struct line_cats *Cats;
- unsigned int n_features, feature_count, n_outside, n_filtered, n_class_filtered;
+#ifdef HAVE_LONG_LONG_INT
+ unsigned long long n_features, feature_count, n_outside,
+ n_filtered, n_class_filtered, not_valid;
+#else
+ unsigned long n_features, feature_count, n_outside,
+#endif
int overwrite;
G_gisinit(argv[0]);
@@ -687,12 +693,19 @@
int skip_every = 0;
int preserve_every = 0;
int every_counter = 0;
- int n_count_filtered = 0;
- int offset_n = 0;
- int offset_n_counter = 0;
- int limit_n = 0;
- /* we are not counting it elsewhere except for cat */
- int limit_n_counter = 0;
+ unsigned long long n_count_filtered = 0;
+ unsigned long long offset_n = 0;
+ unsigned long long offset_n_counter = 0;
+ unsigned long long limit_n = 0;
+ unsigned long long limit_n_counter = 0;
+#else
+ unsigned long n_count_filtered = 0;
+ unsigned long offset_n = 0;
+ unsigned long offset_n_counter = 0;
+ unsigned long limit_n = 0;
+ unsigned long limit_n_counter = 0;
+#endif
if (skip_opt->answer)
skip_every = atoi(skip_opt->answer);
if (preserve_opt->answer)
@@ -701,8 +714,11 @@
offset_n = atoi(offset_opt->answer);
if (limit_opt->answer)
limit_n = atoi(limit_opt->answer);
- G_important_message(_("Scanning %d points..."), n_features);
+ G_important_message(_("Scanning %llu points..."), n_features);
+#else
+ G_important_message(_("Scanning %lu points..."), n_features);
+#endif
while ((LAS_point = LASReader_GetNextPoint(LAS_reader)) != NULL) {
double x, y, z;
@@ -900,24 +916,46 @@
Vect_build(&Map);
Vect_close(&Map);
if (limit_n)
+ G_message(_("%llu points imported (limit was %llu)"), limit_n_counter, limit_n);
+ else
+ G_message(_("%llu points imported"),
+ n_features - not_valid - n_outside - n_filtered - n_class_filtered
+ - offset_n_counter - n_count_filtered);
+ if (not_valid)
+ G_message(_("%llu input points were not valid"), not_valid);
+ if (n_outside)
+ G_message(_("%llu input points were outside of the selected area"), n_outside);
+ if (n_filtered)
+ G_message(_("%llu input points were filtered out by return number"), n_filtered);
+ if (n_class_filtered)
+ G_message(_("%llu input points were filtered out by class number"), n_class_filtered);
+ if (offset_n_counter)
+ G_message(_("%llu input points were skipped at the begging using offset"), offset_n_counter);
+ if (n_count_filtered)
+ G_message(_("%llu input points were skipped by count-based decimation"), n_count_filtered);
+#else
+ if (limit_n)
G_message(_("%d points imported (limit was %d)"), limit_n_counter, limit_n);
else
G_message(_("%d points imported"),
if (not_valid)
- G_message(_("%d input points were not valid"), not_valid);
+ G_message(_("%lu input points were not valid"), not_valid);
if (n_outside)
- G_message(_("%d input points were outside of the selected area"), n_outside);
+ G_message(_("%lu input points were outside of the selected area"), n_outside);
if (n_filtered)
- G_message(_("%d input points were filtered out by return number"), n_filtered);
+ G_message(_("%lu input points were filtered out by return number"), n_filtered);
- G_message(_("%d input points were filtered out by class number"), n_class_filtered);
+ G_message(_("%lu input points were filtered out by class number"), n_class_filtered);
- G_message(_("%d input points were skipped at the begging using offset"), offset_n_counter);
+ G_message(_("%lu input points were skipped at the begging using offset"), offset_n_counter);
- G_message(_("%d input points were skipped by count-based decimation"), n_count_filtered);
+ G_message(_("%lu input points were skipped by count-based decimation"), n_count_filtered);
+ G_message(_("Accuracy of the printed point counts might be limited by your computer architecture."));
+#endif
if (limit_n)
G_message(_("The rest of points was ignored"));
