[GRASS-SVN] r66269 - grass/trunk/vector/v.kernel
Mon Sep 21 08:54:50 PDT 2015
Author: neteler
Date: 2015-09-21 08:54:50 -0700 (Mon, 21 Sep 2015)
New Revision: 66269
   grass/trunk/vector/v.kernel/main.c
v.kernel: always show target raster resolution; fix dangling curly braces -Wdangling-else
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2015-09-21 11:16:52 UTC (rev 66268)
+++ grass/trunk/vector/v.kernel/main.c	2015-09-21 15:54:50 UTC (rev 66269)
@@ -222,22 +222,23 @@
 	exit(EXIT_FAILURE);
     if (net_opt->answer) {
-	if (G_find_vector2(out_opt->answer, G_mapset()))
+	if (G_find_vector2(out_opt->answer, G_mapset())) {
             if (overwrite)
                 G_warning(_("Vector map <%s> already exists and will be overwritten"),
                           out_opt->answer);
             else
                 G_fatal_error(_("Vector map <%s> already exists"),
                               out_opt->answer);
-    else {
-	if (G_find_raster(out_opt->answer, G_mapset()))
+    } else {
+	if (G_find_raster(out_opt->answer, G_mapset())) {
             if (overwrite)
                 G_warning(_("Raster map <%s> already exists and will be overwritten"),
                           out_opt->answer);
             else
                 G_fatal_error(_("Raster map <%s> already exists"),
                               out_opt->answer);
     /*read options */
@@ -302,8 +303,13 @@
     G_asprintf(&tmpstr1, n_("%d row", "%d rows", window.rows), window.rows);
     G_asprintf(&tmpstr2, n_("%d column", "%d columns", window.cols), window.cols);
     /* GTC First argument is resolution, second - number of rows as a text, third - number of columns as a text. */
-    G_verbose_message(_("Output raster map: resolution: %f\t%s\t%s"),
+    if (G_verbose() > G_verbose_std()) {
+       G_verbose_message(_("Output raster map: resolution: %f\t%s\t%s"), /* mhh, this assumes square pixels */
                       window.ew_res, tmpstr1, tmpstr2);
+    } else {
+       G_message(_("Output raster map resolution: %f"), window.ew_res); /* mhh, this assumes square pixels */
     G_free(tmpstr1);
     G_free(tmpstr2);
