[GRASS-SVN] r66319 - in grass/trunk/temporal/t.rast.series: . testsuite
Thu Sep 24 00:22:57 PDT 2015
Author: huhabla
Date: 2015-09-24 00:22:57 -0700 (Thu, 24 Sep 2015)
New Revision: 66319
Added:
   grass/trunk/temporal/t.rast.series/testsuite/
   grass/trunk/temporal/t.rast.series/testsuite/test_series.py
   grass/trunk/temporal/t.rast.series/t.rast.series.py
temporal modules: Fixed usage of the "z" flag and added tests
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py	2015-09-24 05:04:21 UTC (rev 66318)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py	2015-09-24 07:22:57 UTC (rev 66319)
@@ -98,7 +98,9 @@
         file.close()
-        flag = "z"
+        flag = ""
+        if len(rows) > 1000:
+            flag += "z"
         if nulls:
             flag += "n"
Added: grass/trunk/temporal/t.rast.series/testsuite/test_series.py
--- grass/trunk/temporal/t.rast.series/testsuite/test_series.py	                        (rev 0)
+++ grass/trunk/temporal/t.rast.series/testsuite/test_series.py	2015-09-24 07:22:57 UTC (rev 66319)
@@ -0,0 +1,154 @@
+"""Test t.rast.series
+(C) 2015 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert
+import os
+import grass.pygrass.modules as pymod
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestSnapAbsoluteSTRDS(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        os.putenv("GRASS_OVERWRITE",  "1")
+        tgis.init()
+        cls.use_temp_region()
+        cls.runModule("g.region",  s=0,  n=80,  w=0,  e=120,  b=0,
+                      t=50,  res=10,  res3=10)
+        cls.runModule("r.mapcalc", expression="a1 = 100",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a2 = 200",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a3 = 300",  overwrite=True)
+        cls.runModule("r.mapcalc", expression="a4 = 400",  overwrite=True)
+        cls.runModule("t.create",  type="strds",  temporaltype="absolute",
+                                    output="A",  title="A test",
+                                    description="A test",  overwrite=True)
+        cls.runModule("t.register", type="raster",  input="A",
+                                     maps="a1,a2,a3,a4",
+                                     start="2001-01-01",
+                                     increment="1 month",
+                                     overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.del_temp_region()
+        cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+        cls.runModule("g.remove", flags="f", type="raster", name="series_average")
+        cls.runModule("g.remove", flags="f", type="raster", name="series_maximum")
+        cls.runModule("g.remove", flags="f", type="raster", name="series_minimum")
+        cls.runModule("g.remove", flags="f", type="raster", name="series_minimum_2")
+    def test_average(self):
+        self.assertModule("t.rast.series", input="A", method="average",
+                          output="series_average")
+        self.assertRasterMinMax(map="series_average", refmin=250, refmax=250,
+                                msg="Average must be 250")
+    def test_maximum(self):
+        self.assertModule("t.rast.series", input="A", method="maximum",
+                          output="series_maximum")
+        self.assertRasterMinMax(map="series_maximum", refmin=400, refmax=400,
+                                msg="Maximum must be 400")
+    def test_minimum(self):
+        self.assertModule("t.rast.series", input="A", method="minimum",
+                          output="series_minimum")
+        self.assertRasterMinMax(map="series_minimum", refmin=100, refmax=100,
+                                msg="Minimum must be 100")
+    def test_minimum_where(self):
+                          output="series_minimum_2",
+                          where="start_time >= '2001-03-01'")
+        self.assertRasterMinMax(map="series_minimum_2", refmin=300, refmax=300,
+                                msg="Minimum must be 300")
+class TestSnapRelativeSTRDS(TestCase):
+    @classmethod
+        tgis.init()
+        cls.runModule("t.create",  type="strds",  temporaltype="relative",
+                                     start="0",
+                                     increment="14", unit="days",
+                                     overwrite=True)
+    @classmethod
+                          where="start_time >= 28")
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
