[GRASS-SVN] r66288 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical
svn_grass at osgeo.org
Tue Sep 22 05:18:50 PDT 2015
Author: Giulia
Date: 2015-09-22 05:18:50 -0700 (Tue, 22 Sep 2015)
New Revision: 66288
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
r.green: fixed bug about energy potential computation and changed temporary files as tmprgreen
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py 2015-09-22 12:17:13 UTC (rev 66287)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py 2015-09-22 12:18:50 UTC (rev 66288)
@@ -24,7 +24,7 @@
#%option G_OPT_R_ELEV
#% required: yes
#%end
-#%option
+#%option G_OPT_R_INPUT
#% key: discharge
#% type: string
#% gisprompt: old,cell,raster
@@ -32,7 +32,7 @@
#% description: Name of river discharge [m3/s]
#% required: yes
#%end
-#%option
+#%option G_OPT_V_INPUT
#% key: rivers
#% type: string
#% gisprompt: old,vector,vector
@@ -40,7 +40,7 @@
#% description: Name of river network
#% required: no
#%end
-#%option
#% key: lakes
#% type: string
@@ -56,7 +56,7 @@
#% answer: 0
#% guisection: Basin Potential
#%end
-#%option
#% key: basins
#% type: string
@@ -65,7 +65,7 @@
#% required: no
#%end
-#%option
#% key: stream
#% type: string
@@ -79,7 +79,7 @@
#% key: d
#% description: Debug with intermediate maps
#%end
-#%option
+#%option G_OPT_V_OUTPUT
#% key: output
#% type: string
#% key_desc: name
@@ -94,7 +94,6 @@
import os
import sys
import atexit
-import pdb
# import grass libraries
from grass.script import core as gcore
@@ -105,6 +104,7 @@
set_path('r.green', 'libgreen', os.path.join('..', '..'))
# finally import the module in the library
from libgreen.utils import cleanup
+from libhydro.basin import dtm_corr
from libhydro import basin
from libgreen.utils import check_overlay_rr
#from libgreen.utils import check_overlay_rv
@@ -121,8 +121,9 @@
# inizialitation
- TMPRAST, TMPVECT, DEBUG = [], [], False
- atexit.register(cleanup, rast=TMPRAST, vect=TMPVECT, debug=DEBUG)
+ pid = os.getpid()
+ DEBUG = False
+ atexit.register(cleanup, pattern=("tmprgreen_%i" % pid), debug=DEBUG)
#TOD_add the possibilities to have q_points
# required
discharge = options['discharge']
@@ -134,6 +135,7 @@
lakes = options['lakes'] # vec
E = options['output']
threshold = options['threshold']
# existing plants
# segments = options['segments']
# output_segm = options['output_segm']
@@ -154,31 +156,18 @@
# print info
# check temporary raster
- TMPRAST = ['dtm_mean', 'neighbors',
- 'closure', 'down', 'lakes', 'stream_thin',
- 'debug', 'vec_rast']
- TMPVECT = ['tmptmp', 'segments']
- if not gcore.overwrite():
- for m in TMPRAST:
- if gcore.find_file(m)['name']:
- msgr.fatal(_("Temporary raster map %s exists") % (m))
if rivers:
# cp the vector in the current mapset in order to clean it
- to_copy = '%s,river_new' % rivers
+ tmp_river = "tmprgreen_%i_river" % pid
+ to_copy = '%s,%s' % (rivers, tmp_river)
gcore.run_command('g.copy', vector=to_copy)
- rivers = 'river_new'
- TMPVECT.append('river_new')
+ rivers = tmp_river
gcore.run_command('v.build', map=rivers)
- pdb.set_trace()
- dtm_corr, tmp_v, tmp_r = basin.dtm_corr(dtm, rivers, lakes)
- TMPRAST = TMPRAST + tmp_r
- TMPVECT = TMPVECT + tmp_v
+ tmp_dtm_corr = "tmprgreen_%i_dtm_corr" % pid
+ dtm_corr(dtm, rivers, tmp_dtm_corr, lakes)
basins, stream = basin.check_compute_basin_stream(basins, stream,
- dtm_corr, threshold)
+ tmp_dtm_corr, threshold)
else:
dtm, threshold)
@@ -189,6 +178,7 @@
warn = ("Discharge map doesn't overlay all the stream map."
"It covers only the %s %% of rivers") % (perc_overlay)
msgr.warning(warn)
+ import ipdb; ipdb.set_trace()
msgr.message("\Init basins\n")
#pdb.set_trace()
@@ -198,11 +188,11 @@
basins_tot, inputs = basin.init_basins(basins)
msgr.message("\nCompute mean elevation\n")
+ tmp_dtm_mean = "tmprgreen_%i_dtm_mean" % pid
gcore.run_command('r.stats.zonal',
base=basins,
cover=dtm, flags='r',
- output='dtm_mean',
+ output=tmp_dtm_mean,
method='average')
msgr.message("\nBuild the basin network\n")
@@ -230,67 +220,11 @@
# if not rivers or debug I write the result in the new vector stream
msgr.message("\nWrite results\n")
basin.write_results2newvec(stream, E, basins_tot, inputs)
- # try tobuilt a vector shp of rivers coerent with vector input
- #TODO: and the new branches created by r.watershed, check how to add to
- # the existing vector river
-# if rivers:
-# if DEBUG:
-# basin.write_results2newvec(stream, 'debug', basins_tot, inputs)
-# basin.add_results2shp(basins, rivers, basins_tot, E, inputs)
-# else:
- # if there are plants, it deletes the piece of river
- # pdb.set_trace()
-# if (segments and hydro):
-# warn = (("%s map could have been generated by %s."
-# "%s is used for next computations")
-# % (segments, hydro, segments))
-# msgr.warning(warn)
-# if hydro and not(segments):
-# msgr.message("\nr.green.hydro.delplants\n")
-# gcore.run_command('r.green.hydro.delplants',
-# hydro=hydro,
-# hydro_layer=hydro_layer,
-# river=E,
-# plants='plant',
-# output='segments',
-# hydro_kind_intake=hydro_kind_intake,
-# hydro_kind_turbine=hydro_kind_turbine,
-# elevation=dtm,
-# other=other,
-# other_kind_intake=other_kind_intake,
-# other_kind_turbine=other_kind_turbine)
-# segments = 'segments'
-# #FIXME: with temporary plants it don't work
-# if segments:
-# perc_overlay = check_overlay_rv(discharge, segments)
-# if float(perc_overlay) < 90:
-# warn = ("Discharge map doesn't overlay all the segments map."
-# "It covers only the %s %% of rivers") % (perc_overlay)
-# gcore.run_command('r.green.hydro.optimal',
-# flags='c',
-# discharge=discharge,
-# river=segments,
-# dtm=dtm,
-# len_plant='10000000',
-# output_plant=output_segm,
-# output_point=output_point,
-# distance='0.5',
-# len_min='0.5')
if __name__ == "__main__":
options, flags = gcore.parser()
sys.exit(main(options, flags))
