[GRASS-SVN] r66282 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial
Tue Sep 22 05:06:38 PDT 2015
Author: Giulia
Date: 2015-09-22 05:06:38 -0700 (Tue, 22 Sep 2015)
New Revision: 66282
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
r.green: put structure input as mandatory
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2015-09-22 12:05:02 UTC (rev 66281)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.financial/r.green.hydro.financial.py	2015-09-22 12:06:38 UTC (rev 66282)
@@ -26,7 +26,7 @@
 #%option G_OPT_V_INPUT
 #%  key: struct
 #%  label: Name of the input vector map with the structure of the plants
-#%  required: no
+#%  required: yes
 #%end
@@ -496,8 +496,6 @@
 import os
 import atexit
-import random
 import numpy as np
 from grass.script import core as gcore
 from grass.exceptions import ParameterError
@@ -585,6 +583,7 @@
                           slim=slim, width=width, depth=depth),
               overwrite=overwrite)
 def vmapcalc2(vmap, vlayer, cname, ctype, expr, overwrite=False):
     v.db_addcolumn(map=vmap, layer=vlayer, columns=[(cname, ctype)],
@@ -1009,27 +1008,27 @@
                          function=max_NPV,
                          exclude=['intake_id', 'side', 'power',
                                   'gross_head', 'discharge'])
-    if opts['output_struct']:
-        vec = VectorTopo(opts['output_struct'])
-        vec.open('rw')
-        vec.table.columns.add('max_NPV','VARCHAR(3)')
-        list_intakeid=list(set(vec.table.execute('SELECT intake_id FROM %s' %vec.table.name).fetchall()))
-        for i in range(0,len(list_intakeid)):
-            vec.rewind()
-            list_npv=list(vec.table.execute('SELECT NPV FROM %s WHERE intake_id=%i;' % (vec.table.name, list_intakeid[i][0])).fetchall())
-            npvmax=max(list_npv)[0]
-            for line in vec:
-                if line.attrs['intake_id'] == list_intakeid[i][0]:
-                    if line.attrs['NPV'] == npvmax:
-                        line.attrs['max_NPV']='yes'
-                    else:
-                        line.attrs['max_NPV']='no'
+    vec = VectorTopo(opts['output_struct'])
+    vec.open('rw')
+    vec.table.columns.add('max_NPV','VARCHAR(3)')
+    list_intakeid=list(set(vec.table.execute('SELECT intake_id FROM %s' %vec.table.name).fetchall()))
-        vec.table.conn.commit()
-        vec.close()
+    for i in range(0,len(list_intakeid)):
+        vec.rewind()
+        list_npv=list(vec.table.execute('SELECT NPV FROM %s WHERE intake_id=%i;' % (vec.table.name, list_intakeid[i][0])).fetchall())
+        npvmax=max(list_npv)[0]
+        for line in vec:
+            if line.attrs['intake_id'] == list_intakeid[i][0]:
+                if line.attrs['NPV'] == npvmax:
+                    line.attrs['max_NPV']='yes'
+                else:
+                    line.attrs['max_NPV']='no'
+    vec.table.conn.commit()
+    vec.close()
 if __name__ == "__main__":
     main(*parser())
