[GRASS-SVN] r66328 - in grass/trunk/temporal: t.rast.what t.vect.what.strds
svn_grass at osgeo.org
Fri Sep 25 04:07:25 PDT 2015
Author: neteler
Date: 2015-09-25 04:07:25 -0700 (Fri, 25 Sep 2015)
New Revision: 66328
grass/trunk/temporal/t.rast.what/t.rast.what.html
grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
temporal manual: reference v.what.strds
Modified: grass/trunk/temporal/t.rast.what/t.rast.what.html
--- grass/trunk/temporal/t.rast.what/t.rast.what.html 2015-09-25 10:59:31 UTC (rev 66327)
+++ grass/trunk/temporal/t.rast.what/t.rast.what.html 2015-09-25 11:07:25 UTC (rev 66328)
@@ -1,21 +1,24 @@
<h2>DESCRIPTION</h2>
<em>t.rast.what</em> is designed to sample space time raster datasets
-at specific point coordinates using <a href="r.what.html">r.what</a> internally.
-The output of <a href="r.what.html">r.what</a>
-is transformed to different output layouts.
+at specific point coordinates using <a href="r.what.html">r.what</a>
+internally. The output of <a href="r.what.html">r.what</a> is transformed
+to different output layouts.
The output layouts can be specified using the <em>layout</em> option.
<p>
Three layouts can be specified:
<ul>
<li><em>row</em> - Row order, one vector sample point value per row</li>
- <li><em>col</em> - Column order, create a column for each vector sample point of a single time step/raster layer</li>
- <li><em>timerow</em> - Time order, create a column for each time step, this order is the original r.what output, except that the column names are the time stamps</li>
+ <li><em>col</em> - Column order, create a column for each vector sample
+ point of a single time step/raster layer</li>
+ <li><em>timerow</em> - Time order, create a column for each time step,
+ this order is the original <em>r.what</em> output, except that the column
+ names are the timestamps</li>
</ul>
Please have a look at the example to see the supported layouts.
<p>
-This module is designed to run several instances of r.what to sample
+This module is designed to run several instances of <em>r.what</em> to sample
subsets of a space time raster dataset in parallel. Several intermediate
text files will be created that are merged into a single file at the
end of the processing.
@@ -31,7 +34,8 @@
<h3>Data preparation</h3>
In the following examples we sample a space time raster dataset that contains
-4 raster map layers. First we create the STRDS that will be sampled with t.rast.what.
+4 raster map layers. First we create the STRDS that will be sampled with
+<em>t.rast.what</em>.
<div class="code"><pre>
g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10
@@ -116,13 +120,14 @@
<h2>SEE ALSO</h2>
<em>
-<a href="r.what.html">r.what</a> ,
+<a href="g.region.html">g.region</a>,
+<a href="r.mask.html">r.mask</a>
<a href="r.neighbors.html">r.neighbors</a>,
+<a href="r.what.html">r.what</a>,
+<a href="t.info.html">t.info</a>,
<a href="t.rast.aggregate.ds.html">t.rast.aggregate.ds</a>,
<a href="t.rast.extract.html">t.rast.extract</a>,
-<a href="t.info.html">t.info</a>,
-<a href="g.region.html">g.region</a>,
-<a href="r.mask.html">r.mask</a>
+<a href="v.what.strds.html">v.what.strds</a>
</em>
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html 2015-09-25 10:59:31 UTC (rev 66327)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html 2015-09-25 11:07:25 UTC (rev 66328)
@@ -24,6 +24,7 @@
<a href="v.univar.html">v.univar</a>,
<a href="v.what.rast.html">v.what.rast</a>,
<a href="v.what.rast3.html">v.what.rast3</a>,
+<a href="v.what.strds.html">v.what.strds</a>,
<a href="v.what.vect.html">v.what.vect</a>,
<a href="t.create.html">t.create</a>,
