[GRASS-SVN] r66261 - in grass/trunk/temporal: . t.info t.list t.merge
svn_grass at osgeo.org
Fri Sep 18 17:48:31 PDT 2015
Author: neteler
Date: 2015-09-18 17:48:31 -0700 (Fri, 18 Sep 2015)
New Revision: 66261
grass/trunk/temporal/t.info/t.info.html
grass/trunk/temporal/t.list/t.list.html
grass/trunk/temporal/t.merge/t.merge.html
grass/trunk/temporal/temporalintro.html
temporal manual: explain usage of temporal databases stored in other mapsets
Modified: grass/trunk/temporal/t.info/t.info.html
--- grass/trunk/temporal/t.info/t.info.html 2015-09-18 12:54:15 UTC (rev 66260)
+++ grass/trunk/temporal/t.info/t.info.html 2015-09-19 00:48:31 UTC (rev 66261)
@@ -15,6 +15,12 @@
In addition, information about the chosen temporal database backend
can be reported.
+<h2>NOTES</h2>
+Temporal databases stored in other mapsets can be used as long as they
+are in the user's current mapset search path (managed with
+<a href="g.mapsets.html">g.mapsets</a>).
<h2>EXAMPLES</h2>
<h3>Temporal DBMI information</h3>
Modified: grass/trunk/temporal/t.list/t.list.html
--- grass/trunk/temporal/t.list/t.list.html 2015-09-18 12:54:15 UTC (rev 66260)
+++ grass/trunk/temporal/t.list/t.list.html 2015-09-19 00:48:31 UTC (rev 66261)
@@ -13,9 +13,13 @@
<h2>NOTES</h2>
-The SQL where and sort expression will be applied for each temporal
-database that was found in accessible mapsets. Hence sorting works only
-on mapset basis.
+The SQL <em>where</em> and <em>sort</em> expression will be applied for
+each temporal database that was found in accessible mapsets. Hence
+sorting works only on mapset basis.
+<p>
<h2>EXAMPLES</h2>
Modified: grass/trunk/temporal/t.merge/t.merge.html
--- grass/trunk/temporal/t.merge/t.merge.html 2015-09-18 12:54:15 UTC (rev 66260)
+++ grass/trunk/temporal/t.merge/t.merge.html 2015-09-19 00:48:31 UTC (rev 66261)
@@ -13,6 +13,12 @@
the output space time dataset, hence the same maps can be registered in
different input space time datasets.
+<h2>NOTES</h2>
<h2>Examples</h2>
In this example we will create two space time raster datasets and
Modified: grass/trunk/temporal/temporalintro.html
--- grass/trunk/temporal/temporalintro.html 2015-09-18 12:54:15 UTC (rev 66260)
+++ grass/trunk/temporal/temporalintro.html 2015-09-19 00:48:31 UTC (rev 66261)
@@ -21,7 +21,10 @@
<h3>Temporal data management in general</h3>
Space time datasets are stored in a temporal database. SQLite3 or
-PostgreSQL are supported as SQL database back end.
+PostgreSQL are supported as SQL database back end. Temporal databases
+stored in other mapsets can be used as long as they are in the
+user's current mapset search path (managed with <a href="g.mapsets.html">g.mapsets</a>).
+<p>
Connection settings are performed with <a href="t.connect.html">t.connect</a>.
As default a sqlite3 database will be created in the current mapset that
stores all space time datasets and registered time series maps.
@@ -187,10 +190,10 @@
<li>Gebbert, S., Pebesma, E., 2014. TGRASS: A temporal GIS for field based
environmental modeling. Environmental Modelling & Software 53, 1-12.
(<a href="http://dx.doi.org/10.1016/j.envsoft.2013.11.001">DOI</a>)</li>
+<li><a href="http://grasswiki.osgeo.org/wiki/Temporal_data_processing">Temporal data processing</a> (Wiki)</li>
<li>Vaclav Petras, Anna Petrasova, Helena Mitasova, Markus Neteler, <b>FOSS4G 2014 workshop</b>: <br>
<a href="http://fatra.cnr.ncsu.edu/temporal-grass-workshop/">Spatio-temporal data handling and visualization in GRASS GIS</a></li>
-<li><a href="http://grasswiki.osgeo.org/wiki/Temporal_data_processing">Temporal data processing</a> (Wiki)</li>
-<li><a href="http://www.geostat-course.org/Topic_Gebbert">GEOSTAT TGRASS Course</a></li>
+<li><a href="http://www.geostat-course.org/Topic_Gebbert">GEOSTAT 2012 TGRASS Course</a></li>
</ul>
