[GRASS-SVN] r66311 - grass-addons/grass7/vector/v.in.redlist
Wed Sep 23 12:22:49 PDT 2015
Author: hellik
Date: 2015-09-23 12:22:49 -0700 (Wed, 23 Sep 2015)
New Revision: 66311
   grass-addons/grass7/vector/v.in.redlist/Makefile
   grass-addons/grass7/vector/v.in.redlist/v.in.redlist.html
   grass-addons/grass7/vector/v.in.redlist/v.in.redlist.py
v.in.redlist: module_svn_propset
Modified: grass-addons/grass7/vector/v.in.redlist/Makefile
--- grass-addons/grass7/vector/v.in.redlist/Makefile	2015-09-23 19:16:53 UTC (rev 66310)
+++ grass-addons/grass7/vector/v.in.redlist/Makefile	2015-09-23 19:22:49 UTC (rev 66311)
@@ -1,7 +1,7 @@
-MODULE_TOPDIR = ../..
-PGM = v.in.redlist
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
+MODULE_TOPDIR = ../..
+PGM = v.in.redlist
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.in.redlist/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Modified: grass-addons/grass7/vector/v.in.redlist/v.in.redlist.html
--- grass-addons/grass7/vector/v.in.redlist/v.in.redlist.html	2015-09-23 19:16:53 UTC (rev 66310)
+++ grass-addons/grass7/vector/v.in.redlist/v.in.redlist.html	2015-09-23 19:22:49 UTC (rev 66311)
@@ -1,46 +1,46 @@
-<h2>DESCRIPTION</h2>
-<em>v.in.redlist</em> imports <a href="http://www.iucn.org/">IUCN</a> <a href="http://www.iucnredlist.org/">Red List</a>
-<a href="http://www.iucnredlist.org/technical-documents/spatial-data">Spatial Data</a>.
-This data is by definition in WGS84 geographic coordinates.
-<p>
- By the <i>-l</i> flag species in column 'binomial' of the attribute
-table are listed. The species in column 'binomial' can be exported to a
-text file by the <i>-s</i> flag.
-</p>
-<p>
-One of the species mentioned by <i>-l</i> or <i>-s</i> flag has to be specified for importing.
-</p>
-<h2>EXAMPLE</h2>
-<div class="code">
- <pre>
-  # list species in column 'binomial' of the attribute table by -l flag
-  v.in.redlist -l input=C:\dl\iucn\GYMNOPHIONA\GYMNOPHIONA.shp
-  # export species in column 'binomial' of the attribute table into a text file by -s flag
-  v.in.redlist -s input=C:\dl\iucn\GYMNOPHIONA\GYMNOPHIONA.shp dir=C:\dl\iucn\GYMNOPHIONA
-  # import spatial data for a user defined species
-  v.in.redlist input=C:\dl\iucn\GYMNOPHIONA\GYMNOPHIONA.shp /
-  output=Scolecomorphus_vittatus species_name=Scolecomorphus vittatus
- </pre>
-</div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="v.in.ogr.html">v.in.ogr</a>
-</em>
-<h2>AUTHOR</h2>
-Helmut Kudrnovsky
-<p>
-<i>Last changed: $Date: 2015-08-28 18:13:57 +0200 (Fr, 28 Aug 2015) $</i>
+<h2>DESCRIPTION</h2>
+<em>v.in.redlist</em> imports <a href="http://www.iucn.org/">IUCN</a> <a href="http://www.iucnredlist.org/">Red List</a>
+<a href="http://www.iucnredlist.org/technical-documents/spatial-data">Spatial Data</a>.
+This data is by definition in WGS84 geographic coordinates.
+<p>
+ By the <i>-l</i> flag species in column 'binomial' of the attribute
+table are listed. The species in column 'binomial' can be exported to a
+text file by the <i>-s</i> flag.
+</p>
+<p>
+One of the species mentioned by <i>-l</i> or <i>-s</i> flag has to be specified for importing.
+</p>
+<h2>EXAMPLE</h2>
+<div class="code">
+ <pre>
+  # list species in column 'binomial' of the attribute table by -l flag
+  v.in.redlist -l input=C:\dl\iucn\GYMNOPHIONA\GYMNOPHIONA.shp
+  # export species in column 'binomial' of the attribute table into a text file by -s flag
+  v.in.redlist -s input=C:\dl\iucn\GYMNOPHIONA\GYMNOPHIONA.shp dir=C:\dl\iucn\GYMNOPHIONA
+  # import spatial data for a user defined species
+  v.in.redlist input=C:\dl\iucn\GYMNOPHIONA\GYMNOPHIONA.shp /
+  output=Scolecomorphus_vittatus species_name=Scolecomorphus vittatus
+ </pre>
+</div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.in.ogr.html">v.in.ogr</a>
+</em>
+<h2>AUTHOR</h2>
+Helmut Kudrnovsky
+<p>
+<i>Last changed: $Date$</i>
 </p>
\ No newline at end of file
Property changes on: grass-addons/grass7/vector/v.in.redlist/v.in.redlist.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass-addons/grass7/vector/v.in.redlist/v.in.redlist.py
--- grass-addons/grass7/vector/v.in.redlist/v.in.redlist.py	2015-09-23 19:16:53 UTC (rev 66310)
+++ grass-addons/grass7/vector/v.in.redlist/v.in.redlist.py	2015-09-23 19:22:49 UTC (rev 66311)
@@ -1,133 +1,133 @@
-#!/usr/bin/env python
-MODULE:    v.in.redlist
-AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
-PURPOSE:   Imports IUCN Red List Spatial Data
-COPYRIGHT: (C) 2015 by the GRASS Development Team
-           This program is free software under the GNU General Public
-           License (>=v2). Read the file COPYING that comes with GRASS
-           for details.
-#%module
-#% description: importing of IUCN Red List Spatial Data
-#% keyword: vector
-#% keyword: geometry
-#%end
-#%option G_OPT_F_BIN_INPUT
-#% key: input
-#% description: name of the IUCN Red List Spatial Data shapefile
-#% required : yes
-#% guisection: GIS data
-#%end
-#%option G_OPT_V_OUTPUT
-#% key: output
-#% description: name of the imported IUCN Red List Spatial Data
-#% required : no
-#%end
-#%option
-#% key: species_name
-#% description: name of species which should be imported
-#% required : no
-#%end
-#%flag
-#% key: l
-#% description: list species in IUCN Red List Spatial Data
-#% guisection: listing
-#%end
-#%flag
-#% key: s
-#% description: save species list to a text file
-#%end
-#%option G_OPT_M_DIR
-#% key: dir
-#% description: Directory where the species list will be found
-#% required : no
-#%end
-import sys
-import os
-import grass.script as grass
-from osgeo import ogr
-if not os.environ.has_key("GISBASE"):
-    grass.message( "You must be in GRASS GIS to run this program." )
-    sys.exit(1)
-def main():
-    redlist_shapefile_long = options['input']
-    imported_species = options['species_name']
-    species_to_import = options['output']
-    imported_species_quoted = "'"+imported_species+"'"
-    directory = options['dir']
-    list_species = flags['l']
-    save_species = flags['s']
-    redlist_shapefile_short = os.path.basename(redlist_shapefile_long)
-    species_filename = redlist_shapefile_short.split('.')[0]
-    species_file = species_filename+'.txt'
-    global tmp
-    # save species list to a user defined directory
-    if save_species :
-		grass.message( "saving species list to a text file ..." )
-		output_species_file = os.path.join( directory, species_file )
-		# define ogr driver
-		driver = ogr.GetDriverByName("ESRI Shapefile")
-		# open data source
-		dataSource = driver.Open(redlist_shapefile_long, 0)
-		# get layer
-		layer = dataSource.GetLayer()
-		# open export file
-		f = open('%s' % (output_species_file), 'wb')
-		# write content of the attribute table column binomial
-		for feature in layer:
-			 f.write('%s\n' % (feature.GetField("binomial")))
-		f.close()
-		grass.message( "%s" % (output_species_file) )
-    # print species list of the shapefile
-    elif list_species :
-		grass.message( "list species IUCN Red List Spatial Data ..." )
-		# get layer
-				grass.message( '%s' % (feature.GetField("binomial")))
-    # import spatial data for a user defined species in the Red List
-    else :
-		grass.message( " importing spatial data for %s ..." % (imported_species_quoted) )
-		grass.run_command( "v.in.ogr", input = redlist_shapefile_long,
-								output = species_to_import,
-								where = "binomial = %s" % (imported_species_quoted),
-								quiet = True)
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
+#!/usr/bin/env python
+MODULE:    v.in.redlist
+AUTHOR(S): Helmut Kudrnovsky <alectoria AT gmx at>
+PURPOSE:   Imports IUCN Red List Spatial Data
+COPYRIGHT: (C) 2015 by the GRASS Development Team
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+#%module
+#% description: importing of IUCN Red List Spatial Data
+#% keyword: vector
+#% keyword: geometry
+#%end
+#%option G_OPT_F_BIN_INPUT
+#% key: input
+#% description: name of the IUCN Red List Spatial Data shapefile
+#% required : yes
+#% guisection: GIS data
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: output
+#% description: name of the imported IUCN Red List Spatial Data
+#% required : no
+#%end
+#%option
+#% key: species_name
+#% description: name of species which should be imported
+#% required : no
+#%end
+#%flag
+#% key: l
+#% description: list species in IUCN Red List Spatial Data
+#% guisection: listing
+#%end
+#%flag
+#% key: s
+#% description: save species list to a text file
+#%end
+#%option G_OPT_M_DIR
+#% key: dir
+#% description: Directory where the species list will be found
+#% required : no
+#%end
+import sys
+import os
+import grass.script as grass
+from osgeo import ogr
+if not os.environ.has_key("GISBASE"):
+    grass.message( "You must be in GRASS GIS to run this program." )
+    sys.exit(1)
+def main():
+    redlist_shapefile_long = options['input']
+    imported_species = options['species_name']
+    species_to_import = options['output']
+    imported_species_quoted = "'"+imported_species+"'"
+    directory = options['dir']
+    list_species = flags['l']
+    save_species = flags['s']
+    redlist_shapefile_short = os.path.basename(redlist_shapefile_long)
+    species_filename = redlist_shapefile_short.split('.')[0]
+    species_file = species_filename+'.txt'
+    global tmp
+    # save species list to a user defined directory
+    if save_species :
+		grass.message( "saving species list to a text file ..." )
+		output_species_file = os.path.join( directory, species_file )
+		# define ogr driver
+		driver = ogr.GetDriverByName("ESRI Shapefile")
+		# open data source
+		dataSource = driver.Open(redlist_shapefile_long, 0)
+		# get layer
+		layer = dataSource.GetLayer()
+		# open export file
+		f = open('%s' % (output_species_file), 'wb')
+		# write content of the attribute table column binomial
+		for feature in layer:
+			 f.write('%s\n' % (feature.GetField("binomial")))
+		f.close()
+		grass.message( "%s" % (output_species_file) )
+    # print species list of the shapefile
+    elif list_species :
+		grass.message( "list species IUCN Red List Spatial Data ..." )
+		# get layer
+				grass.message( '%s' % (feature.GetField("binomial")))
+    # import spatial data for a user defined species in the Red List
+    else :
+		grass.message( " importing spatial data for %s ..." % (imported_species_quoted) )
+		grass.run_command( "v.in.ogr", input = redlist_shapefile_long,
+								output = species_to_import,
+								where = "binomial = %s" % (imported_species_quoted),
+								quiet = True)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.in.redlist/v.in.redlist.py
   + text/x-python
   + native
