[GRASS-SVN] r66322 - in grass-addons/grass7/raster/r.green/r.green.hydro: libhydro r.green.hydro.theoretical
svn_grass at osgeo.org
Thu Sep 24 06:34:08 PDT 2015
Author: Giulia
Date: 2015-09-24 06:34:08 -0700 (Thu, 24 Sep 2015)
New Revision: 66322
grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
r.green: uniform input with other modules
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py 2015-09-24 13:33:32 UTC (rev 66321)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/libhydro/basin.py 2015-09-24 13:34:08 UTC (rev 66322)
@@ -329,7 +329,7 @@
gcore.run_command("r.to.vect", input=tmp_thin,
flags='v',
output=tmp_clean, type="line")
- gcore.run_command("v.edit", map='vec_clean', tool='delete', cats='0')
+ gcore.run_command("v.edit", map=tmp_clean, tool='delete', cats='0')
#pdb.set_trace()
gcore.run_command('v.build', map=tmp_clean)
dissolve_lines(tmp_clean, E)
@@ -480,8 +480,9 @@
msgr = get_msgr()
if (not(basins) or not(stream)):
- basins = 'basins'
- stream = 'stream'
+ pid = os.getpid()
+ basins = "tmprgreen_%i_basins" % pid
+ stream = "tmprgreen_%i_stream" % pid
gcore.run_command('r.watershed',
elevation=dtm,
threshold=threshold,
@@ -563,23 +564,10 @@
return temp
-def fill_energyown(bas, h_mean, discharge_n, stream_n):
+def fill_energyown(bas, h_mean):
Fill basins dictionary with discharge, h_mean and compute the power
- msgr = get_msgr()
- warn = ("%i") % bas.ID
- ttt = discharge_n[stream_n == bas.ID]
- #import ipdb; ipdb.set_trace()
- bas.discharge_own = ttt.sort()
- #FIXME: take the second bgger value to avoid to take the value of
- # another catchment, it is not so elegant
- if len(ttt) > 1 and not(math.isnan(ttt[-2])):
- bas.discharge_own = float(ttt[-2])
- else:
- bas.discharge_own = 0.0
- warn = ("No value for the river ID %i, discharge set to 0") % bas.ID
- msgr.warning(warn)
bas.h_mean = h_mean
# basins_tot[count].h_closure = float(info_c[count])
@@ -589,18 +577,39 @@
#pdb.set_trace()
-def fill_discharge_tot(basins_tot, b):
+def fill_discharge_tot(bas, discharge_n, stream_n):
Fill the total discharge for the basin b by knowing
the relation among basins
thank to the ID_all attribute in the object Basin
- basins_tot[b].discharge_tot = basins_tot[b].discharge_own
+ msgr = get_msgr()
+ warn = ("%i") % bas.ID
+ ttt = discharge_n[stream_n == bas.ID]
+ #import ipdb; ipdb.set_trace()
+ bas.discharge_tot = 0.0
+ ttt.sort()
+ #FIXME: take the second bgger value to avoid to take the value of
+ # another catchment, it is not so elegant
+ # the low value is the upper part of the basin and the greater
+ # the closure point
+ if len(ttt) > 1 and not(math.isnan(ttt[-2])):
+ bas.discharge_tot = float(ttt[-2])
+ else:
+ warn = ("No value for the river ID %i, discharge set to 0") % bas.ID
+ msgr.warning(warn)
+def fill_discharge_own(basins_tot, b):
+ Fill the discharge_own with the run-off of the basin
+ basins_tot[b].discharge_own = basins_tot[b].discharge_tot
#import pdb; pdb.set_trace()
- if basins_tot[b].up:
- basins_tot[b].check_ID_up(basins_tot)
- temp = discharge_sum(basins_tot, basins_tot[b].ID_all)
- basins_tot[b].discharge_tot = basins_tot[b].discharge_own + temp
+ for idd in basins_tot[b].up:
+ basins_tot[b].discharge_own = (basins_tot[b].discharge_own -
+ basins_tot[idd].discharge_tot)
def fill_Eup(basins_tot, b):
@@ -644,9 +653,11 @@
area = area_of_basins(basins, count, dtm)
basins_tot[count].area = float(area)
h_mean = float(info_h[str(count)])
- fill_energyown(basins_tot[count], h_mean, discharge, stream)
+ fill_discharge_tot(basins_tot[count], discharge, stream)
for b in inputs:
- fill_discharge_tot(basins_tot, b)
+ fill_discharge_own(basins_tot, b)
+ fill_energyown(basins_tot[b], h_mean)
for b in inputs:
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py 2015-09-24 13:33:32 UTC (rev 66321)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py 2015-09-24 13:34:08 UTC (rev 66322)
@@ -123,7 +123,7 @@
pid = os.getpid()
DEBUG = False
- atexit.register(cleanup, pattern=("tmprgreen_%i" % pid), debug=DEBUG)
+ atexit.register(cleanup, pattern=("tmprgreen_%i*" % pid), debug=DEBUG)
#TOD_add the possibilities to have q_points
# required
discharge = options['discharge']
@@ -212,7 +212,6 @@
# if not rivers or debug I write the result in the new vector stream
msgr.message("\nWrite results\n")
- import ipdb; ipdb.set_trace()
basin.write_results2newvec(stream, E, basins_tot, inputs)
