[GRASS-SVN] r66292 - in grass-addons/grass7/raster/r.green/r.green.hydro: libhydro r.green.hydro.theoretical
Tue Sep 22 07:30:57 PDT 2015
Author: Giulia
Date: 2015-09-22 07:30:57 -0700 (Tue, 22 Sep 2015)
New Revision: 66292
   grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
   grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
r.green: fix bug about the computation of the basin mean elevation
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py	2015-09-22 12:59:11 UTC (rev 66291)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py	2015-09-22 14:30:57 UTC (rev 66292)
@@ -630,14 +630,21 @@
     Fill the dictionary with the basins attribute
-    info_h = gcore.parse_command('r.category', map='dtm_mean', separator='=')
+    pid = os.getpid()
+    tmp_dtm_mean = "tmprgreen_%i_dtm_mean" % pid
+    gcore.run_command('r.stats.zonal',
+                      base=basins,
+                      cover=dtm, flags='r',
+                      output=tmp_dtm_mean,
+                      method='average')
+    info_h = gcore.parse_command('r.category', map=tmp_dtm_mean, separator='=')
     #pdb.set_trace()
     for count in inputs:
         if info_h[str(count)] != '':
             area = area_of_basins(basins, count, dtm)
             basins_tot[count].area = float(area)
             h_mean = float(info_h[str(count)])
-            fill_energyown(basins_tot[count], h_mean, discharge, stream)
+            fill_energyown(basins_tot[count], h_mean, discharge, stream)
     for b in inputs:
         fill_discharge_tot(basins_tot, b)
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2015-09-22 12:59:11 UTC (rev 66291)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py	2015-09-22 14:30:57 UTC (rev 66292)
@@ -187,14 +187,6 @@
     basins_tot, inputs = basin.init_basins(basins)
-    msgr.message("\nCompute mean elevation\n")
-    tmp_dtm_mean = "tmprgreen_%i_dtm_mean" % pid
-    gcore.run_command('r.stats.zonal',
-                      base=basins,
-                      cover=dtm, flags='r',
-                      output=tmp_dtm_mean,
-                      method='average')
     msgr.message("\nBuild the basin network\n")
     # build_network(stream, dtm, basins_tot) build relationship among basins
