[GRASS-SVN] r66297 - in grass-addons/grass7/raster: r.stream.variables r.stream.watersheds
Tue Sep 22 15:24:10 PDT 2015
Author: elselvaje
Date: 2015-09-22 15:24:10 -0700 (Tue, 22 Sep 2015)
New Revision: 66297
   grass-addons/grass7/raster/r.stream.variables/r.stream.variables
   grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
change echos and other littel impruvement
Modified: grass-addons/grass7/raster/r.stream.variables/r.stream.variables
--- grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-09-22 21:52:57 UTC (rev 66296)
+++ grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-09-22 22:24:10 UTC (rev 66297)
@@ -49,16 +49,26 @@
 #% type: string
 #% key_desc: name
 #% description: Provide the full folder path (same as for r.stream.watersheds)
-#% required:yes
+#% required:no
+#% answer: GISDBASE/folder_structure
 #%end
 #%option
+#% key: out_folder
+#% type: string
+#% key_desc: name
+#% description: Provide the full folder path for the output stream-specific variable
+#% required:no
+#% answer: GISDBASE/stream-specific_variables
+#%end
+#%option
 #% key: output
 #% type: string
 #% key_desc: method
 #% multiple: yes
-#% options: min,max,range,mean,stddev,coeff_var,sum
-#% description: Provide the output aggregation method for the stream-specific variable: upstream minimum, maximum, range, mean, standard deviation, coefficient of variation, sum. Output datatype is Int32
+#% options: cells,min,max,range,mean,stddev,coeff_var,sum
+#% description: Provide the output aggregation method for the stream-specific variable: upstream cells numbers, minimum, maximum, range, mean, standard deviation, coefficient of variation, sum. Output datatype is Int32
 #% required:yes
 #%end
@@ -137,6 +147,14 @@
        export GIS_OPT_FOLDER=$GIS_OPT_FOLDER
 fi
+if [ ${GIS_OPT_OUT_FOLDER} = "GISDBASE/stream-specific_variables" ] ; then
+      export GIS_OPT_OUT_FOLDER=$GISDBASE"/stream-specific_variables"
+else
+      export GIS_OPT_OUT_FOLDER=$GIS_OPT_OUT_FOLDER
+fi
+mkdir  $GIS_OPT_OUT_FOLDER  2> /dev/null
 # what to do in case of user break:
 exitprocedure()
@@ -150,9 +168,9 @@
 # delete intermediate files
 rm -fr  $GISDBASE/$LOCATION_NAME/sub_${GIS_OPT_AREA}*
-rm -fr  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.txt
-rm -fr  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tif
-rm -fr  $GIS_OPT_FOLDER/blockfile/stat_*.txt $GIS_OPT_FOLDER/blockfile/*.tif
+find    $GIS_OPT_FOLDER/ -maxdepth 1 -name  '*.txt' -delete
+find    $GIS_OPT_FOLDER/ -maxdepth 1 -name  '*.tif' -delete
+rm -fr  $GIS_OPT_FOLDER/blockfile/stat_*.txt
 exit 1
@@ -161,11 +179,13 @@
 trap "exitprocedure" 2 3 9 15 19
 echo ""
-echo "Streams variables calculation based on the sub-watershads and sub-streams."
+echo "##########################################################################"
+echo "Streams variables calculation based on the sub-watershads and sub-streams"
 echo ""
-echo "Citation: Domisch, S., Amatulli, G., Jetz, W. (2015)"
+echo "Citation: Domisch, S., Amatulli, G., Jetz, W. (in review)"
 echo "Near-global freshwater-specific environmental variables for"
 echo "biodiversity analyses in 1km resolution. Scientific Data"
 echo ""
 export GISRC_def=$GISRC
@@ -252,7 +272,6 @@
 echo "Check for missing files due to RAM overload"
 if ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  1> /dev/null 2>&1 ; then
 echo $(ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  | wc -l ) files had RAM issues
@@ -262,6 +281,8 @@
 file=$1
 filename=$(basename $file .tif )
+echo Fix missing file $file using only 1 CPU
 if [  $GIS_OPT_AREA =  "watershed"  ] ; then ID=${filename:15:99}; fi
 if [  $GIS_OPT_AREA =  "stream"  ] ; then ID=${filename:12:99}; fi
@@ -324,10 +345,11 @@
 echo "ID|non_null_cells|null_cells|min|max|range|mean|mean_of_abs|stddev|variance|coeff_var|sum|sum_abs" >  $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
 cat  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/stat_${GIS_OPT_VARIABLE}.txt  >>  $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
-echo reclass the grid_id for the following output  ${GIS_OPT_OUTPUT//","/" "}
+echo Reclass the grid_id for the following output  ${GIS_OPT_OUTPUT//","/" "}
 echo ${GIS_OPT_OUTPUT//","/" "} |  xargs -n 1 -P $GIS_OPT_CPU bash -c $'
+if [ $1 = "cells" ]     ; then col=2 ; fi
 if [ $1 = "min" ]       ; then col=4 ; fi
 if [ $1 = "max" ]       ; then col=5 ; fi
 if [ $1 = "range" ]     ; then col=6 ; fi
@@ -342,6 +364,7 @@
 echo ${GIS_OPT_OUTPUT//","/" "} |  xargs -n 1 -P 1 bash -c $'
@@ -355,11 +378,13 @@
 r.reclass input=grid_ID  output=${GIS_OPT_VARIABLE}_$1  rules=$GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt   --overwrite   --q
 rm -f $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt
-r.out.gdal -c  input=${GIS_OPT_VARIABLE}_${1}  nodata=-9999  output=$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif  type=Int32  -c  createopt="COMPRESS=LZW,ZLEVEL=9"  --o --q  2> /dev/null
+r.out.gdal -c  input=${GIS_OPT_VARIABLE}_${1}  nodata=-9999  output=$GIS_OPT_OUT_FOLDER/${GIS_OPT_VARIABLE}_${1}.tif  type=Int32  -c  createopt="COMPRESS=LZW,ZLEVEL=9"  --o --q  2> /dev/null
 echo "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!"
 ' _
+exit
 echo "The full stream variable calculation has been done!"
-echo "To list the stream-specific output variables, use ls $GIS_OPT_FOLDER/blockfile/*.tif"
+echo "To list the stream-specific output variables, use ls $GIS_OPT_OUT_FOLDER/*.tif"
Modified: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
--- grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds	2015-09-22 21:52:57 UTC (rev 66296)
+++ grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds	2015-09-22 22:24:10 UTC (rev 66297)
@@ -22,7 +22,7 @@
 #%Module
-#% description: Sub-watershed delineation based on the drainage direction and a gridded stream network. Based on "Domisch, S., Amatulli, G., Jetz, W. (2015) Near-global freshwater-specific environmental variables for biodiversity analyses in 1km resolution. Scientific Data"
+#% description: Sub-watershed and sub-stream delineation based on the drainage direction and a gridded stream network.
 #% keywords: drainage, stream, hydrology
 #%End
@@ -46,12 +46,11 @@
 #% key: folder
 #% type: string
 #% key_desc: name
-#% description: Provide the full folder path and name where the sub-watersheds and sub-streams will be stored
+#% description: Provide the full folder path and name where the sub-watersheds and sub-streams should be stored
 #% required:no
 #%end
 #%option
 #% key: cpu
 #% type: double
@@ -136,17 +135,20 @@
 # shell check for user break (signal list: trap -l)
 # trap "exitprocedure" 2 3 15
 echo ""
+echo "#######################################################################################################"
 echo "Sub-watershed and sub-streams delineation based on the drainage direction and a gridded stream network."
 echo ""
 echo ""
 echo Exporting stream grid cell coordinates and saving in $GIS_OPT_FOLDER/stream_coord_lines.txt
-rm -fr    $GIS_OPT_FOLDER   2> /dev/null
-mkdir     $GIS_OPT_FOLDER   2> /dev/null
+mkdir     $GIS_OPT_FOLDER
 r.out.xyz   --o input=$GIS_OPT_STREAM  separator=space   output=$GIS_OPT_FOLDER/stream_coord.txt  --q
@@ -173,25 +175,25 @@
 max_seq4d=${max_line: -8:1} ; if [ -z $max_seq4d ] ; then max_seq4d=0 ; else  max_seq3d=9 ; max_seq2d=9 ; max_seq1d=9 ; fi
 for dir4d in  $(seq 0 $max_seq4d) ; do
-for dir3d in  $(seq 0 $max_seq3d) ; do
-for dir2d in  $(seq 0 $max_seq2d) ; do
-for dir1d in  $(seq 0 $max_seq1d) ; do
-mkdir -p  $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1
-done
-done
+    for dir3d in  $(seq 0 $max_seq3d) ; do
+	for dir2d in  $(seq 0 $max_seq2d) ; do
+	    for dir1d in  $(seq 0 $max_seq1d) ; do
+		mkdir -p  $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1
+	    done
+	done
+    done
 done
-done
 mkdir  $GIS_OPT_FOLDER/blockfile
-echo  "Split the stream grid cell coordinate file with $( wc -l $GIS_OPT_FOLDER/stream_coord.txt  | awk '{ print $1 }' ) grid cells into blocks of 10000 cells"
+echo  "Split the stream grid cell coordinate file (X|Y|ID) into subsets of 10000 lines"
 awk -v PATH=$GIS_OPT_FOLDER 'NR%10000==1{x=PATH"/blockfile/blockfile"(++i*10000-10000)}{print > x}'  $GIS_OPT_FOLDER/stream_coord_lines.txt
 awk '{ if(NR>1) print  }' $GIS_OPT_FOLDER/blockfile/blockfile0 > $GIS_OPT_FOLDER/blockfile/blockfile0_tmp
 mv $GIS_OPT_FOLDER/blockfile/blockfile0_tmp $GIS_OPT_FOLDER/blockfile/blockfile0
-echo Create $( ls $GIS_OPT_FOLDER/blockfile/blockfile* | wc -l ) blocks in $GIS_OPT_FOLDER/blockfile/
+echo Create $( ls $GIS_OPT_FOLDER/blockfile/blockfile* | wc -l ) subsets: $GIS_OPT_FOLDER/blockfile/blockfile*.tif
 rm -fr $GISDBASE/$LOCATION_NAME/sub_watershedID*
@@ -216,7 +218,7 @@
 g.gisenv set="LOCATION_NAME=$LOCATION_NAME"
 g.gisenv set="MAPSET=PERMANENT"
-echo  "Start the sub-watershed delineation for block $file"
+echo  "Start the sub-watershed delineation for subset $file"
 awk '{ print NR , $1 , $2 ,$3 }'   $file     | xargs  -n 4 -P $GIS_OPT_CPU  bash -c  $'
 NR=$1
@@ -224,13 +226,10 @@
 Y_coord=$3
 ID=$4
+echo -en  "\r$(expr $NR / 100 + 1 )% done"
-if [ $( expr  $( expr $NR + 1 ) / 100)  -eq  $( expr $NR / 100 + 1 ) ] ; then
-echo  -en  "\r$(expr $NR / 100 + 1 )% done"
-fi
+# replicate the start-GISRC in a unique GISRC
-# replicate the start-GISRC in a uniq GISRC
 cp   $GISRC_def    $HOME/.grass7/rc$ID
 export GISRC=$HOME/.grass7/rc$ID
@@ -256,8 +255,6 @@
 r.null  map=sub_streamID${ID}  setnull=0    --q
 r.out.gdal  -c type=Byte    --o --q     nodata=255     createopt="COMPRESS=LZW,ZLEVEL=9"   input=sub_streamID${ID}@sub_watershedID${ID}    output=$GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif
-if [ ! -f $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif  ] ; then the file $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID${ID}.tif  dose not exist ; fi
 rm -r $HOME/.grass7/rc$ID    $GISDBASE/$LOCATION_NAME/sub_watershedID$ID
 ' _
@@ -320,30 +317,20 @@
 ' _
 echo "Compress the sub-watersheds and sub-streams to reduce the number of inodes filling up the hard disk"
-cd  $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/
+tar -zcPf  $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/${filename}_sub_watershed.tar.gz   $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_watershedID*.tif
+tar -zcPf  $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/${filename}_sub_stream.tar.gz      $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/sub_streamID*.tif
-tar -zcPf  ${filename}_sub_watershed.tar.gz  sub_watershedID*.tif
-tar -zcPf  ${filename}_sub_stream.tar.gz     sub_streamID*.tif
+echo list the compressed files by ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz
-cd  $GIS_OPT_FOLDER
 g.gisenv set="GISDBASE=$GISDBASE"
-rm -fr    $GISDBASE/$LOCATION_NAME/sub_watershedID*    $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/*.tif
+rm -fr    $GISDBASE/$LOCATION_NAME/sub_watershedID* $GIS_OPT_FOLDER/${dir4d}digit4/${dir3d}digit3/${dir2d}digit2/${dir1d}digit1/*.tif
 done
-cd  $GIS_OPT_FOLDER
-echo The full sub-watershed delineation process has been done!
-echo To list the compressed files, use "ls $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/*.tar.gz"
-echo Now you can use r.stream.variables to compute stream-specific environmental variables.
