[GRASS-SVN] r66286 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended
svn_grass at osgeo.org
Tue Sep 22 05:15:13 PDT 2015
Author: Giulia
Date: 2015-09-22 05:15:13 -0700 (Tue, 22 Sep 2015)
New Revision: 66286
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
r.green: changes in the interface
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py 2015-09-22 12:13:55 UTC (rev 66285)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py 2015-09-22 12:15:13 UTC (rev 66286)
@@ -24,10 +24,7 @@
## REQUIRED INPUTS
-#%option
-#% key: elevation
-#% key_desc: name
-#% description: Name of elevation raster map [m]
+#%option G_OPT_R_ELEV
#% required: yes
#%end
#%option G_OPT_V_INPUT
@@ -45,7 +42,7 @@
#% type: double
#% key_desc: double
#% description: Efficiency [0-1]
-#% required: no
+#% required: yes
#% options: 0-1
#% answer: 1
#%end
@@ -54,7 +51,7 @@
#% type: double
#% key_desc: double
#% description: Maximum plant length [m]
-#% required: no
+#% required: yes
#% answer: 100
#%end
#%option
@@ -62,7 +59,7 @@
#% type: double
#% key_desc: double
#% description: Minimum plant length [m]
-#% required: no
+#% required: yes
#% answer: 10
#%end
#%option
@@ -70,7 +67,7 @@
#% type: double
#% key_desc: double
#% description: Minimum distance among plants [m]
-#% required: no
+#% required: yes
#% answer: 0.5
#%end
#%option
@@ -85,19 +82,19 @@
## OPTIONAL INPUTS: LEGAL DISCHARGE
-#%option
+#%option G_OPT_R_INPUT
#% key: discharge_current
#% label: Current discharge [m3/s]
#% required: yes
#% guisection: Legal Discharge
#%end
-#%option
#% key: mfd
#% label: Minimum Flow Discharge (MFD) [m3/s]
#% required: no
#%end
-#%option
#% key: discharge_natural
#% label: Natural discharge [m3/s]
#% required: no
@@ -145,7 +142,6 @@
#% type: double
#% description: Resolution of the visibility map computation
#% required: no
-#% answer: 250
#% guisection: Areas to exclude
#%end
#%option
@@ -153,7 +149,6 @@
#% type: integer
#% description: Number of points for the visibility
#% required: no
-#% answer: 0
#%end
@@ -329,7 +324,7 @@
elif discharge_natural:
formula = '%s=%s-%s*%s/100.0' % (tmp_disch, discharge_current,
- discharge_natural,
+ discharge_natural,
percentage)
mapcalc(formula, overwrite=OVW)
TMPRAST.append(tmp_disch)
