[GRASS-SVN] r66324 - in grass-addons/grass7/raster: r.stream.variables r.stream.watersheds
Thu Sep 24 12:31:33 PDT 2015
Author: elselvaje
Date: 2015-09-24 12:31:33 -0700 (Thu, 24 Sep 2015)
New Revision: 66324
   grass-addons/grass7/raster/r.stream.variables/r.stream.variables
   grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
change attribute nave from vectID to rasterID
Modified: grass-addons/grass7/raster/r.stream.variables/r.stream.variables
--- grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-09-24 13:48:19 UTC (rev 66323)
+++ grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-09-24 19:31:33 UTC (rev 66324)
@@ -377,7 +377,7 @@
 echo  Create stream-specific variable:  $GIS_OPT_VARIABLE $1
 r.reclass input=grid_ID  output=${GIS_OPT_VARIABLE}_$1  rules=$GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt   --overwrite   --q
-rm -f $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt
+# rm -f $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt
 r.out.gdal -c  input=${GIS_OPT_VARIABLE}_${1}  nodata=-9999  output=$GIS_OPT_OUT_FOLDER/${GIS_OPT_VARIABLE}_${1}.tif  type=Int32  -c  createopt="COMPRESS=LZW,ZLEVEL=9"  --o --q  2> /dev/null
 if test -f "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif"; then echo "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!";fi
Modified: grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds
--- grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds	2015-09-24 13:48:19 UTC (rev 66323)
+++ grass-addons/grass7/raster/r.stream.watersheds/r.stream.watersheds	2015-09-24 19:31:33 UTC (rev 66324)
@@ -160,7 +160,7 @@
 echo Rasterize the stream network point coordinates
-v.to.rast --overwrite  input=vector_ID   output=grid_ID   layer=vector_ID     use=attr     attrcolumn=int_1   type=point  --q
+v.to.rast --overwrite  input=vector_ID   output=grid_ID   layer=vector_ID     use=attr     attrcolumn=cat   type=point  --q
 echo  Create the folder structure in $GIS_OPT_FOLDER/ to save results
