[GRASS-SVN] r66284 - grass-addons/grass7/raster/r.green/r.green.hydro/libhydro
svn_grass at osgeo.org
Tue Sep 22 05:13:10 PDT 2015
Author: Giulia
Date: 2015-09-22 05:13:10 -0700 (Tue, 22 Sep 2015)
New Revision: 66284
grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
r.green: temporary files as tmprgreen_PID
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py 2015-09-22 12:11:44 UTC (rev 66283)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py 2015-09-22 12:13:10 UTC (rev 66284)
@@ -17,8 +17,8 @@
# import system libraries
import os
-import numpy as np
import itertools
+import math
#import pdb
@@ -66,12 +66,8 @@
:param delta
gross head m
- if isinstance(delta, float) or isinstance(delta, int):
- if (isinstance(Q, float) or isinstance(Q, int) or
- isinstance(Q, np.float32)):
+ if Q and delta:
return max((delta * 9.81 * Q), 0)
- else:
- return 0.0
else:
return 0.0
@@ -326,14 +322,17 @@
write the basins object in a vector with the same cat value
of the ID basin
- gcore.run_command("r.thin", input=stream, output='stream_thin')
- gcore.run_command("r.to.vect", input='stream_thin',
+ pid = os.getpid()
+ tmp_thin = "tmprgreen_%i_thin" % pid
+ tmp_clean = "tmprgreen_%i_clean" % pid
+ gcore.run_command("r.thin", input=stream, output=tmp_thin)
+ gcore.run_command("r.to.vect", input=tmp_thin,
flags='v',
- output='vec_clean', type="line")
+ output=tmp_clean, type="line")
gcore.run_command("v.edit", map='vec_clean', tool='delete', cats='0')
#pdb.set_trace()
- gcore.run_command('v.build', map='vec_clean')
- dissolve_lines('vec_clean', E)
+ gcore.run_command('v.build', map=tmp_clean)
+ dissolve_lines(tmp_clean, E)
# TODO: dissolve the areas with the same cat
# adding columns
gcore.run_command("v.db.addcolumn", map=E,
@@ -382,7 +381,7 @@
basins_tot[ID].E_up.values()[0],
basins_tot[ID].E_up.keys()[1],
basins_tot[ID].E_up.values()[1],
- 0, 0, basins_tot[ID].E_own
+ 0, 0.0, basins_tot[ID].E_own
+ sum(basins_tot[ID].E_up.values())])
elif len(basins_tot[ID].E_up) == 3:
#pdb.set_trace()
@@ -391,11 +390,12 @@
basins_tot[ID].E_up.keys()[2],
- basins_tot[ID].E_up.values()[2],basins_tot[ID].E_own
- + sum(basins_tot[ID].E_up.values())])
+ basins_tot[ID].E_up.values()[2],
+ basins_tot[ID].E_own + sum(basins_tot[ID].E_up.values())])
else:
- db = db + [0, 0.0, 0, 0.0, 0, 0.0]
- #print db
+ db = db + [0, 0.0, 0, 0.0, 0, 0.0, basins_tot[ID].E_own]
+ db = [float(d) for d in db]
+ # FIXME: numpy.float is not accepted
# TODO: change values, give only key and vals without key
vec.table.update(basins_tot[ID].ID, db, cursor)
@@ -510,24 +510,29 @@
Build the network of streams with the ID of all the basins
in order to know the dependencies among basins
+ pid = os.getpid()
+ tmp_neighbors = "tmprgreen_%i_neighbors" % pid
+ tmp_closure = "tmprgreen_%i_closure" % pid
+ tmp_down = "tmprgreen_%i_down" % pid
river = raster2numpy(stream)
river_comp = raster2compressM(stream).tocoo()
gcore.run_command('r.neighbors', input=stream,
- output="neighbors", method="minimu", size='5',
+ output=tmp_neighbors, method="minimu", size='5',
quantile='0.5')
- formula = 'closure = neighbors-%s' % (stream)
+ formula = '%s = %s-%s' % (tmp_closure, tmp_neighbors, stream)
mapcalc(formula)
# del the map down, it should be not necessary
gcore.run_command('r.stats.zonal',
base=stream,
- cover='closure',
- output='down',
+ cover=tmp_closure,
+ output=tmp_down,
method='min')
#pdb.set_trace()
dtm_n = raster2numpy(dtm)
- clos = raster2numpy('closure')
- ID_down = raster2numpy('down')
+ clos = raster2numpy(tmp_closure)
+ ID_down = raster2numpy(tmp_down)
#pdb.set_trace()
for i, j, v in itertools.izip(river_comp.row,
river_comp.col, river_comp.data):
@@ -563,20 +568,19 @@
Fill basins dictionary with discharge, h_mean and compute the power
msgr = get_msgr()
+ warn = ("%i") % bas.ID
ttt = discharge_n[stream_n == bas.ID]
#import ipdb; ipdb.set_trace()
bas.discharge_own = ttt.sort()
#FIXME: take the second bgger value to avoid to take the value of
# another catchment, it is not so elegant
- if len(ttt) > 1:
+ if len(ttt) > 1 and not(math.isnan(ttt[-2])):
bas.discharge_own = float(ttt[-2])
- elif ((len(ttt) < 1) and (len(ttt) > 0)):
- bas.discharge_own = float(ttt[0])
- warn = ("Only one value of discharge for the river ID %i") % bas.ID
- msgr.warning(warn)
else:
+ bas.discharge_own = 0.0
+ warn = ("No value for the river ID %i, discharge set to 0") % bas.ID
msgr.warning(warn)
bas.h_mean = h_mean
# basins_tot[count].h_closure = float(info_c[count])
delta = bas.h_mean - bas.h_closure
@@ -624,7 +628,7 @@
def fill_basins(inputs, basins_tot, basins, dtm, discharge, stream):
- Fill the dictionary with the basins
+ Fill the dictionary with the basins attribute
info_h = gcore.parse_command('r.category', map='dtm_mean', separator='=')
#pdb.set_trace()
@@ -633,8 +637,7 @@
area = area_of_basins(basins, count, dtm)
basins_tot[count].area = float(area)
h_mean = float(info_h[str(count)])
- fill_energyown(basins_tot[count], h_mean, discharge, stream)
+ fill_energyown(basins_tot[count], h_mean, discharge, stream)
for b in inputs:
fill_discharge_tot(basins_tot, b)
@@ -684,46 +687,47 @@
return raster_out, bas_area
-def dtm_corr(dtm, river, lake=None):
- temp_vec = []
- temp_rast = []
+def dtm_corr(dtm, river, dtm_corr, lake=None):
+ """ Compute a new DTM by applying a corrective factor
+ close to the river network. Output of r.green.watershed
+ will be coherent with the river network
+ pid = os.getpid()
msgr = get_msgr()
info = gcore.parse_command('g.region', flags='pg')
- """ change dtm accordingo to the river and lake vectors"""
if lake:
+ tmp_network = "tmprgreen_%i_network" % pid
inputs = '%s,%s' % (lake, river)
gcore.run_command('v.patch',
input=inputs,
- output='hydro_network')
- temp_vec.append('hydro_network')
- river = 'hydro_network'
+ output=tmp_network)
+ river = tmp_network
msgr.warning("The DTM will be temporarily modified")
distance = [float(info['nsres']), float(info['nsres'])*1.5,
float(info['nsres'])*3]
+ pat = "tmprgreen_%i_" % pid
for i, val in enumerate(distance):
- output = 'buff_%i' % i
+ output = '%sbuff_%i' % (pat, i)
gcore.run_command('v.buffer',
input=river,
output=output,
distance=val)
- temp_vec.append(output)
gcore.run_command('v.to.rast',
input=output,
output=output,
use='val',
value=val,
overwrite=True)
- temp_rast.append(output)
command = ('%s_c = if(isnull(%s),0,%s)') % (output, output,
output)
mapcalc(command, overwrite=True)
- temp_rast.append('%s_c' % output)
- command = (('DTM_corr = if(%s,%s-buff_0_c-buff_1_c-buff_2_c)')
- % (dtm, dtm))
+ command = (('%s = if(%s,%s-%sbuff_0_c-%sbuff_1_c-%sbuff_2_c)')
+ % (dtm_corr, dtm, dtm, pat, pat, pat))
- return 'DTM_corr', temp_vec, temp_rast
if __name__ == "__main__":
